2014-02-07, 17:05
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
2014-02-10, 19:11
2014-02-10, 22:12
(2014-02-10, 19:11)bry- Wrote: [ -> ](2014-01-16, 19:42)teeedubb Wrote: [ -> ]Sorry man, my script will be of no use then.
@teeedubb - you have info on the script. I have a buddy with OE that would like to try and use it.
is it possible to only have the lights on when media is playing?
To turn boblight off and on via remote?
Try this:
toggle_boblight_service.py (place in preferred folder)
import xbmc
cmd = '{"jsonrpc": "2.0", "method": "Addons.SetAddonEnabled", '
cmd += '"params": { "addonid": "script.xbmc.boblight", "enabled": "toggle" }, "id": 1}'
Keymap entry:
<hash>RunScript(special://profile/scripts/toggle_boblight_service.py)</hash>
2014-02-11, 09:26
(2014-02-06, 20:10)soder Wrote: [ -> ]Great.
But I think it's possible to have non distracting settings even with about 15% grab at the edges.
My settings now are great I think. :-)
/Söder
Will try this. If only editing boblight.conf wasnt such a PITA.. Anyone know of a calculator I could use? The one I originally used is no longer online.
(2014-02-10, 19:11)bry- Wrote: [ -> ]@teeedubb - you have info on the script. I have a buddy with OE that would like to try and use it.
#!/bin/bash
export DISPLAY=:0
if [[ ! -f /tmp/boblight.running ]] ; then
if [[ $(pidof xbmc.bin) ]]; then
curl -H "Content-Type: application/json" -v -X POST -d '{"id":1,"jsonrpc":"2.0","method":"GUI.ShowNotification","params":{"title":"Boblight","message":"Enabled","image":"/home/xbmc/.xbmc/addons/script.boblight.launcher/icon.png" }}' http://localhost:9191/jsonrpc
curl -H "Content-Type: application/json" -v -X POST -d '{"jsonrpc": "2.0", "method": "Addons.SetAddonEnabled", "params": { "addonid": "script.xbmc.boblight", "enabled": true }, "id": 1}' http://localhost:9191/jsonrpc
else
notify-send -i /home/xbmc/.xbmc/addons/script.boblight.launcher/icon.png "BOBLIGHT ENABLED "
fi
sudo /usr/bin/.scripts/reset-teensy.sh
echo Boblightd + boblight-X11 NOT running, /tmp/boblight.running NOT found...
echo Turning boblight on.
if [[ $(pidof boblightd) ]]; then
kill $(pidof boblightd)
fi
if [[ $(pidof boblight-X11) ]]; then
kill $(pidof boblight-X11)
fi
sleep 1
kill -9 $(pidof boblightd)
sleep 1
fi
kill -9 $(pidof boblight-X11)
sleep 1
fi
boblightd -f -c /etc/boblight.conf
sleep 4
boblight-X11 -f -x -u 32 -o speed=70 -o value=10 -o saturation=1.0 -o threshold=10 &
touch /tmp/boblight.running
elif [[ ! -f /tmp/boblight-onecolour.running ]] ; then
curl -H "Content-Type: application/json" -v -X POST -d '{"id":1,"jsonrpc":"2.0","method":"GUI.ShowNotification","params":{"title":"Boblight Single-Colour","message":"Enabled","image":"/home/xbmc/.xbmc/addons/script.boblight.launcher/icon.png" }}' http://localhost:9191/jsonrpc
else
notify-send -i /home/xbmc/.xbmc/addons/script.boblight.launcher/icon.png "BOBLIGHT SINGLE-COLOUR ENABLED "
fi
echo Boblightd + boblight-X11 running, /tmp/boblight-onecolour.running NOT found...
echo Turning boblight-onecolour on.
fi
fi
sleep 1
kill 9 $(pidof boblightd)
sleep 1
fi
kill 9 $(pidof boblight-X11)
sleep 1
fi
boblightd -f -c /etc/boblight-onecolour.conf
sleep 4
# boblight-X11 -f -o speed=70 -o value=10 -o saturation=1.0 -o threshold=10 &
touch /tmp/boblight-onecolour.running
else
echo Boblightd + boblight-X11 running, /tmp/boblight* found...
echo Turning boblight off.
curl -H "Content-Type: application/json" -v -X POST -d '{"jsonrpc": "2.0", "method": "Addons.SetAddonEnabled", "params": { "addonid": "script.xbmc.boblight", "enabled": false }, "id": 1}' http://localhost:9191/jsonrpc
curl -H "Content-Type: application/json" -v -X POST -d '{"id":1,"jsonrpc":"2.0","method":"GUI.ShowNotification","params":{"title":"Boblight","message":"Disabled","image":"/home/xbmc/.xbmc/addons/script.boblight.launcher/icon.png" }}' http://localhost:9191/jsonrpc
else
notify-send -i /home/xbmc/.xbmc/addons/script.boblight.launcher/icon.png "BOBLIGHT DISABLED "
fi
fi
fi
sleep 1
sleep 1
fi
sleep 1
fi
rm -f /tmp/boblight.running
rm -f /tmp/boblight-onecolour.running
fi
It works by stopping/starting boblightd + boblight-x11 and will toggle boblight, single colour boblight then off. Ive found that if xbmc-boblight is started first it will have priority over boblight-x11, so xbmc-boblight will work with videos and boblight-x11 will work in fullscreen vis's, menus and external programs such as steam + chrome when xbmc isnt running. You probably need to mod it to suit your needs/OE. Its run via remote by irexec.
(2014-02-10, 22:12)schumi2004 Wrote: [ -> ](2014-02-10, 19:11)bry- Wrote: [ -> ](2014-01-16, 19:42)teeedubb Wrote: [ -> ]Sorry man, my script will be of no use then.
Try this:
Code:import xbmc
Keymap entry:
Code:<hash>RunScript(special://profile/scripts/toggle_boblight_service.py)</hash>
Nice.. The script above gives me loads of boblight error messages in the xbmc.log because the add is still enabled, this should solve it.
2014-02-11, 13:39
(2014-02-11, 09:26)teeedubb Wrote: [ -> ](2014-02-06, 20:10)soder Wrote: [ -> ]Great.
/Söder
Is it really that big pain? When you know you setup, and where the lights are, and how you have placed them on the TV, I find it easy to mod my .conf to grab more or less %.
hscan 75 100
vscan 85 100
Not that hard to make the vscan here to 20% instead of 15%..
I find it more difficult to edit the colors and gamma and "power" to suit just MY "official" Lightpack...
/Söder
2014-02-12, 15:19
2014-02-13, 12:57
This is definitly out of scope of this thread which is about the addon. Sry - but if you need to compile something for raspbian i would say ask in the raspbian forum. Sorry again that i can't support all dozens of 3rd party issues which lead to non working boblight - but at least i have to draw a line somewhere for not even more poluting my free time.
PS: also i am not the auhtor of that speedy1985 thingy - but if his howto doesn't work then better ask him?
2014-02-13, 13:02
Thank you for your support and reply.
Fully understand...
Fully understand...
2014-02-14, 16:47
(2014-01-24, 14:41)soder Wrote: [ -> ]You're right that I should be using 0-25, 25-50, 50-75, 75-100 for hscan for the top bar.(2014-01-24, 02:22)Webbeh Wrote: [ -> ](2014-01-21, 18:05)soder Wrote: [ -> ]Hi! I yesterday got my Lightpack from lightpack.tv and since I use OpenELEC I can't use there Prismatik software, but I have to use the Boblight daemon and addon in XBMC.
Here's the settings I'm using with Lightpack/OpenELEC: http://ericsembrat.com/2014/01/23/lightp...elec-xbmc/
But I see you only use the "default" settings the guy in the blog used? Not for the hscan and vscan, but the colors?
I used the default settings for the colors because they worked properly - I used a YouTube video of backlight testing and it worked as expected. I saw no need to adjust them, as they were working to my satisfaction.
I'll see if I can adjust this post this weekend and send out an update. Thanks!
2014-02-16, 22:29
i'm a noob who trys to run boblight on his RaspberryPi with RaspBMC.
Actually it runs fine, but there is something verry annoying i dont understand...
Sometimes all LEDs fade on (green color) for 3 times in a row without any doings by me. That happens when the RasPi is doing nothing (runs in the background, LEDs are off (black)) as well as i'm watching a movie or listen to music with the RasPi.
The timeintervalls are verry different. Sometimes it dont happens for hours and than it happens every minute.
I have made two videos.
First one: http://youtu.be/J-sDcAEhNn0
Secound one: http://youtu.be/9OTKEnpVpLc
In the secound one, it happens exactly every 24 secounds and this for hours! Not even a reboot fixed it, i had to import a backup...Now it still happens, but not as often as in the scound video.
How can i stop it? Are there any settings for it?
greetings
greetings
2014-02-22, 11:03
hey guys,
i am about to start my little boblight/adalight project (60" 100-150 LEDs) but before i start i got a few (n00b) questions. i hope someone can help me in the case
there are a lot of tutorials regarding boblight - arduino - xbmc on the internet. all of them are based on windows. my HTPC will run xbmcbuntu. can i configurate the arduino from my windows desktop pc and later just plug it into the HTPC (XBMCBuntu + addon) ?
2014-02-22, 12:28
Hey
I;m usuing this addon for a year by now,,,
SUDDENLY when i run XBMC i get:
boblight script failed!
this is the log part:
tried to install\reinstall boblight xbmc but no success
the LEDS are ws2801 with arduino uno, connected to windows 7 and xbmc 12.3\gotham (doesnt work with both)
THANKS
12:25:23 T:2272 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeEncodeError'>
Error Contents: 'ascii' codec can't encode characters in position 32-36: ordinal not in range(128)
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.xbmc.boblight\default.py", line 237, in <module>
run_boblight()
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.xbmc.boblight\default.py", line 200, in run_boblight
if not main.connectBoblight():
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.xbmc.boblight\default.py", line 111, in connectBoblight
xbmc.executebuiltin("XBMC.Notification(%s,%s,%s,%s)" % (__scriptname__,text,750,__icon__))
UnicodeEncodeError: 'ascii' codec can't encode characters in position 32-36: ordinal not in range(128)
12:25:24 T:1628 NOTICE: Thread FileCache start, auto delete: false
12:25:32 T:4580 NOTICE: Previous line repeats 10 times.
THANKS
2014-02-22, 12:49
try this version please
https://dl.dropboxusercontent.com/u/7435...7-test.zip
and does the notification text look wrong afterwards with this version?
2014-02-23, 00:13
I have to Report, that I also use Boblight for year on XBMC.
Since the last update this week - the lights are constant in the standby Color I set.
When playing movies nothing happens.
Please tell me where can I download the bugfree previous Version - without lights watching movies isn`t fun.
GreeT`s eRich
GreeT`s eRich
2014-02-23, 00:14
I hope it is OK that I ask here.
I have 2 lightpacks that I wan't to get working with boblight
I haven't installed any libraries for the prismatik,
meaning only boblight/d is installed, and the according libraries.
this is my config
I have only inserted 1 LED strip for LP2 (I am adding 1 by 1)
but, when I start boblightd, LP2 is not showing anything, and looking at the debug, it is like it is adding and throwing the connection for both LP1 and LP2 again and again (I only took a snippet of the log..)
Well, I can get LP1 working, so I am thinking that it is OK, that I haven't installed prismatik, or any libraries.
I have used the prismatik, and both lightpacks are working, I just didn't like how prismatik worked.
Have anyone experienced anything like this in their quest of using boblight with lightpack..? thanks
this is my config
[global]
[device]
name LP1
channels 30
type lightpack
interval 20000
#bus 2
#address 4
serial 95230303231351C020B1
[device]
name LP2
channels 30
type lightpack
interval 20000
#bus 2
#address 5
serial 95230303231351E0F1C1
[color]
name red
rgb FF0000
gamma 1.6
adjust 1.0
blacklevel 0.0
[color]
name grn
rgb 0000FF
gamma 1.6
adjust 1.0
blacklevel 0.0
[color]
name blu
rgb 00FF00
gamma 1.6
adjust 1.0
blacklevel 0.0
[light]
name L01
color red LP1 1
color blu LP1 2
color grn LP1 3
hscan 83 100
vscan 75 100
[light]
name L02
color red LP1 4
color blu LP1 5
color grn LP1 6
hscan 83 100
vscan 75 100
[light]
name L03
color red LP1 7
color blu LP1 8
color grn LP1 9
hscan 83 100
vscan 50 75
[light]
name L04
color red LP1 10
color blu LP1 11
color grn LP1 12
hscan 67 83
vscan 75 100
[light]
name L05
color red LP1 13
color blu LP1 14
color grn LP1 15
hscan 50 67
vscan 75 100
[light]
name L06
color red LP1 16
color blu LP1 17
color grn LP1 18
hscan 83 100
vscan 25 50
[light]
name L07
color red LP1 19
color blu LP1 20
color grn LP1 21
hscan 83 100
vscan 0 25
[light]
name L08
color red LP1 22
color blu LP1 23
color grn LP1 24
hscan 83 100
vscan 0 25
[light]
name L09
color red LP1 25
color blu LP1 26
color grn LP1 27
hscan 67 83
vscan 0 25
[light]
name L10
color red LP1 28
color blu LP1 29
color grn LP1 30
hscan 50 67
vscan 0 25
[light]
name L11
color red LP2 1
color blu LP2 2
color grn LP2 3
hscan 50 67
vscan 0 25
(CDeviceLightpack::SetupDevice) LP2: found Lightpack at bus 2 address 4, serial is 95230303231351E0F1C1
(CDevice::Process) LP2: setup succeeded
(CDevice::Process) LP1: closed
(CDevice::Process) LP1: setting up
(CDeviceLightpack::SetupDevice) LP1: found Lightpack at bus 2 address 3, serial is 95230303231351C020B1
(CDeviceLightpack::SetupDevice) LP1: Lightpack is initialized, bus 2 device address 3
(CDeviceLightpack::SetupDevice) LP1: found Lightpack at bus 2 address 4, serial is 95230303231351E0F1C1
(CDevice::Process) LP1: setup succeeded
(CDevice::Process) LP2: closed
(CDevice::Process) LP2: setting up
(CDeviceLightpack::SetupDevice) LP2: found Lightpack at bus 2 address 3, serial is 95230303231351C020B1
(CDeviceLightpack::SetupDevice) LP2: Lightpack is initialized, bus 2 device address 3
(CClientsHandler::ParseSet) 127.0.0.1:42039 priority set to 255
^C(SignalHandler) caught SIGINT
(CClientsHandler::GetReadableFd)select() Interrupted system call
(main) signaling devices to stop
(CClientsHandler::Cleanup) disconnecting clients
(CClientsHandler::RemoveClient) removing 127.0.0.1:42039
(CClientsHandler::Cleanup) closing listening socket
(CClientsHandler::Cleanup) clients handler stopped
(main) waiting for devices to stop
(CDevice::Process) LP2: stopped
(CDevice::Process) LP1: stopped
(main) exiting
