Full Version: [WIP] Unfinished Skin
I've been busy and what free time I got I enjoy playing Call of Duty plus I've had this skin pretty much done, or at the state its at now since February and only coded like 200 lines since then. I doubt I'll do anymore and I've gotten bored with it since I've been using it for a whole year almost. I'd say it's 85% done...
So here it is, enjoy!! - *No further support on this skin will be provided*
DOWNLOAD
nice
Is it Dharma or Eden compatible?
Thanks for your work on this! Now thats what a Wall view should look like! keep it simple and it looks awesome!! Smile
Japaja Wrote:Is it Dharma or Eden compatible?
According to the Addon.xml it should be Eden...
XBMCGUI = 3.0
@mcborzu:
maybe somebody (or me) wants to get hands on this nice skin...
unfortunately this one has a compressed textures.xbt
you have a release with all textures uncompressed?
mad-max
Is this Noir?
Hitcher Wrote:Is this Noir?
the episode view, yes. I always like that view bit not the other mockups so I took that view and used that as an influence for a unified theme...
@mad-max
The .xbt is just confluence images. I use confluence as my base so I can use the skin while building then when done and have my own images I delete the confluence .xbt
can we finish this? it looks awsome
noiz13 Wrote:can we finish this?
Of course you can.
Hitcher Wrote:Of course you can.
i what needs to be done with this skin doe you have a to list?
