OK put these together as I use Recently Added & I have a Revo 3600 so the intro used to start late & end to soon, so I made a new one using images only.
Download for Ver 0.9.4.1
Download for Ver 0.9.5-git as of 14:33 11/12/2011 - Side Panel Version Only, also due to the new search addon code in the skin, you cant have Recently Added & Search enabled at the same time, so I made them disable each other to stop conflicts.
note: there are two versions of Recently added one that uses a submenu layout & one that uses the side menu layout.
Recently Added:
Intro:
Nice! Love that layout
Would you mind sharing the backgrounds from the screenies?
Jaypeg Wrote:Nice! Love that layout
Thank you & here you go
Wallpaper Pictures
The mod looks great, though I can't use it as I'm using the github builds. Thanks for the wallpaper collection aswell, I've been meaning to get myself some new wallpapers for a while!
butchabay Wrote:Nice work ! If i can make a suggestion:
Labels " New Movies " or " New Epsiodes " wouldn't they look nicer alligned to the left ?
probably, but I like the look of it aligned to the right, used some of the blank space at the top.
Added a Git version using the latest Git revision as of 15:26 06/12/2011
Got it installed, I can see the little tab on the right... how do I activate it (get it to display)
Abrasher Wrote:Got it installed, I can see the little tab on the right... how do I activate it (get it to display)
Press right on your remote or keyboard, when the tab is visible.
I will double check, but I believe I did that. Perhaps not working on ATV2? I'll try in the morning.
Updated this to the latest Git version as of 14:33 11/12/2011
This works and looks great. But are you not supposed to be able to start the episodes/movies from this menu? Nothing happens when I press OK/Enter.
Nander Wrote:This works and looks great. But are you not supposed to be able to start the episodes/movies from this menu? Nothing happens when I press OK/Enter.
They work for me, OpenElec Pre Eden with latest refocus git version all working fine.
I'm also on a Revo 3600.
