Hey everyone.
Wondering if I can get some brainstorming to figure out the next step in my setup here.
bobo1on1 has been kind enough to give me some advice along the way.
Right now I am using 4
http://www.sparkfun.com/products/10312 of these led strips
the type with the ws2801 chip in between each on the strip.
I accomplished my goal today of being able to at least get the lights to respond in a way.
I've followed this guide to the T
http://www.ladyada.net/make/adalight/
The LED's only on the top work and sometimes only 25 of them
I'm sticking with this boblight.conf file right now just to get some stability as anything else I do like using the calculator and plugging it into the boblight.conf file makes the LED's do random things and still only the top strand
D A N N Y
http://code.google.com/p/boblight/source...light.conf
using an arduino uno r3
I've gotten a bit over my head unfortunately and am stumped as to where I need to go next as all of my attempts only get the top to turn on (they all are connected together and getting power)
I really appreciate any help someone could offer
-----------EDIT-------------
I've adjusted the boblight.conf to use the calculator settings here
http://sanya.tarhelyszolgaltato.eu/index...37&comb=40
As of right now when I compile and upload the adalight file to the arduino per the adalight instructions i referenced above.....all 4 strips turn on....but only the top and the right flash, red then green then blue as seems to be indicating a proper startup.
the other 2 just turn on white and stay white.
When I start XBMC boblight connects and does its red green blue cycle again but the bottom and left side just remain white
When I play media however only the top 25 LED's light up....the rest of the top strip and the right strip is dark while the bottom and left strip remain white.
The 25 are changing colors but it mostly stays at whites and lite blues, even on pitch black they remain a bright white or blue....makes me feel like all of the data for the whole boblight.conf is going to those 25
Thoughts
lol I'm lost here
D A N
