Full Version: weather.wunderground plugin on ATV2 issue
Seeing the recent switch for Eden to default to wundeground (nice !) I noticed an error on ATV2
23:11:40 T:111419392 ERROR: Error Contents: No module named simplejson
23:11:40 T:111419392 ERROR: Traceback (most recent call last):
File "/private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/weather.wunderground/default.py", line 17, in <module>
import os, sys, urllib2, base64, socket, simplejson
ImportError: No module named simplejson
this is in a recent nightly (dec. 5th), it seems ios doesn't have simeplejson for python ?
weather still seems to work, but just wanted to give the devs a headsup.
Jester Wrote:Seeing the recent switch for Eden to default to wundeground (nice !) I noticed an error on ATV2
simplejson is an external script that needs to be install along with the add-on.
You can get the .zip from the link below.
http://mirrors.xbmc.org/addons/eden-pre/...implejson/
bedankt,
However this should be installed already/automatically if the wunderground plugin provides the default weather on a fresh install....
Jester Wrote:bedankt,
Indeed and it should.
PHP Code:
    <addon id="weather.wunderground" name="Weather Underground" version="0.0.2" provider-name="Team XBMC">
requires>
import addon="xbmc.python" version="2.0"/>
import addon="script.module.simplejson" version="2.0.10"/>
requires
So why it wasn't is a mystery.
Martijn Wrote:Indeed and it should.
PHP Code:
requires>
requires
ill get my debug boots on tonight and report back
thanks
I'm calling it gremlins
just tried to reproduce with a fresh nightly, no issue, sorry for the fuss, closed Smile
