2011-11-29, 19:50
Hi all,
I have a problem to read my m2ts file. I have big jerks on my MacMini 2.4 Ghz/4Go RAM.
I tried all the options in the video settings but it does not change!
I have made no changes to the file.
It has a rip and information I have no problem to read a PopcornHour (no irony for me eh! )
It's 1080p and 60Hz audio file DTSMA + LPCM and DD 5.1
Here is the transcript of a media-info:
Do you have an idea of the problem?
Thank you
Quote:* * * MediaInfo Mac 0.7.36.0 file analysis report.
* * * MediaInfo Mac is ©2010 by Diego Massanti - http://mediainfo.massanti.com
* * * MediaInfoLib by Jerome Martinez - http://mediainfo.sourceforge.net
Created on: 29 nov. 2011 18:44:48 HNEC
Report for file: BBKING.m2ts
General / Container Stream #1
Total Video Streams for this File.................1
Total Audio Streams for this File.................3
Video Codecs Used.................................AVC
Audio Codecs Used.................................PCM / AC3 / DTS-HD
File Format.......................................BDAV
Play Time.........................................1h 39mn
Total File Size...................................19.0 GiB
Total Stream BitRate..............................27.4 Mbps
Video Stream #1
Codec (Human Name)................................AVC
Codec (FourCC)....................................27
Codec [email protected]
Frame Width.......................................1 920 pixels
Frame Height......................................1 080 pixels
Frame Rate........................................29.970 fps
Total Frames......................................178319
Display Aspect Ratio..............................16:9
Video Standard....................................NTSC
Scan Type.........................................Interlaced
Scan Order........................................TFF
Color Space.......................................YUV
Codec Settings (Summary)..........................CABAC / 4 Ref Frames
Codec Settings (CABAC)............................Yes
Codec Settings (Reference Frames).................4
Video Stream Length...............................1h 39mn 9s 910ms
Video Stream BitRate Mode.........................VBR
Bit Depth.........................................8 bits
Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer Characteristics..........................BT.709-5, BT.1361
Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio Stream #1
Codec.............................................PCM
Codec (FourCC)....................................128
Audio Stream Length...............................1h 39mn 9s 975ms
Audio Stream BitRate..............................1 536 Kbps
Audio Stream BitRate Mode.........................CBR
Number of Audio Channels..........................2
Audio Channel's Positions.........................Front: L R
Sampling Rate.....................................48.0 KHz
Bit Depth.........................................16 bits
Audio Stream Delay................................10mn 0s
Audio Stream Size.................................1.06 GiB (6%)
Audio Stream #2
Codec.............................................AC-3
Codec (FourCC)....................................129
Audio Stream Length...............................1h 39mn 9s 984ms
Audio Stream BitRate..............................448 Kbps
Number of Audio Channels..........................6
Audio Channel's Positions.........................Front: L C R, Side: L R, LFE
Audio Stream Size.................................318 MiB (2%)
Audio Stream #3
Codec.............................................DTS
Codec (FourCC)....................................134
Audio Stream Length...............................1h 39mn 10s 5ms
Audio Stream BitRate Mode.........................VBR
Thank you
