Full Version: Streaming from Seedbox
Hey guys
I'm having trouble adding my Seedbox as a video source.
I followed these instructions on website:
1. Install and run XBMC.
2. Select Videos from the main screen.
3. Click Add Source.
4. Click Browse.
5. Scroll down to the bottom and click Add Network Location
6. Configure the following:
Protocol: Web Server Directory (HTTPS)
Server Address: username.seedunlimited.com
Remote Path: /downloads/
Port: 443
Username: your seed unlimited username
Password: your password
7. Click OK
8. Scroll back up, you should see the entry you just added in step 6, click on it.
9. You should now see a list of files on your seed box, just click OK.
10. Enter a name for the server, this can be anything you like.
11. Click OK.
The above instructions worked fine on xbmc on my Windows PC... But for some reason, it won't work with the ATV2. (I get an "Unable to Connect" error "Could not retrieve directory information" etc.
Is this feature not working with the AppleTV2? or am I missing something?
Cheers.
Missing a debug log, for starters.
OK my bad.
I figured out what I did wrong on the ATV2. I selected WebDAV Server instead of Web Server Directory.
All working now Smile
when entering you address I'm not getting how it suppose to look do i enter it just like it says in my browser or do i need to enter extra username.seedunlimited.com just take out the username and enter 177.222.23.123.seedunlimited.com or is just my address thanks for the help on such a stupid question
sorry thats your path for your seedbox mine is gonna be different because mine is setup different
