2014-01-24, 18:29
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
2014-01-27, 09:50
Hey guys,
Is there anyway to make the addon light up the leds with the average colour from all sampled zones, so all leds will be the same colour?
2014-01-27, 19:04
(2014-01-27, 09:50)teeedubb Wrote: [ -> ]Hey guys,
I guess just set vscan and hscan to 0-100 on all channels in conf.
/Söder
2014-01-28, 11:28
(2014-01-24, 18:00)schumi2004 Wrote: [ -> ](2014-01-24, 17:56)davisdmg Wrote: [ -> ]Hello again guys, I tried with higher values of thresold (20-30-40-50) and it isnt working. It shows better, but when the scene is black, it is showing like a "grey" light.Try these settings/conf
I'm not sure if I did something wrong.
I downloaded the boblight from google code. Compiled like first post says.
I'm launching boblightd -f (I'm in ubuntu server). Should I launch boblightd-x11 instead of boblightd?
About config files I have this for 50 leds connected to an arduino:
http://paste.ubuntu.com/6808972/
I'm not sure if I'm missing something
I had the same configuration in the raspberry pi, and the leds worked really great.
Any ideas?
50 leds conf http://pastebin.com/i5AunzH4
script.xbmc.boblight settings http://pastebin.com/UxVRSd5R
I tried these settings, work much better than mine.
So my problem is in boblight.conf. I was reading both files and the only thing that changes is the setting of the 3 main colors:
Your config:
[color]
name red
rgb FF0000
gamma 2.1
adjust 0.8
blacklevel 0.0
[color]
name green
rgb 00FF00
gamma 2.0
adjust 1.0
blacklevel 0.0
[color]
name blue
rgb 0000FF
gamma 2.1
adjust 0.5
blacklevel 0.0
My config:
[color]
name red
rgb FF0000
gamma 1.0
adjust 1.0
blacklevel 0.0
[color]
name green
rgb 00FF00
gamma 1.0
adjust 1.0
blacklevel 0.0
[color]
name blue
rgb 0000FF
gamma 1.0
adjust 1.0
blacklevel 0.0
I guess I can copy the positoin of the leds from my config to your config.
Thank you very much for the help!
2014-01-28, 13:17
(2014-01-27, 19:04)soder Wrote: [ -> ]I guess just set vscan and hscan to 0-100 on all channels in conf.
/Söder
Good idea and a plus is it that I could probably toggle between normal and one colour boblight with the remote.
2014-01-29, 18:01
(2014-01-28, 11:28)davisdmg Wrote: [ -> ](2014-01-24, 18:00)schumi2004 Wrote: [ -> ](2014-01-24, 17:56)davisdmg Wrote: [ -> ]Hello again guys, I tried with higher values of thresold (20-30-40-50) and it isnt working. It shows better, but when the scene is black, it is showing like a "grey" light.Try these settings/conf
Any ideas?
Your config:
[color]
name red
rgb FF0000
gamma 2.1
adjust 0.8
blacklevel 0.0
[color]
name green
rgb 00FF00
gamma 2.0
adjust 1.0
blacklevel 0.0
[color]
name blue
rgb 0000FF
gamma 2.1
adjust 0.5
blacklevel 0.0
My config:
[color]
name red
rgb FF0000
gamma 1.0
adjust 1.0
blacklevel 0.0
[color]
name green
rgb 00FF00
gamma 1.0
adjust 1.0
blacklevel 0.0
[color]
name blue
rgb 0000FF
gamma 1.0
adjust 1.0
blacklevel 0.0
From what I understand, the gamma/adjust setting in the .conf file is to be able to set different setting for each color. The setting in the XBMC addon if for all colors at once.
Also, the gamma setting is how much "glow" the color has. The adjust is just a way to give a stronger or weaker light.
Please correct me if I got it all wrong. =)
/Söder
2014-01-31, 20:10
Hi everyone, I just received my Lightpack (the one from the Kickstarter) I'm trying to find how to set the up Boblight Deamon for Mac OS I already have the config file, by using the boblight config generator. I'm trying to get this working on a Mac Mini as my HTPC. Any help would be amazing.
2014-02-05, 20:19
Having some trouble installing this on xbmcuntu for a lightpack... get the following error
No-one else seems to have had this issue recently - any thoughts?
ar: libboblight_la-boblight_client.o: No such file or directory
make[2]: *** [libboblight.la] Error 1
make[2]: Leaving directory `/home/xbmc/bobsource/boblight-read-only/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/xbmc/bobsource/boblight-read-only'
make: *** [all] Error 2
2014-02-05, 22:32
Hello,
I'm new in this forum and I hope to get help.
I use XbmcBuntu on a Zotac Zbox ID18 and a Arduino Uno Board.
The boblightd and Xbmc Boblight Addon are generally working, but I want the LEDs to be turned off when the screen is dark. I figured out that the setting "threshold" should control this behaviour, but I can't find this setting in the Addon configuration at XBMC. I found these values at .xbmc/addons/script.xbmc.boblight/resources/settings.xml, but when I change these values, it has no influence.
I hope anybody can help me.
2014-02-05, 22:37
(2014-01-27, 19:04)soder Wrote: [ -> ](2014-01-27, 09:50)teeedubb Wrote: [ -> ]Hey guys,
/Söder
I got around to trying this and it works nicely! I think I prefer it like this for watching movies - its not so colorful and distracting but it still adds atmosphere. Plus I can switch between 1 coloyr and normal boblight via remote by restarting boblightd with the different configs.
2014-02-06, 20:10
(2014-02-05, 22:37)teeedubb Wrote: [ -> ](2014-01-27, 19:04)soder Wrote: [ -> ](2014-01-27, 09:50)teeedubb Wrote: [ -> ]Hey guys,
/Söder
Great.
But I think it's possible to have non distracting settings even with about 15% grab at the edges.
My settings now are great I think. :-)
/Söder
2014-02-06, 22:23
2014-02-07, 04:49
Does anyone know how the config works with 2 lightpacks?? I tried to set mine up as follows but I'm only getting 1 light pack to work this way. Always this this config I am getting a lot of flickering as well.
Any help getting these 2 packs up and running would be greatly appreciated.
[global]
[device]
name LP1
channels 30
type lightpack
interval 20000
#bus 1
#address 6
#debug true
[device]
name LP2
channels 30
type lightpack
interval 20000
#bus 1
#address 7
#debug true
[color]
name red
rgb FF0000
gamma 1.6
adjust 1.0
blacklevel 0.0
[color]
name blu
rgb 0000FF
gamma 1.6
adjust 1.0
blacklevel 0.0
[color]
name grn
rgb 00FF00
gamma 1.6
adjust 1.0
blacklevel 0.0
[light]
name L01
color red LP1 1
color blu LP1 2
color grn LP1 3
hscan 25 50
vscan 85 100
[light]
name L02
color red LP1 4
color blu LP1 5
color grn LP1 6
hscan 0 25
vscan 85 100
[light]
name L03
color red LP1 7
color blu LP1 8
color grn LP1 9
hscan 0 15
vscan 75 100
[light]
name L04
color red LP1 10
color blu LP1 11
color grn LP1 12
hscan 0 15
vscan 50 75
[light]
name L05
color red LP1 13
color blu LP1 14
color grn LP1 15
hscan 0 15
vscan 25 50
[light]
name L06
color red LP1 16
color blu LP1 17
color grn LP1 18
hscan 0 15
vscan 0 25
[light]
name L07
color red LP1 19
color blu LP1 20
color grn LP1 21
hscan 0 12
vscan 0 15
[light]
name L08
color red LP1 22
color blu LP1 23
color grn LP1 24
hscan 12 24
vscan 0 15
[light]
name L09
color red LP1 25
color blu LP1 26
color grn LP1 27
hscan 24 36
vscan 0 15
[light]
name L10
color red LP1 28
color blu LP1 29
color grn LP1 30
hscan 36 48
vscan 0 15
[light]
name L11
color red LP2 1
color blu LP2 2
color grn LP2 3
hscan 48 60
vscan 0 15
[light]
name L12
color red LP2 4
color blu LP2 5
color grn LP2 6
hscan 60 72
vscan 0 15
[light]
name L13
color red LP2 7
color blu LP2 8
color grn LP2 9
hscan 72 82
vscan 0 15
[light]
name L14
color red LP2 10
color blu LP2 11
color grn LP2 12
hscan 84 96
vscan 0 15
[light]
name L15
color red LP2 13
color blu LP2 14
color grn LP2 15
hscan 85 100
vscan 0 25
[light]
name L16
color red LP2 16
color blu LP2 17
color grn LP2 18
hscan 85 100
vscan 25 50
[light]
name L17
color red LP2 19
color blu LP2 20
color grn LP2 21
hscan 85 100
vscan 50 75
[light]
name L18
color red LP2 22
color blu LP2 23
color grn LP2 24
hscan 85 100
vscan 75 100
[light]
name L19
color red LP2 25
color blu LP2 26
color grn LP2 27
hscan 75 100
vscan 85 100
[light]
name L20
color red LP2 28
color blu LP2 29
color grn LP2 30
hscan 50 75
vscan 85 100
2014-02-07, 13:51
Ludeboy:
isn't there a software (prismatik) to configure this...?
2014-02-07, 16:33
(2014-02-06, 22:23)Bub4 Wrote: [ -> ]Hello All,
First of all, thank you bobo1on1 and Memphiz for making this great addon...!
I don't have any other idea anymore but asking you guys.
Tried my best to setup the Boblight on my own, but in current stage it's like a big wall in front of me
Received the arduino uno and LEDs first to setup and this was working fine.
As stand alone, all of my 50 LEDs are blinking properly. As well in xbmc, if I use the export file - all is looking good.
Havent mounted the LED on TV, but RGB-Test was looking fine.
However, I like to use the boblightd which was made because of "my" request.
Big thanks to QoolBox and the Guys who supported him to do this:
http://www.positiv-it.fr/thecus/download....0_x64.rar
-> This is a boblightd for Thecus NAS Systems
After giving xbmc the NAS IP, the connection to boblightd was succesfull.
But... nothing happens and I have no idea why.
Following my boblight.conf:
http://pastebin.com/Y8hTLib8
I tried - as well - the correct [device] output, which should be tty.usbmodem621 for the Arduino Uno, shouldn't it...?
As from my understanding, there should be all included to get the connection.
It would be great, if anyone could help me to find what I'm doing wrong.
I'm using a Mac Mini 2010 - OS 10.7.5
(Another problem is, that the Arduino prevents OS startup if it is connected via USB.
If someone would have a tweak for this, it would be great...!)
Thank you very much for your support.
Edit: I'm using Frodo 12.3.
Please let me know, if you need any other information/logs.
Haven't added this, because I thought all is related to boblightd...
Would be glad, if someone could help
I guess the nas is linux based and you have some sort of shell access to it (ssh?).
Plugin in the arduino and do "dmesg" ... this should tell you how the device is called. If it is linux based it should be definitly prefixed with "/dev/" ... e.x. "/dev/tty.usbmodem621". But first you need to be sure how the device is called. It might even be that drivers for the arduino are missing on the nas.
