Full Version: webcam setup
Hi all, looking for some software to run on my windows pc that will stream multiple webcam's to xbmc (using .strm file is fine) and also have the ability to do motion detection and viewing the stream on an iPad/iPhone as well!
A lot to ask, but I'm sure someone else has done something similar just can't find it myself.
Thx.
Matt.
There is a thread that just started which you ask the same question check it out it gives all the information you are asking. I will say be patient sometimes it takes a day or two for the guidance.
http://forum.xbmc.org/showthread.php?tid=50589
