Full Version: AppleTv2 - New router/wifi connection
Hey all,
My Mum has had her wifi router replaced after an ISP engineer visit to her house. I've setup her Apple TV to boot straight into XBMC by passing the frontrow dashboard (keeps it simple). Is there a way I can use terminal/ssh to add the new wifi settings if I initially hardwire to the router?
Cheers
I'm not aware of any ability to modify wireless settings via shh to the AppleTV. If you run an ethernet to the AppleTV, does it get an IP address from your new router? If so, you could use that IP address to ssh to the Apple TV, remove the auto-boot to XBMC to get back to Frontrow and then setup wireless.
DOH! Never thought of that, cheers will give it blast tonight, thanks
