smajor Wrote:It depends on Your resolution. Simply change the boblight percent values to pixels.
I tried that... didn't see a difference.
i'm running at full 1080p so (1920x1080)...
Lunatixz Wrote:I tried that... didn't see a difference.
maybe You misunderstood: the config file depend on the resolution, because lightpack calculates with exact pixels rather than percents like boblight
I callculated this in head, but with this many areas You're better of resizin gthem in the program itself with Your mouse
[LED_1]
IsEnabled=true
[email protected](0 0)
[email protected](1920 540)
CoefRed=1
CoefGreen=1
CoefBlue=1
[LED_2]
IsEnabled=true
[email protected](960 0)
[email protected](960 1080)
CoefRed=1
CoefGreen=1
CoefBlue=1
[LED_3]
IsEnabled=true
CoefRed=1
CoefGreen=1
CoefBlue=1
[LED_4]
IsEnabled=true
[email protected](0 540)
CoefRed=1
CoefGreen=1
CoefBlue=1
smajor Wrote:Niice!
I really like your tool. Could you change the width field (for dimensions) to a three digit number? This way my tv doesn't fit
Hello,
i have a SEDU-Box with 56 channels of mini-DMX LED-Stripes.
With AtmoWin on Win7 x64 this is running, but there is micro-stuttering while playing video.
So i am looking for an alternative solution.
I have read the thread, but i am not sure, if this combination (Win7 x64, SEDU-Box, Boblight-Plugin for XBMC Eden Beta 3, boblightd for Win) will run or not.
Someone running this combination ? If so, can you provide a boblight-config-file ?
Thanks & Regards,
XBMCManni
I find alot of Q&A on the software side of things, but very little in terms of how to setup the hardware,, I don't have tons of DIY electrical work, but I'm sure I have the skill to throw something together with solder, etc...
does someone have a good guide to build something that works with xbmc & boblight and/or lightpack?
I have tried googling but all i really see are different ways of accomplishing something and not really how to build it.
Links to product websites will help alot too.
I know I'm a noob, but would like to dive in for the high channel count build,,,
secondly, is there a way to duplicate a couple of the light strips so perhaps I can place some behind my front speakers,, I think it would be a pretty wild setup.....
lastly, anyone know a program that may work with sound to produce a light effect that may work better behind the speakers....
thx - added to the first post...
So I could connect the USB port from my anduino to my Windows 7 XBMC box and let the addon connect to a linux box for the daemon?
I have a question about this addon (before i invest in a LED strip). It sounds very nice, but the screen i use now has a resolution of 1920x1200, thus I have black bars in almost everything I view (I keep original aspect ratio's). How will this add-on react to this? Will it have much use?
triberraar Wrote:I have a question about this addon (before i invest in a LED strip). It sounds very nice, but the screen i use now has a resolution of 1920x1200, thus I have black bars in almost everything I view (I keep original aspect ratio's). How will this add-on react to this? Will it have much use?
On video that I play in 4x3, the lights on the side work as expected.
Adam B. Wrote:On video that I play in 4x3, the lights on the side work as expected.
As expected being they are black (what is what i expect would hope they didn't :p) or do you mean that boblight is smart enought to not take the black area but the sides of the "image"?
triberraar Wrote:As expected being they are black (what is what i expect would hope they didn't :p) or do you mean that boblight is smart enought to not take the black area but the sides of the "image"?
I believe boblight doesnt do any consideration automaticaly.
Everything depends on the config file (which tells the program what areas to merit) You make.
In a word: it can easily be done (try my configurator)
ps: So it will reflect rather on the users intellect (smartness)
