Full Version: [RELEASE] Official XBMC boblight Addon
see that ?
(2013-07-16, 11:48)Memphiz Wrote: [ -> ]You need to configure your custom preset - it works definitly same like the slow and fast presets (just with custom values - so if it stays down on your side - your custom values are invalid somehow...).
OK It Worked,
I Use
preset: CUSTOM
Speed: 50
Autospeed: 0
Interpolation: off
saturation: 3.00
value: 1.50
threshold: 0 (What is the recommendition here ? what is it?)
But,
Seems like sometimes suddently the led FLASHES with white light, they just blink and then continue to work normaly.. I can't says how many times or when, but it just happen sometimes..
Flashing might be electronical problems or wrong prefix in the boblightd.conf
Threshholt specifies the grayvalue at which the leds are shut off (i have set this to 20 for example). It prevents the leds from turning on in very dark scenes (or in the outro...).
can you give me an example for "electronical problems" ?
What can cause this? what to check for?
You would need something like this: http://www.hackerspaceshop.com/raspberrypi-ws2801.html
While I was having issues with flashing it did help at first, but then I messed something up and had to reinstal OS on RPi. After that reinstall I don't need the bridge anymore. LED's work as they should connected directly to GPIO pins.
I guess something must have change in SPI driver in Raspbian or something.
I don't use Rasp-pi.. arduino uno + htpc +windows+boblight, thats it
^ no one know why my leds flashing sometimes? (no PI.. PC under windows)
and I am realy want to control boblight from web\iphone..
I saw Bobdroid for android, anyone can make ios app?
also saw this:
http://vzoltan.com/rpi/color.php
which is a color picker from web, this work for PI and this is the code:
http://vzoltan.com/rpi/color.zip
and the full topic
http://www.raspberrypi.org/phpBB3/viewto...&start=175
can it be translate for windows?
I feel like I am the only one who have iphone\windows lol..
The boblightd is working fine on OSX, but I've seen this video from the user amet on youtube:
http://www.youtube.com/watch?v=KuV0MTaYt-Q
Is the fullscreen capture done via boblight-x11? If it is, does someone have a compiled version for OSX? Prismatik just doesn't run as smooth as boblight...
(2013-07-26, 22:36)clep Wrote: [ -> ]The boblightd is working fine on OSX, but I've seen this video from the user amet on youtube:
Looks like a video played in XBMC.
Could anyone help me? Is there anyway to use the boblight client in windows to send data to a remote raspberry pi?
I have the boblight XBMC plugin and it works great, but I want to use bob light outside of XBMC, it is possible?
Hey Peeps,
I was wondering if someone actually tried to run this on a Pivos Xios yet ?
I am willing to try, but have no idea where to start with this.
Thanks !
did anyone come around with a fix for the letterbox-problem as written in post #540?
(2013-08-04, 16:51)danielfmo Wrote: [ -> ]Hi,
http://forum.xbmc.org/showthread.php?tid...pid1486374
(2013-08-17, 20:48)santiniuk Wrote: [ -> ]
This is for XBMC, right now there is no way to use boblight outside of XBMC (Windows).
Okay, so since LIFX is finally about to completely pass certification and is much closer to being shipped than ever before, does anyone plan on working LIFX into this addon? Something similar had been tried with Hue but due to apparent reasons relating to the Hue hub's limited query rate of 30 queries per second, it only made it feasible to use one bulb for the effect. This limitation does not exist on the LIFX bulb, as far as I can tell, as each bulb will be able to be communicated with directly via each bulb's integrated access point (read: LIFX's latest update on Kickstarter regarding controlling each bulb without being connected to a Wi-Fi access point). This should hopefully allow devs to address more than one bulb for the effect. Thanks for the consideration!
