I just purchase the ATV2 and have it at home.
I've not plugged it in or switched it on.
I've never jail broken anything before and really dont want to mess it up.
I want to install XBMC on it.
What do i need to do 1st ?
NeVeREire Wrote:I just purchase the ATV2 and have it at home.
the first step is to download seas0nPass and jailbreak it dont worry you will not mess it up once you jailbreak it you will need firecore..aTV Flash to install nito tv and that will give you xbmc
I need to check what version it is.. I think i also need to download the latest itunes.
Also when do i connect it to the router ? at the moment i've it on my desk not connected to the internet.
NeVeREire Wrote:I need to check what version it is.. I think i also need to download the latest itunes.
yes..you need to be on 4.3_8F455 to be untethered
rudawgr Wrote:yes..you need to be on 4.3_8F455 to be untethered
I've no idea what that means.
I need to buy a mini USB ! just seen
how do i check my firmware version ?
Also i dont have a Mac i've windows.
NeVeREire Wrote:how do i check my firmware version ?
go to settings, general, about
and also is the same process on mac or windows
rudawgr Wrote:the first step is to download seas0nPass and jailbreak it dont worry you will not mess it up once you jailbreak it you will need firecore..aTV Flash to install nito tv and that will give you xbmc
This is incorrect. You do not need Firecore's aTV Flash.
NeVeREire Wrote:I've no idea what that means.
You need a micro USB cable, which is different from a mini USB cable.
Ned Scott Wrote:This is incorrect. You do not need Firecore's aTV Flash.
you right scott you dont if you are not a newbe...im train to make thinks easier for him
rudawgr Wrote:you right scott you dont if you are not a newbe...im train to make thinks easier for him
Firecore's aTV Flash costs $30. Our wiki install instructions are very easy to follow and are free. Firecore's media player directly conflicts with XBMC due to some issue with file sharing libraries, and you have to uninstall it for XBMC to work.
scott what that hell are you talking about?..i have firecore and i have no problem with xbmc..also with firecore you get more software, yes it cost money but is money well spend
