Hi there,
using boblight for quite a long time now, but right now the lights stay of while playing a video and i cannot find the problem.
Any Help/Hint appreciated.
Boblight starts while starting the system (flashing Red, Green, Blue appears)
Configuration is an Adalight with 50 LEDs and according to the
xbmc debug log the boblight addon starts, but all lights stay out.
THX
Chaos
Does the xbmc plugin connect to the boblight server?
Hi
(2012-12-01, 22:11)meisterfuu Wrote: [ -> ]Does the xbmc plugin connect to the boblight server?
no that seems to be the big problem.
Started the boblightd in foreground and nothing connected.
A started boblight-X11 in a second terminal connected.
Also tried the network setting in the plugin to use 127.0.0.1, also did not work.
THX
Chaos
Hi
If i set the boblight plugin to use a static bg color, the color ist displayed the whole time. Also while playing videos.
So for some reason it seems the plugin cannot "scan" what is running.
Any Help/Comments?
THX
Chaos
(2012-11-30, 01:42)teeedubb Wrote: [ -> ]Yeah Im looking at using a WS2801 led strip. Ive ordererd a Teensy 2 board which should be able to handle 150 leds, but I doubt Ill need that many, Ive just rounded everything up. If its too many channels for the teensy I can cut the strip and space out the led so theres less channels. I wonder if its possible to group led's into single channels? Say like 2 leds per channel..
I am using a ws2801 150 led strip (well 140 i burn 5 ICs, i think is a 2801 per 2 leds) with no problem at all with the adalight code, what i want is be able to using it with the add-on, right now am using processing and is no the best thing to do...but so far so good i want to be able to have more control over the colors percent and things like that and I think the addon can give me that. Am using Arduino Uno R3, 5V 2A ps, 150 led strip.
I read somewhere someone compile boblightd server in a Mac, did someone have the compile version or at least the steps, i need that and a .pde compatible with boblight.
Hi
(2012-12-03, 21:51)reaven Wrote: [ -> ]I read somewhere someone compile boblightd server in a Mac, did someone have the compile version or at least the steps, i need that and a .pde compatible with boblight.
i used
adas tutorial for my 50 LEDs WS2801.
Did you try their
github pde?
About the Mac thing, no clue.
THX
Chaos
Hi there
(2012-12-01, 17:53)Chaos_666 Wrote: [ -> ]Hi there,
Configuration is an Adalight with 50 LEDs and according to the xbmc debug log the boblight addon starts, but all lights stay out.
THX
Chaos
(2012-12-01, 23:10)Chaos_666 Wrote: [ -> ]Hi
THX
Chaos
(2012-12-03, 14:46)Chaos_666 Wrote: [ -> ]Hi
Any Help/Comments?
THX
Chaos
after two days of digging into this, the problem was related to the addon script.watchlist.service
Deleted that and boblight works as usual.
Tough one. Maybe someone wants to dig further...
THX
Chaos
(2012-11-30, 20:27)illiac4 Wrote: [ -> ] (2012-11-30, 01:42)teeedubb Wrote: [ -> ]Yeah Im looking at using a WS2801 led strip. Ive ordererd a Teensy 2 board which should be able to handle 150 leds, but I doubt Ill need that many, Ive just rounded everything up. If its too many channels for the teensy I can cut the strip and space out the led so theres less channels. I wonder if its possible to group led's into single channels? Say like 2 leds per channel..
you can configure the two leds to sample the same position, so they will have the same colour. But i do not see the point of doing this.
I was thinking incase the controller couldnt handle enough channels I could group leds to reduce the number of channels, but on second though I dont think its right, as each led equals 1xRGB (3 channels).
(2012-12-03, 21:51)reaven Wrote: [ -> ] (2012-11-30, 01:42)teeedubb Wrote: [ -> ]Yeah Im looking at using a WS2801 led strip. Ive ordererd a Teensy 2 board which should be able to handle 150 leds, but I doubt Ill need that many, Ive just rounded everything up. If its too many channels for the teensy I can cut the strip and space out the led so theres less channels. I wonder if its possible to group led's into single channels? Say like 2 leds per channel..
Great, good to know that adalight works with boblight and 150 leds. Just, curious how did the leds burn out?
Got my led strip today, hopefully Ill get my teensy v2 soon so we I can get the ball rolling
I need some advice from the pro's here.
I have a 50 inch TV. I want something good, not too overwhelming.
It doesn't matter how or what products, as long as it is not too expensive (over 150€) and it needs to be very compatible with this xbmc addon.
Which is better: the small LED bulb strips or the flat strips? (I think the flat strips are easier to install?)
So what do you recommend?
Update
After digging around I found
http://www.karatelight.de
I'm interested in the Karatelight 16, so 4 led strips on each side of the TV
How compatible is this Karatelight with this addon? Plugandplay vs pain in the ass?
(2012-12-05, 05:26)teeedubb Wrote: [ -> ]Great, good to know that adalight works with boblight and 150 leds. Just, curious how did the leds burn out?
well I have my led strip just on top of my tv not secure or anything cause i was just testing, just few days ago i was preparing to mount it on my tv more "professionally" and i notice that my 150 led strip is in fact 160 so when i first programmed i code for 150 thats why i had 10 leds off !!!! my bad hahaha and my gain !!
(2012-12-19, 11:18)tripkip Wrote: [ -> ]I need some advice from the pro's here.
Update
After digging around I found http://www.karatelight.de
I would go with adalight. I have builD many of them. I have used the one on strand and also on stripe (32leds per meter). I can not say which are better. Cheaper are on strand and already defused but are bigger than the one on stripe.
Hello,
really interesting topic. I have a 47" TV and considering to buy a rgb led stripe 60led/m
https://www.adafruit.com/products/1138 and a Arduino Mega 2560 R3
I need 3m of led strip. Is the Arduino Mega capable to manage 180leds? Do I need anything else?
