Full Version: [atv2] crashes when scanning music library
Pages: 1 2
I keep getting crashes when trying to scan music library. Music library is SMB share from Windows iTunes music folder.
First of all - normaly i can't scan audio library - when trying to add source to library i have "Stop scanning" which do nothing. After manualy deleting MyMusic18.db end restarthing xbmc i see option "add to library" which starts scanning and then after few moments and scaned items xbmc crashes. Since then it try's to rescan music library every startup (even with "scan audio library at startup" unchecked in settings) and crashes after few songs creating endless loop. Only deleting MyMusic18.db helps, but then i'm right at beggining.
If needed I can provide any additional info.
AppleTV2
(uname -a) Darwin Apple-TV 11.0.0 Darwin Kernel Version 11.0.0: Thu Feb 10 21:46:56 PST 2011; root:xnu-1735.46~2/RELEASE_ARM_S5L8930X AppleTV2,1 arm K66AP Darwin
OS 8F455, IR 01.28, iBoot 1072.59, SW 4.3 / 2557
XBMC: xbmc-20111203-0a31dbe-master-atv2.deb
(installed apt-get 10-2 from repo, then nightly build with dpkg -i)
Logs:
First run with "add to library" try:
xbmc.log - http://pastebin.com/PH8VNqhf
syslog - http://pastebin.com/HWXuSA9H
crashreport (got 2 with almost same timestamp):
AppleTV_2011-12-03-133905_Apple-TV: http://pastebin.com/BpdhA9Vw
AppleTV_2011-12-03-133921_Apple-TV: http://pastebin.com/NCrTfFPu
Next runs:
xbmc.log - http://pastebin.com/j1cY6rRR
syslog - http://pastebin.com/dzc7wcdR
crashreport- http://pastebin.com/hP21zKSB
exact same issue here
could you try this version and report back?
http://dl.dropbox.com/u/30371861/org.xbm...d3tag3.deb
Same here
dropbox error cant grab file...error logging in?
I used to be able to scan music library or play music but now when I go into the music folder (I only have 1 folder with music) it crashes. If I try and scan the folder it crashes. If I remove and re-add the share and then try same thing ..it crashes back to atv2 desktop
sorry ... link corrected. Also see this thread which might be the same problem:
http://forum.xbmc.org/showthread.php?tid...box&page=7
Gump, yer a gdamn genius... fixed it, thanks so much, greatly appreciated
No issues scanning and no issues playing. Thank you
this fix is already in master and will be in eden aswell ... there might be other issues in the testversion i linked so don't bother...
ok...I've always grabbed the build from Darwin/atv2/...deb for my atv2
should I not be getting this one and should I actually be using the one from the osx builds?
thanks
homerjs Wrote:ok...I've always grabbed the build from Darwin/atv2/...deb for my atv2
thanks
ATV2s don't run OSX, so no.
Memphiz Wrote:this fix is already in master and will be in eden aswell ... there might be other issues in the testversion i linked so don't bother...
ok, so where is this master file? thanks
There is no build of it atm because the buildbots are suspended for Eden beta. So its in the master code ... no file to download for you yet ...
thank you appreciate the info
re-posted to other topic chain. NOT hijacked one. GOFF
Thumbnails using nfs shares using afp and mysql all off the same host. Interesting.
Have you tried browsing your afp source to see if it still works? It manages to see the db and get the thumbnails but bails when trying to get the music.
Maybe it doesn't like fiddy cent Smile
Ps start your own thread instead of hijacking one
Pages: 1 2
