Full Version: Use Ok dialog to display message
Is there an easy way to activate the built in okdialog to display a message, much like
Notification(header,message[,time,image])
will do for notifications?
Or would I need scripting to do this?
You would need a script.
Hm, a challenge Big Grin
Cheers
Couldn't you copy the code from your DialogOk.xml to a custom window?
I use eventghost and a change in DialogKaiToast.xml for the size change a well as defining where to look for the image local or network, I used a network path for the images.
and heres another motion shot
Image DRIVEWAY
Hope it helps.
