Full Version: [RELEASE] Official XBMC boblight Addon
Should work if I understood koying correctly.
But I can't get boblightd to work for me Sad
http://xbmclogs.com/pzqvxl8pw
Kodi Boblight] - connection to boblightd failed: SO_ERROR 127.0.0.1:19333 Connection refused
- you know about boblightd and stuff like that? ^^
so question for those running windows + lightpack.tv setup. can you determine the FPS you are getting? Using prismatik i am getting around 15-25 fps.
(2016-01-22, 16:15)Memphiz Wrote: [ -> ]
Well not much as I used hyperion back on the pi. But your first post says it should install itself on the first run of boblight.
that is libboblight which is the client part (and as of your log was loaded fine already) - but you also need a boblightd (daemon/server) running in your network somewhere (it must be where the leds are physically connected to)...
Only openelec provides a boblightd addon afaik - but thats oe specific. Normally installing and configuring boblightd is in the scope of the admin...
Reading my first post again i have this topic covered and made it clear that the addon is only the client...
Hi, I have another question. Since i installed Boblight i experience stuttering and skipping when watching HD material. That was not the case before i used boblight. That led me to this post by memphiz:
(2013-01-31, 16:51)F0x123 Wrote: [ -> ]I thought as no HD content is stuttering without boblight that the Radeon HD 6310 is fast enough and the boblight calculation is done by the CPU.
(2013-01-31, 18:03)Memphiz Wrote: [ -> ]The problem is shrinking and grabbing the frames from the GPU - this stalls to gl/les pipeline and makes it stutter (at least on low power gpu.
My hardware is an AMD A6-3500 APU with a built-in Radeon HD 6530D.
Enough GPU power for smooth playback, but apparently not enough for playback and frame grabbing by boblight.
My question now is, what GPU Card is recommended for running boblight?
Which cards are the minimum? Any special recommendations? Should be futureproof if possible.
I want to stay on Linux, if that matters for the decision.
Thanks in advance!
(2016-01-23, 16:08)Memphiz Wrote: [ -> ]that is libboblight which is the client part (and as of your log was loaded fine already) - but you also need a boblightd (daemon/server) running in your network somewhere (it must be where the leds are physically connected to)...
I think I was confused by the boblight.so
Somehow thought that it would be the same as the boblightd.
Quote:For this addon to be working you need a library for communicating with the boblightd - daemon. It should get automagically downloaded for you on the first run of the addon for Windows and OSX.
So I'm probably out of luck as I can't run boblightd on Android.
i run the daemon on my openwrt router which has the leds connected via usb2rs232 converter for example...
(2016-01-23, 21:52)cirkator Wrote: [ -> ]Hi, I have another question. Since i installed Boblight i experience stuttering and skipping when watching HD material. That was not the case before i used boblight. That led me to this post by memphiz:
Thanks in advance!
Nobody?
Just wanted to say that after switching to openelec 6.0.1 I have no framedrops when running boblightd.
Saw posts from people running weaker hardware then mine with no problems and that made me suspicious.
Well in my case, boblight client with Kodi with an hyperiond server on another host : frame drops constantly (about half of 24 frames, enough to be unwatchable) on HD content, while using a Braswell Intel NUC on OE 6.0.1.
Sometimes solved only by rewinding/fast forwarding a couple of times, sometimes not, even on the same media. Hard to troubleshoot in that case.
Same drops with hyperion kodi plugin.
hi all !
long time since i didn't use my boblight setup, so i've decided to put it on again!
so far connexion are ok, i use 2x25 ws2801 strand
i use a arduino uno with this code:
// Arduino "bridge" code between host computer and WS2801-based digital
// RGB LED pixels (e.g. Adafruit product ID #322).  Intended for use
// with USB-native boards such as Teensy or Adafruit 32u4 Breakout;
// works on normal serial Arduinos, but throughput is severely limited.
// LED data is streamed, not buffered, making this suitable for larger
// installations (e.g. video wall, etc.) than could otherwise be held
// in the Arduino's limited RAM.
// Some effort is put into avoiding buffer underruns (where the output
// side becomes starved of data).  The WS2801 latch protocol, being
// delay-based, could be inadvertently triggered if the USB bus or CPU
// is swamped with other tasks.  This code buffers incoming serial data
// and introduces intentional pauses if there's a threat of the buffer
// draining prematurely.  The cost of this complexity is somewhat
// reduced throughput, the gain is that most visual glitches are
// avoided (though ultimately a function of the load on the USB bus and
// host CPU, and out of our control).
// LED data and clock lines are connected to the Arduino's SPI output.
// On traditional Arduino boards, SPI data out is digital pin 11 and
// clock is digital pin 13.  On both Teensy and the 32u4 Breakout,
// data out is pin B2, clock is B1.  LEDs should be externally
// powered -- trying to run any more than just a few off the Arduino's
// 5V line is generally a Bad Idea.  LED ground should also be
// connected to Arduino ground.
//   This file is part of Adalight.
//   Adalight is free software: you can redistribute it and/or modify
//   it under the terms of the GNU Lesser General Public License as
//   published by the Free Software Foundation, either version 3 of
//   the License, or (at your option) any later version.
//   Adalight is distributed in the hope that it will be useful,
//   but WITHOUT ANY WARRANTY; without even the implied warranty of
//   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//   GNU Lesser General Public License for more details.
//   You should have received a copy of the GNU Lesser General Public
//   License along with Adalight.  If not, see
//   <http://www.gnu.org/licenses/>.
#include <SPI.h>
// LED pin for Adafruit 32u4 Breakout Board:
//#define LED_DDR  DDRE
//#define LED_PORT PORTE
//#define LED_PIN  _BV(PORTE6)
// LED pin for Teensy:
//#define LED_DDR  DDRD
//#define LED_PORT PORTD
//#define LED_PIN  _BV(PORTD6)
// LED pin for Arduino:
#define LED_DDR  DDRB
#define LED_PORT PORTB
#define LED_PIN  _BV(PORTB5)
// A 'magic word' (along with LED count & checksum) precedes each block
// of LED data; this assists the microcontroller in syncing up with the
// host-side software and properly issuing the latch (host I/O is
// likely buffered, making usleep() unreliable for latch).  You may see
// an initial glitchy frame or two until the two come into alignment.
// The magic word can be whatever sequence you like, but each character
// should be unique, and frequent pixel values like 0 and 255 are
// avoided -- fewer false positives.  The host software will need to
// generate a compatible header: immediately following the magic word
// are three bytes: a 16-bit count of the number of LEDs (high byte
// first) followed by a simple checksum value (high byte XOR low byte
// XOR 0x55).  LED data follows, 3 bytes per LED, in order R, G, B,
// where 0 = off and 255 = max brightness.
static const uint8_t magic[] = {'A','d','a'};
#define MAGICSIZE  sizeof(magic)
#define HEADERSIZE (MAGICSIZE + 3)
#define MODE_HEADER 0
#define MODE_HOLD   1
#define MODE_DATA   2
// If no serial data is received for a while, the LEDs are shut off
// automatically.  This avoids the annoying "stuck pixel" look when
// quitting LED display programs on the host computer.
static const unsigned long serialTimeout = 15000; // 15 seconds
void setup()
  // Dirty trick: the circular buffer for serial data is 256 bytes,
  // and the "in" and "out" indices are unsigned 8-bit types -- this
  // much simplifies the cases where in/out need to "wrap around" the
  // beginning/end of the buffer.  Otherwise there'd be a ton of bit-
  // masking and/or conditional code every time one of these indices
  // needs to change, slowing things down tremendously.
  uint8_t
    buffer[256],
    indexIn       = 0,
    indexOut      = 0,
    mode          = MODE_HEADER,
    hi, lo, chk, i, spiFlag;
  int16_t
    bytesBuffered = 0,
    hold          = 0,
    c;
  int32_t
    bytesRemaining;
  unsigned long
    startTime,
    lastByteTime,
    lastAckTime,
    t;
  LED_DDR  |=  LED_PIN; // Enable output for LED
  LED_PORT &= ~LED_PIN; // LED off
  Serial.begin(115200); // Teensy/32u4 disregards baud rate; is OK!
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(SPI_MODE0);
  SPI.setClockDivider(SPI_CLOCK_DIV16); // 1 MHz max, else flicker
  // Issue test pattern to LEDs on startup.  This helps verify that
  // wiring between the Arduino and LEDs is correct.  Not knowing the
  // actual number of LEDs connected, this sets all of them (well, up
  // to the first 25,000, so as not to be TOO time consuming) to red,
  // green, blue, then off.  Once you're confident everything is working
  // end-to-end, it's OK to comment this out and reprogram the Arduino.
  uint8_t testcolor[] = { 0, 0, 0, 255, 0, 0 };
  for(char n=3; n>=0; n--) {
    for(c=0; c<25000; c++) {
      for(i=0; i<3; i++) {
        for(SPDR = testcolor[n + i]; !(SPSR & _BV(SPIF)); );
    delay(1); // One millisecond pause = latch
  Serial.print("Ada\n"); // Send ACK string to host
  startTime    = micros();
  lastByteTime = lastAckTime = millis();
  // loop() is avoided as even that small bit of function overhead
  // has a measurable impact on this code's overall throughput.
  for(;;) {
    // Implementation is a simple finite-state machine.
    // Regardless of mode, check for serial input each time:
    t = millis();
    if((bytesBuffered < 256) && ((c = Serial.read()) >= 0)) {
      buffer[indexIn++] = c;
      bytesBuffered++;
      lastByteTime = lastAckTime = t; // Reset timeout counters
    } else {
      // No data received.  If this persists, send an ACK packet
      // to host once every second to alert it to our presence.
      if((t - lastAckTime) > 1000) {
        lastAckTime = t; // Reset counter
      // If no data received for an extended time, turn off all LEDs.
      if((t - lastByteTime) > serialTimeout) {
        for(c=0; c<32767; c++) {
          for(SPDR=0; !(SPSR & _BV(SPIF)); );
        lastByteTime = t; // Reset counter
    switch(mode) {
     case MODE_HEADER:
      // In header-seeking mode.  Is there enough data to check?
      if(bytesBuffered >= HEADERSIZE) {
        // Indeed.  Check for a 'magic word' match.
        for(i=0; (i<MAGICSIZE) && (buffer[indexOut++] == magic[i++]););
        if(i == MAGICSIZE) {
          // Magic word matches.  Now how about the checksum?
          hi  = buffer[indexOut++];
          lo  = buffer[indexOut++];
          chk = buffer[indexOut++];
          if(chk == (hi ^ lo ^ 0x55)) {
            // Checksum looks valid.  Get 16-bit LED count, add 1
            // (# LEDs is always > 0) and multiply by 3 for R,G,B.
            bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L);
            bytesBuffered -= 3;
            spiFlag        = 0;         // No data out yet
            mode           = MODE_HOLD; // Proceed to latch wait mode
          } else {
            // Checksum didn't match; search resumes after magic word.
            indexOut  -= 3; // Rewind
        } // else no header match.  Resume at first mismatched byte.
        bytesBuffered -= i;
      break;
     case MODE_HOLD:
      // Ostensibly "waiting for the latch from the prior frame
      // to complete" mode, but may also revert to this mode when
      // underrun prevention necessitates a delay.
      if((micros() - startTime) < hold) break; // Still holding; keep buffering
      // Latch/delay complete.  Advance to data-issuing mode...
      mode      = MODE_DATA; // ...and fall through (no break):
     case MODE_DATA:
      while(spiFlag && !(SPSR & _BV(SPIF))); // Wait for prior byte
      if(bytesRemaining > 0) {
        if(bytesBuffered > 0) {
          SPDR = buffer[indexOut++];   // Issue next byte
          bytesBuffered--;
          bytesRemaining--;
          spiFlag = 1;
        // If serial buffer is threatening to underrun, start
        // introducing progressively longer pauses to allow more
        // data to arrive (up to a point).
        if((bytesBuffered < 32) && (bytesRemaining > bytesBuffered)) {
          hold      = 100 + (32 - bytesBuffered) * 10;
          mode      = MODE_HOLD;
      } else {
        // End of data -- issue latch:
        hold       = 1000;        // Latch duration = 1000 uS
        LED_PORT  |= LED_PIN;     // LED on
        mode       = MODE_HEADER; // Begin next header search
    } // end switch
  } // end for(;;)
void loop()
  // Not used.  See note in setup() function.
at this time, when i power on the arduino the 50 leds show RGB on startup, so wiring is ok.
i use a asrock ion330 as htpc with openelec, I've installed boblight demon and kodi boblight addons.
here is my boblight conf file:
[global]
timeout         20
interface       127.0.0.1
port            19333
interpolation   on
proportional    100.0
saturation      1.5
value           1.2
valuerange      0.0 1.0
use             yes
method          average
threshold       10
[device]
name            ambilight
type            atmo
output          /dev/ttyACM0
rate            115200
channels        150
interval        20000
prefix          41 64 61 00 18 4D
[color]
name            red
rgb             FF0000
gamma           1.0
adjust          1.0
blacklevel      0.0
[color]
name            green
rgb             00FF00
gamma           1.0
adjust          1.0
blacklevel      0.0
[color]
name            blue
rgb             0000FF
gamma           1.0
adjust          1.0
blacklevel      0.0
[light]
name    Right_9
color    red        ambilight 1
color    green    ambilight 2
color    blue    ambilight 3
hscan    85 100
vscan    88.88 100
[light]
name    Right_8
color    red        ambilight 4
color    green    ambilight 5
color    blue    ambilight 6
hscan    85 100
vscan    77.77 88.88
[light]
name    Right_7
color    red        ambilight 7
color    green    ambilight 8
color    blue    ambilight 9
hscan    85 100
vscan    66.66 77.77
[light]
name    Right_6
color    red        ambilight 10
color    green    ambilight 11
color    blue    ambilight 12
hscan    85 100
vscan    55.55 66.66
[light]
name    Right_5
color    red        ambilight 13
color    green    ambilight 14
color    blue    ambilight 15
hscan    85 100
vscan    44.44 55.55
[light]
name    Right_4
color    red        ambilight 16
color    green    ambilight 17
color    blue    ambilight 18
hscan    85 100
vscan    33.33 44.44
[light]
name    Right_3
color    red        ambilight 19
color    green    ambilight 20
color    blue    ambilight 21
hscan    85 100
vscan    22.22 33.33
[light]
name    Right_2
color    red        ambilight 22
color    green    ambilight 23
color    blue    ambilight 24
hscan    85 100
vscan    11.11 22.22
[light]
name    Right_1
color    red        ambilight 25
color    green    ambilight 26
color    blue    ambilight 27
hscan    85 100
vscan    0 11.11
[light]
name    Top_16
color    red        ambilight 28
color    green    ambilight 29
color    blue    ambilight 30
hscan    93.75 100
vscan    0 15
[light]
name    Top_15
color    red        ambilight 31
color    green    ambilight 32
color    blue    ambilight 33
hscan    87.5 93.75
vscan    0 15
[light]
name    Top_14
color    red        ambilight 34
color    green    ambilight 35
color    blue    ambilight 36
hscan    81.25 87.5
vscan    0 15
[light]
name    Top_13
color    red        ambilight 37
color    green    ambilight 38
color    blue    ambilight 39
hscan    75 81.25
vscan    0 15
[light]
name    Top_12
color    red        ambilight 40
color    green    ambilight 41
color    blue    ambilight 42
hscan    68.75 75
vscan    0 15
[light]
name    Top_11
color    red        ambilight 43
color    green    ambilight 44
color    blue    ambilight 45
hscan    62.5 68.75
vscan    0 15
[light]
name    Top_10
color    red        ambilight 46
color    green    ambilight 47
color    blue    ambilight 48
hscan    56.25 62.5
vscan    0 15
[light]
name    Top_9
color    red        ambilight 49
color    green    ambilight 50
color    blue    ambilight 51
hscan    50 56.25
vscan    0 15
[light]
name    Top_8
color    red        ambilight 52
color    green    ambilight 53
color    blue    ambilight 54
hscan    43.75 50
vscan    0 15
[light]
name    Top_7
color    red        ambilight 55
color    green    ambilight 56
color    blue    ambilight 57
hscan    37.5 43.75
vscan    0 15
[light]
name    Top_6
color    red        ambilight 58
color    green    ambilight 59
color    blue    ambilight 60
hscan    31.25 37.5
vscan    0 15
[light]
name    Top_5
color    red        ambilight 61
color    green    ambilight 62
color    blue    ambilight 63
hscan    25 31.25
vscan    0 15
[light]
name    Top_4
color    red        ambilight 64
color    green    ambilight 65
color    blue    ambilight 66
hscan    18.75 25
vscan    0 15
[light]
name    Top_3
color    red        ambilight 67
color    green    ambilight 68
color    blue    ambilight 69
hscan    12.5 18.75
vscan    0 15
[light]
name    Top_2
color    red        ambilight 70
color    green    ambilight 71
color    blue    ambilight 72
hscan    6.25 12.5
vscan    0 15
[light]
name    Top_1
color    red        ambilight 73
color    green    ambilight 74
color    blue    ambilight 75
hscan    0 6.25
vscan    0 15
[light]
name    Left_1
color    red        ambilight 76
color    green    ambilight 77
color    blue    ambilight 78
hscan    0 15
vscan    0 11.11
[light]
name    Left_2
color    red        ambilight 79
color    green    ambilight 80
color    blue    ambilight 81
hscan    0 15
vscan    11.11 22.22
[light]
name    Left_3
color    red        ambilight 82
color    green    ambilight 83
color    blue    ambilight 84
hscan    0 15
vscan    22.22 33.33
[light]
name    Left_4
color    red        ambilight 85
color    green    ambilight 86
color    blue    ambilight 87
hscan    0 15
vscan    33.33 44.44
[light]
name    Left_5
color    red        ambilight 88
color    green    ambilight 89
color    blue    ambilight 90
hscan    0 15
vscan    44.44 55.55
[light]
name    Left_6
color    red        ambilight 91
color    green    ambilight 92
color    blue    ambilight 93
hscan    0 15
vscan    55.55 66.66
[light]
name    Left_7
color    red        ambilight 94
color    green    ambilight 95
color    blue    ambilight 96
hscan    0 15
vscan    66.66 77.77
[light]
name    Left_8
color    red        ambilight 97
color    green    ambilight 98
color    blue    ambilight 99
hscan    0 15
vscan    77.77 88.88
[light]
name    Left_9
color    red        ambilight 100
color    green    ambilight 101
color    blue    ambilight 102
hscan    0 15
vscan    88.88 100
[light]
name    Bottom_1
color    red        ambilight 103
color    green    ambilight 104
color    blue    ambilight 105
hscan    0 6.25
vscan    0 15
[light]
name    Bottom_2
color    red        ambilight 106
color    green    ambilight 107
color    blue    ambilight 108
hscan    6.25 12.5
vscan    0 15
[light]
name    Bottom_3
color    red        ambilight 109
color    green    ambilight 110
color    blue    ambilight 111
hscan    12.5 18.75
vscan    0 15
[light]
name    Bottom_4
color    red        ambilight 112
color    green    ambilight 113
color    blue    ambilight 114
hscan    18.75 25
vscan    0 15
[light]
name    Bottom_5
color    red        ambilight 115
color    green    ambilight 116
color    blue    ambilight 117
hscan    25 31.25
vscan    0 15
[light]
name    Bottom_6
color    red        ambilight 118
color    green    ambilight 119
color    blue    ambilight 120
hscan    31.25 37.5
vscan    0 15
[light]
name    Bottom_7
color    red        ambilight 121
color    green    ambilight 122
color    blue    ambilight 123
hscan    37.5 43.75
vscan    0 15
[light]
name    Bottom_8
color    red        ambilight 124
color    green    ambilight 125
color    blue    ambilight 126
hscan    43.75 50
vscan    0 15
[light]
name    Bottom_9
color    red        ambilight 127
color    green    ambilight 128
color    blue    ambilight 129
hscan    50 56.25
vscan    0 15
[light]
name    Bottom_10
color    red        ambilight 130
color    green    ambilight 131
color    blue    ambilight 132
hscan    56.25 62.5
vscan    0 15
[light]
name    Bottom_11
color    red        ambilight 133
color    green    ambilight 134
color    blue    ambilight 135
hscan    62.5 68.75
vscan    0 15
[light]
name    Bottom_12
color    red        ambilight 136
color    green    ambilight 137
color    blue    ambilight 138
hscan    68.7 75
vscan    0 15
[light]
name    Bottom_13
color    red        ambilight 139
color    green    ambilight 140
color    blue    ambilight 141
hscan    75 81.25
vscan    0 15
[light]
name    Bottom_14
color    red        ambilight 142
color    green    ambilight 143
color    blue    ambilight 144
hscan    81.25 87.5
vscan    0 15
[light]
name    Bottom_15
color    red        ambilight 145
color    green    ambilight 146
color    blue    ambilight 147
hscan    87.5 93.75
vscan    0 15
[light]
name    Bottom_16
color    red        ambilight 148
color    green    ambilight 149
color    blue    ambilight 150
hscan    93.75 100
vscan    0 15
after a restart, all seem to work, for the 25 first leds ...
i've tried some other conf file, changing prefix, etc.
nothing seems to make it work, if i launch a video, it's working, on half screen.
i can't figure out what i've missed here, and hope someone can point me to it .
thx.
addon boblight not working 16.0 RC2 (arm), 16.0 RC3 (arm)
recorded color
boblight works 15.2
Please correct , return the library is responsible for boblight
one of the worst posts i have read since a long time - learn the language before posting for god sake...
hopefully someone can help me.
In the past I used Openelec 5.0.8 on my Xtreamer Ulra and got Boblight working. Working means Openelec used the Boblight-Deamon (boblightd) on my Dreambox7020, the Led-Controller is connected to my Dreambox.
Today I replaced my Xtremer Ultra with a Raspberry Pi2, but unfotunately didnĀ“t get the Lights behind my TV up.
I installed Boblight and boblightd from the repositorys, loaded up my boblight.conf and configured the IP and Port of my Dreambox in the Boblight Client on the Pi2.
Now I eneded up with a non working Boblight configuration on my Pi2. Could someone help me on this or is the Pi2 not able to handle this because of missing X11 functionality.
Did anyone get the boblight addon running on a Pi2 (Openelec)?
rgs
Jan
