Full Version: EMM Flags
I was wondering if someone could help me out with my media flags. I was using Media Companion until it stopped being supported and ceased working. I have switched to Ember Media Manager and I'm running into some problems with the flags.
Here is a screenshot of what I'm running into with some of the movies. This is an HD-DVD rip in VC-1 with a DD+ audio track. It seems as though EMM has no flags for either VC-1 or DD+. Is there a way to add those?
So no one else has encountered this issue?
Use vc1 instead of vc-1 to get the flag. The second issue I can't help you with.
clubwerks Wrote:Use vc1 instead of vc-1 to get the flag. The second issue I can't help you with.
Changing them to vc1 worked like a charm. Thanks clubwerks.
Does anyone know how to add a DD+ icon?
Also, after adding DVD as the source, XBMC doesn't seem to recognize that tag and show the DVD logo on the box. I know I can edit the file name to include .dvd, but I really don't want to rename 400+ movies and rebuild my iTunes library all over again.
