(2014-03-01, 01:16)nickr Wrote: [ -> ]What device is your lightpack?
It is a lightpack from woodenshark. I am getting the unknown device error.
Edit: After further investigation it appears I did not compile the library for boblight. I don't know how to do this on my build though as it is an mx Linux build for an android set top box. I will investigate but if anyone has a mygica atv520 and knows how to install a library that would be greatly appreciated.
Please ensure that you really specified some settings for those custom categories. I verified it a dozens of times and it works for me like it should.
(2014-03-05, 13:52)Memphiz Wrote: [ -> ]Please ensure that you really specified some settings for those custom categories. I verified it a dozens of times and it works for me like it should.
Hi, I can confirm that. In previous versions blank values worked like something were filled. I think, that wasn't a feature, that was a little bug. Probably developer (meant you
) could have no issues here, because he knows that something should be filled
(2014-03-05, 09:44)baseofdrum Wrote: [ -> ]same here
Just try to read the first post and set that parameters, that you'll find suitable for your device. For my lightpack normal are: saturation - up to 10 (for music - 20), value - 0.6 (pretty close to wall), threshold - 10 (just as recommended)
The purpose of custom ist to have custom settings - What did you think? *wonders* - if it worked before - it was a bug indeed - the Default custom values are zeroed ...
i tried on custom to set only the speed , the rest was 0 - it was on tv shows.
then i tried to add saturation between 0 - 10.
i also tried to add or remove the other values - but always the same.
the lights going off when i start the tv show. Don't know what i'm doing wrong.
of course on slow or fast everything working fine, so i just let it as it is
look in the
debug log (wiki) - it prints out the boblight values - use the values from e.x. "fast" and set them in a custom category. If you still get a black boblight then i wanna see that
debug log (wiki)
just search the log for "boblight" to find the relevant printouts.
Just FYI--I saw your response in the bug tracker, but I haven't had time to mess with the setup and get you a debug log. But yes, the values are not "zeroed." In fact, I've just tried all the settings I had set in the Music Videos category in the others. Same results everytime. The only custom setting that works on my setup is the one I set in Music Videos.
I will work on getting you a debug log in the next couple of days. Thanx for being so responsive!
OK--I think I just figured out the problem. Looking at the xbmc debug log, I see that whenever I switch to the TV Shows custom settings, it thinks the saturation setting is "0.0" But when I look at ~/userdata/addon_data/script.xbmc.boblight/settings.xml, that file contains the proper saturation setting of "1.1" I'm not sure why it only seems to get the musicvideo custom setting right but not the others.
Debug Log File:
http://www.xbmclogs.com/show.php?id=144479
My settings.xml:
http://www.xbmclogs.com/show.php?id=145799
My boblight.conf:
http://www.xbmclogs.com/show.php?id=145802
The pertinent sections from xbmc.log in debug:
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - start
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - PlayerChanged(start)
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - handleCategory(tvshow)
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - handleGlobalSettings
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - setupForTVShow
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed saturation to 0.0 ret: True
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed value to 0.0 ret: True
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed speed to 100.0 ret: True
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed autospeed to 0.0 ret: True
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed interpolation to 0 ret: True
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed threshold to 0.0 ret: True
01:37:22 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - handleStaticBgSettings
And the correct settings whenever I set to musicvideo:
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - start
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - PlayerChanged(start)
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - handleCategory(musicvideo)
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - handleGlobalSettings
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - setupForMusicVideo
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed saturation to 1.1 ret: True
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed value to 1.0 ret: True
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed speed to 60.0 ret: True
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed autospeed to 0.0 ret: True
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed interpolation to 0 ret: True
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - changed threshold to 30.0 ret: True
01:37:29 T:140279923332864 DEBUG: ### [XBMC Boblight] - settings() - handleStaticBgSettings
debug log (wiki) (means enable debugging!) - also post logs to patebin.com and put the link in here.
can someone please help me with 3D films (SBS) while using boblight and xbmc (frodo or gotham)? thx!
(2014-03-07, 11:59)Memphiz Wrote: [ -> ]debug log (wiki) (means enable debugging!) - also post logs to patebin.com and put the link in here.
I edited my original message once I figured it out. The link is there and also on the GitHub Issue Tracker.
Please edit your Post and move it all to pastebin.com - it's horrible to view on a phone as it is now...
(2014-03-08, 12:42)Memphiz Wrote: [ -> ]Please edit your Post and move it all to pastebin.com - it's horrible to view on a phone as it is now...
Nevermind. I just got it all to work. I think the defaults for all the values in custom should be set to something other than zero. I missed setting the value setting in the other custom setups eventhough I copied (and missed) the the value setting in the settings.xml file.
Thanx for the help.
