2014-01-16, 06:09
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
2014-01-16, 06:09
2014-01-16, 17:40
(2014-01-16, 06:09)nickr Wrote: [ -> ](2014-01-16, 06:00)bry- Wrote: [ -> ]LOL first time I've seen someone bump someone else's post!(2014-01-14, 18:16)davisdmg Wrote: [ -> ]you are right, I'll record a video todayc'mon now - almost 24hrs since your last post.
waiting on my lightpack and started doing some reading. As someone who leaves their xbmc box online 24/7 does boblight shutdown the lights when the tv is powered off?
2014-01-16, 17:44
You can make it power off when the screensaver kicks in ... so yes
2014-01-16, 18:09
(2014-01-16, 17:44)Memphiz Wrote: [ -> ]You can make it power off when the screensaver kicks in ... so yes
excellent - thank you Memphiz
2014-01-16, 18:47
one more thing - is there a key combination that I can create a button for on a harmony remote to toggle this on/off?
2014-01-16, 19:19
(2014-01-16, 18:47)bry- Wrote: [ -> ]one more thing - is there a key combination that I can create a button for on a harmony remote to toggle this on/off?
What os? I use a script to start/stop boblightd in Linux. Works well, only downside is the spam in the xbnc.log when boblightd isn't running, which leads to this question:
Anyway to disable the boblight add on logging in xbmc.log?
2014-01-16, 19:30
(2014-01-16, 19:19)teeedubb Wrote: [ -> ](2014-01-16, 18:47)bry- Wrote: [ -> ]one more thing - is there a key combination that I can create a button for on a harmony remote to toggle this on/off?
Would be windows based.
2014-01-16, 19:42
Sorry man, my script will be of no use then.
2014-01-19, 22:37
(2014-01-14, 17:22)Memphiz Wrote: [ -> ]White fog? Are you leds burning or so? - sorry - but i guess without a photo or something nobody really knows what you mean
I'm sorry for my delay. I had so much work to do
Here are the photos and the videos showing what I meant:
These two are with custom settings:
https://www.dropbox.com/sc/9cdlgttaq3mwkql/Cg4exCl_3H
These are with "fast" settings:
https://www.dropbox.com/sc/nhfz05mab3ullg3/dQd1DVbuT7
and a video:
https://www.dropbox.com/sc/q834ri0k77ttxqh/xjvB7LNmYf
You can see that there is a white light always on
This is my boblight.conf:
http://paste.ubuntu.com/6782191/
I'm using an arduino to control the leds. And with that boblight, everything was going perfect in the raspberry pi. So I think my problem is in the boblight xbmc addon.
2014-01-19, 23:29
(2014-01-19, 22:37)davisdmg Wrote: [ -> ](2014-01-14, 17:22)Memphiz Wrote: [ -> ]White fog? Are you leds burning or so? - sorry - but i guess without a photo or something nobody really knows what you mean
and a video:
Did you try changing the threshold value? To 20 or something like that? Looks like it's set to zero.
2014-01-19, 23:50
(2014-01-19, 22:37)davisdmg Wrote: [ -> ]Although this is for Windows i suggest you read this topic and check your config http://forum.xbmc.org/showthread.php?tid=145908(2014-01-14, 17:22)Memphiz Wrote: [ -> ]White fog? Are you leds burning or so? - sorry - but i guess without a photo or something nobody really knows what you mean
and a video:
I'm 100% sure there is some misconfiguration.
Map a key to point/execute this script (modify to match boblight script) http://forum.xbmc.org/showthread.php?tid...pid1595159
Works perfect here.
2014-01-20, 00:19
I'm using ubuntu server, no windows
About thresold. It is set to 20 in the custom settings. I'll try a higher value. Ty for the answer!
2014-01-20, 00:33
(2014-01-20, 00:19)davisdmg Wrote: [ -> ]I'm using ubuntu server, no windows
I know it's for Windows but that doesn't mean you can't read it and understand how to adjust settings and why you should adjust them
Edit:
The last time I checked it had more info anyway also check this post and translate to your native language http://gathering.tweakers.net/forum/list...6#40091926
And this also http://gathering.tweakers.net/forum/list...6#39966806
2014-01-21, 14:31
hello guys,
i do not want to be slightly offtopic, but could you please help me with selecting a led string? i am planning to use it with a raspberry and a 42" tv, both for xbmc and also as a remote-controlled ambient lighting for my living room.
i would like to buy the cheapest and have found the following ones on ebay, however i am not sure whether they are long enough to cover the 42" tv. i plan to mount them with velcro, so even though i do not need water proofing, some casing on the leds might be useful for attaching the velcro.
so could you let me know which one would be the best for these purposes?
http://www.ebay.com/itm/50pcs-12mm-WS280...51af6af53d
http://www.ebay.com/itm/50PCS-WS2801-RGB...1c35a87511
http://www.ebay.com/itm/50pcs-12mm-IP65-...565746552c
http://www.ebay.com/itm/50pcs-12mm-IP65-...35c12558a7
http://www.ebay.com/itm/50PCS-WS2801-RGB...338539d8bd
thanks in advance
oh and I do not want to have an Arduino inbetween, i.e. i am shooting for this setup. Why is having an additional Arduino in the setup useful at all?
thanks in advance
2014-01-21, 16:14
(2014-01-21, 14:31)dre81 Wrote: [ -> ]hello guys,
thanks in advance
Hope this helps to you:
I have this leds.
http://www.ebay.es/itm/230873716903?ssPa...298wt_1165
If you are going to buy the leds from this store, send them a email after the buy telling them you come from this blog (grabthiscode and user davisdmg). They will give you 2$ discount and 5$ if you buy two. (Because I lot of people is coming from my blog).
And here you have the how-to for the raspberry + ambilight: http://www.grabthiscode.com/diy/how-to-s...die-trying
BTW I tried with belcro and it is not a very good solution. I would recommend pvc cahnnel.
