thats the log on kodi side. I guess you need to have a look into the log of boblightd then.
Also as a side note. Whenever the extracted color information is not working, then it is not related to the boblight addon but to the platform specific RenderCapture implementation in Kodi core. The addon only does something like "give me the current image data in 64x64 pixels downscaled). Platformspecific code in Kodi core is responsible to deliver that image data. If it doesn't work for you platform - first try to switch off the Hardware Decoding Feature for the Video. (software decoding should give proper access to the image data on all platforms. Its the hardware decoding that needs to be altered for each platform for being able to extract the image data and whenever hardware decoding code is changed in Kodi - its likely that RenderCapture breaks because most devs are not always aware of that interface which is important for boblight only...).
(2016-08-12, 19:10)Blink515 Wrote: [ -> ]Hello,
Been awhile since using my boblight setup and come to find that it is no longer working when a video is played. I have made a few hardware changes and updated to Windows 10 so I'm thinking those things may be to blame.
Boblight connects and shows the startup rainbow then goes to the soft white color that I have it set when not playing videos but when I play a video everything goes black. I enabled debugging in the config file and am seeing that Kodi is throwing all black color codes to boblight.
I can use the Bobdroid app on my phone and set colors and everything just fine so it is definitely related to something with Kodi and playing videos and may not even be the addons fault.
With all of that said, I am using Kodi 16.0 on Windows 10 with the daemon also on the same machine. I upgraded my CPU from an AMD Kaveri to an Intel I5-6600k and have been using the built in graphics chips for both CPUs. I am guessing that the intel graphics drivers don't play nice with however Kodi is getting the video color values.
Thanks in advance for any help or suggestions.
That's so weird. The exact thing happened to me. It started maybe 2 weeks ago, and I haven't been able to figure it out. The only difference is that I haven't made any changes to the hardware...
(2016-08-13, 12:54)Memphiz Wrote: [ -> ]thats the log on kodi side. I guess you need to have a look into the log of boblightd then.
Thank you! Playing around with the "video scaling method" on the OSD video settings fixed it. If I select auto, dxva, or bilinear, the system stops working. If I select anything else, for example "Lanczos3 Optimized", it starts working immediately. I also had to scroll down to the bottom and select "Set as default for all media" to get it to work on new files.
(2016-08-12, 22:09)westcoastbias Wrote: [ -> ]Is there a way to tell what color boblight is currently reading?
For instance, I am not happy when the tv shows a dark blue, boblight usually shows something closer to cyan. If I know what boblight is reading as the color, I can manually change that color in the conf file to something better.
Any ideas? Can I hack the add-on to have it print statements out to the log?
I've tried a few config setups but always come back to this one:
[global]
interface 127.0.0.1
port 19333
[device]
name LP1
channels 30
type lightpack
interval 20000
#bus 1
#address 6
#debug true
[color]
name red
rgb FF0000
gamma 1.6
adjust 1.0
[color]
name grn
rgb 00FF00
gamma 1.6
adjust 1.0
[color]
name blu
rgb 0000FF
gamma 1.6
adjust 1.0
[light]
name L01
color red LP1 1
color grn LP1 2
color blu LP1 3
hscan 80 100
vscan 0 50
[light]
name L02
color red LP1 4
color grn LP1 5
color blu LP1 6
hscan 75 100
vscan 0 20
[light]
name L03
color red LP1 7
color grn LP1 8
color blu LP1 9
hscan 50 75
vscan 0 20
[light]
name L04
color red LP1 10
color grn LP1 11
color blu LP1 12
hscan 80 100
vscan 50 100
[light]
name L05
color red LP1 13
color grn LP1 14
color blu LP1 15
hscan 50 100
vscan 80 100
[light]
name L06
color red LP1 16
color grn LP1 17
color blu LP1 18
hscan 25 50
vscan 0 20
[light]
name L07
color red LP1 19
color grn LP1 20
color blu LP1 21
hscan 0 25
vscan 0 20
[light]
name L08
color red LP1 22
color grn LP1 23
color blu LP1 24
hscan 0 20
vscan 0 50
[light]
name L09
color red LP1 25
color grn LP1 26
color blu LP1 27
hscan 0 20
vscan 50 100
[light]
name L10
color red LP1 28
color grn LP1 29
color blu LP1 30
hscan 0 50
vscan 80 100
(2016-08-14, 06:42)FlatText Wrote: [ -> ] (2016-08-12, 22:09)westcoastbias Wrote: [ -> ]Is there a way to tell what color boblight is currently reading?
[global]
interface 127.0.0.1
port 19333
[device]
name LP1
channels 30
type lightpack
interval 20000
#bus 1
#address 6
#debug true
[color]
name red
rgb FF0000
gamma 1.6
adjust 1.0
[color]
name grn
rgb 00FF00
gamma 1.6
adjust 1.0
[color]
name blu
rgb 0000FF
gamma 1.6
adjust 1.0
[light]
name L01
color red LP1 1
color grn LP1 2
color blu LP1 3
hscan 80 100
vscan 0 50
[light]
name L02
color red LP1 4
color grn LP1 5
color blu LP1 6
hscan 75 100
vscan 0 20
[light]
name L03
color red LP1 7
color grn LP1 8
color blu LP1 9
hscan 50 75
vscan 0 20
[light]
name L04
color red LP1 10
color grn LP1 11
color blu LP1 12
hscan 80 100
vscan 50 100
[light]
name L05
color red LP1 13
color grn LP1 14
color blu LP1 15
hscan 50 100
vscan 80 100
[light]
name L06
color red LP1 16
color grn LP1 17
color blu LP1 18
hscan 25 50
vscan 0 20
[light]
name L07
color red LP1 19
color grn LP1 20
color blu LP1 21
hscan 0 25
vscan 0 20
[light]
name L08
color red LP1 22
color grn LP1 23
color blu LP1 24
hscan 0 20
vscan 0 50
[light]
name L09
color red LP1 25
color grn LP1 26
color blu LP1 27
hscan 0 20
vscan 50 100
[light]
name L10
color red LP1 28
color grn LP1 29
color blu LP1 30
hscan 0 50
vscan 80 100
The amount of edge you are taking there is interesting. Ive seen most files take far less, I will look into it.
My main complaint, is that for very dark scenes, the lights tend to give a blue that is much too light. I dont know if this is a limitation of RGB LEDs or something else. But if I could get into that config file, I could see the color that is being reported by boblight and create a custom color definition that I feel is more appropriate.
Hi! I'm trying to make an ambilight clone based on android kodi with arduino. I put libboblight.so into data/data/... Set the latest version of boblight in kodi, connected arduino to box, it was defund. Where should be boblight.conf? Thank you!
I think i've answered your question on github already. Please continue here in the forums for further requests.
Hi, I've been running Kodi Boblight using Arduino, Kodi and a Windows 10 for a while now. And it seems that after the recent anniversary update my ambilight has broken.
Communication seems to be present ie I get my standby backlight when nothing is playing. But when I start a show or movie the ambilight turns of until I stop playback. I've uninstalled the Kodi Boblight service and reinstalled it but that didn't fix it. I'm hoping it's not related to the boblightd.exe for windows, because that still seems to function without problem.
I'm not sure how to get debug info to you so if you need it, please point me in the right direction
Thanks for the amazing add-on and I'm hoping I can keep using it
I have an issue with the android boblight addon running on the shield tv (boblightd is running remotely on RPi).
While watching a movie/tvshow, the addon only sends a white light (captured via tcpdump on the RPi): "set light light1 rgb 0.48966 0.210018 0.589499" (the command repeats all through the playback).
But while running LiveTV the colors match those on screen: "set light light1 rgb 1 0.499863 0.64334" and then "set light light1 rgb 1 0.499863 0.64334"
Any idea?
P.S. I'm using KODI Krypton beta1 with the latest boblight addon.
Surface render vs software rendering? Do you use mediacodec hw decoder?
It's on default settings -> mediacodec hw is used.
I have no android device - are there any options for different render methods? (Maybe in expert level?)
I have a working 100 LED system running Kodi 16.2, boblight, windows 10. The only problem is the last 4 lights refuse to light up on Kodi. When I test it through Arduino, all light up. When I start Boblightd outside of Kodi they all light up. As soon as I turn on Kodi and connect through the Addon, the last 4 don't work. Very strange. My config file is below. If anyone has any ideas I would love some help. Thanks.
PHP Code:
[global]
interface 127.0.0.1
port 19333
[device]
name AmbiLight
type momo
output /dev/com3
channels 300
prefix 41 64 61 00 5f 0A
interval 20000
rate 115200
debug off
delayafteropen 100000
[color]
name red
rgb FF0000
adjust .9
blacklevel 0
gamma 2.3
[color]
name green
rgb 00FF00
adjust .9
blacklevel 0
gamma 2.3
[color]
name blue
rgb 0000FF
adjust .9
blacklevel 0
gamma 2.3
# Bottom Start
[light]
name start1
color red AmbiLight 1
color green AmbiLight 2
color blue AmbiLight 3
hscan 36.6 40.4
vscan 93 98
[light]
name start2
color red AmbiLight 4
color green AmbiLight 5
color blue AmbiLight 6
hscan 32.7 36.6
vscan 93 98
[light]
name start3
color red AmbiLight 7
color green AmbiLight 8
color blue AmbiLight 9
hscan 28.9 32.7
vscan 93 98
[light]
name start4
color red AmbiLight 10
color green AmbiLight 11
color blue AmbiLight 12
hscan 25 28.9
vscan 93 98
[light]
name start5
color red AmbiLight 13
color green AmbiLight 14
color blue AmbiLight 15
hscan 21.2 25
vscan 93 98
[light]
name start6
color red AmbiLight 16
color green AmbiLight 17
color blue AmbiLight 18
hscan 17.4 21.2
vscan 93 98
[light]
name start7
color red AmbiLight 19
color green AmbiLight 20
color blue AmbiLight 21
hscan 13.5 17.4
vscan 93 98
[light]
name start8
color red AmbiLight 22
color green AmbiLight 23
color blue AmbiLight 24
hscan 9.7 13.5
vscan 93 98
[light]
name start9
color red AmbiLight 25
color green AmbiLight 26
color blue AmbiLight 27
hscan 5.8 9.7
vscan 93 98
[light]
name start10
color red AmbiLight 28
color green AmbiLight 29
color blue AmbiLight 30
hscan 2 5.8
vscan 93 98
# Right Side
[light]
name right1
color red AmbiLight 31
color green AmbiLight 32
color blue AmbiLight 33
hscan 2 7
vscan 93.6 98
[light]
name right2
color red AmbiLight 34
color green AmbiLight 35
color blue AmbiLight 36
hscan 2 7
vscan 89.3 93.6
[light]
name right3
color red AmbiLight 37
color green AmbiLight 38
color blue AmbiLight 39
hscan 2 7
vscan 84.9 89.3
[light]
name right4
color red AmbiLight 40
color green AmbiLight 41
color blue AmbiLight 42
hscan 2 7
vscan 80.5 84.9
[light]
name right5
color red AmbiLight 43
color green AmbiLight 44
color blue AmbiLight 45
hscan 2 7
vscan 76.2 80.5
[light]
name right6
color red AmbiLight 46
color green AmbiLight 47
color blue AmbiLight 48
hscan 2 7
vscan 71.8 76.2
[light]
name right7
color red AmbiLight 49
color green AmbiLight 50
color blue AmbiLight 51
hscan 2 7
vscan 67.5 71.8
[light]
name right8
color red AmbiLight 52
color green AmbiLight 53
color blue AmbiLight 54
hscan 2 7
vscan 63.1 67.5
[light]
name right9
color red AmbiLight 55
color green AmbiLight 56
color blue AmbiLight 57
hscan 2 7
vscan 58.7 63.1
[light]
name right10
color red AmbiLight 58
color green AmbiLight 59
color blue AmbiLight 60
hscan 2 7
vscan 54.4 58.7
[light]
name right11
color red AmbiLight 61
color green AmbiLight 62
color blue AmbiLight 63
hscan 2 7
vscan 50 54.4
[light]
name right12
color red AmbiLight 64
color green AmbiLight 65
color blue AmbiLight 66
hscan 2 7
vscan 45.6 50
[light]
name right13
color red AmbiLight 67
color green AmbiLight 68
color blue AmbiLight 69
hscan 2 7
vscan 41.3 45.6
[light]
name right14
color red AmbiLight 70
color green AmbiLight 71
color blue AmbiLight 72
hscan 2 7
vscan 36.9 41.3
[light]
name right15
color red AmbiLight 73
color green AmbiLight 74
color blue AmbiLight 75
hscan 2 7
vscan 32.5 36.9
[light]
name right16
color red AmbiLight 76
color green AmbiLight 77
color blue AmbiLight 78
hscan 2 7
vscan 28.2 32.5
[light]
name right17
color red AmbiLight 79
color green AmbiLight 80
color blue AmbiLight 81
hscan 2 7
vscan 23.8 28.2
[light]
name right18
color red AmbiLight 82
color green AmbiLight 83
color blue AmbiLight 84
hscan 2 7
vscan 19.5 23.8
[light]
name right19
color red AmbiLight 85
color green AmbiLight 86
color blue AmbiLight 87
hscan 2 7
vscan 15.1 19.5
[light]
name right20
color red AmbiLight 88
color green AmbiLight 89
color blue AmbiLight 90
hscan 2 7
vscan 10.7 15.1
[light]
name right21
color red AmbiLight 91
color green AmbiLight 92
color blue AmbiLight 93
hscan 2 7
vscan 6.4 10.7
[light]
name right22
color red AmbiLight 94
color green AmbiLight 95
color blue AmbiLight 96
hscan 2 7
vscan 2 6.4
# Top
[light]
name top1
color red AmbiLight 97
color green AmbiLight 98
color blue AmbiLight 99
hscan 2 4.7
vscan 2 7
[light]
name top2
color red AmbiLight 100
color green AmbiLight 101
color blue AmbiLight 102
hscan 4.7 7.5
vscan 2 7
[light]
name top3
color red AmbiLight 103
color green AmbiLight 104
color blue AmbiLight 105
hscan 7.5 10.2
vscan 2 7
[light]
name top4
color red AmbiLight 106
color green AmbiLight 107
color blue AmbiLight 108
hscan 10.2 13
vscan 2 7
[light]
name top5
color red AmbiLight 109
color green AmbiLight 110
color blue AmbiLight 111
hscan 13 15.7
vscan 2 7
[light]
name top6
color red AmbiLight 112
color green AmbiLight 113
color blue AmbiLight 114
hscan 15.7 18.5
vscan 2 7
[light]
name top7
color red AmbiLight 115
color green AmbiLight 116
color blue AmbiLight 117
hscan 18.5 21.2
vscan 2 7
[light]
name top8
color red AmbiLight 118
color green AmbiLight 119
color blue AmbiLight 120
hscan 21.2 23.9
vscan 2 7
[light]
name top9
color red AmbiLight 121
color green AmbiLight 122
color blue AmbiLight 123
hscan 23.9 26.7
vscan 2 7
[light]
name top10
color red AmbiLight 124
color green AmbiLight 125
color blue AmbiLight 126
hscan 26.7 29.4
vscan 2 7
[light]
name top11
color red AmbiLight 127
color green AmbiLight 128
color blue AmbiLight 129
hscan 29.4 32.2
vscan 2 7
[light]
name top12
color red AmbiLight 130
color green AmbiLight 131
color blue AmbiLight 132
hscan 32.2 34.9
vscan 2 7
[light]
name top13
color red AmbiLight 133
color green AmbiLight 134
color blue AmbiLight 135
hscan 34.9 37.7
vscan 2 7
[light]
name top14
color red AmbiLight 136
color green AmbiLight 137
color blue AmbiLight 138
hscan 37.7 40.4
vscan 2 7
[light]
name top15
color red AmbiLight 139
color green AmbiLight 140
color blue AmbiLight 141
hscan 40.4 43.1
vscan 2 7
[light]
name top16
color red AmbiLight 142
color green AmbiLight 143
color blue AmbiLight 144
hscan 43.1 45.9
vscan 2 7
[light]
name top17
color red AmbiLight 145
color green AmbiLight 146
color blue AmbiLight 147
hscan 45.9 48.6
vscan 2 7
[light]
name top18
color red AmbiLight 148
color green AmbiLight 149
color blue AmbiLight 150
hscan 48.6 51.4
vscan 2 7
[light]
name top19
color red AmbiLight 151
color green AmbiLight 152
color blue AmbiLight 153
hscan 51.4 54.1
vscan 2 7
[light]
name top20
color red AmbiLight 154
color green AmbiLight 155
color blue AmbiLight 156
hscan 54.1 56.9
vscan 2 7
[light]
name top21
color red AmbiLight 157
color green AmbiLight 158
color blue AmbiLight 159
hscan 56.9 59.6
vscan 2 7
[light]
name top22
color red AmbiLight 160
color green AmbiLight 161
color blue AmbiLight 162
hscan 59.6 62.3
vscan 2 7
[light]
name top23
color red AmbiLight 163
color green AmbiLight 164
color blue AmbiLight 165
hscan 62.3 65.1
vscan 2 7
[light]
name top24
color red AmbiLight 166
color green AmbiLight 167
color blue AmbiLight 168
hscan 65.1 67.8
vscan 2 7
[light]
name top25
color red AmbiLight 169
color green AmbiLight 170
color blue AmbiLight 171
hscan 67.8 70.6
vscan 2 7
[light]
name top26
color red AmbiLight 172
color green AmbiLight 173
color blue AmbiLight 174
hscan 70.6 73.3
vscan 2 7
[light]
name top27
color red AmbiLight 175
color green AmbiLight 176
color blue AmbiLight 177
hscan 73.3 76.1
vscan 2 7
[light]
name top28
color red AmbiLight 178
color green AmbiLight 179
color blue AmbiLight 180
hscan 76.1 78.8
vscan 2 7
[light]
name top29
color red AmbiLight 181
color green AmbiLight 182
color blue AmbiLight 183
hscan 78.8 81.5
vscan 2 7
[light]
name top30
color red AmbiLight 184
color green AmbiLight 185
color blue AmbiLight 186
hscan 81.5 84.3
vscan 2 7
[light]
name top31
color red AmbiLight 187
color green AmbiLight 188
color blue AmbiLight 189
hscan 84.3 87
vscan 2 7
[light]
name top32
color red AmbiLight 190
color green AmbiLight 191
color blue AmbiLight 192
hscan 87 89.8
vscan 2 7
[light]
name top33
color red AmbiLight 193
color green AmbiLight 194
color blue AmbiLight 195
hscan 89.8 92.5
vscan 2 7
[light]
name top34
color red AmbiLight 196
color green AmbiLight 197
color blue AmbiLight 198
hscan 92.5 95.3
vscan 2 7
[light]
name top35
color red AmbiLight 199
color green AmbiLight 200
color blue AmbiLight 201
hscan 95.3 98
vscan 2 7
# Left Side
[light]
name left1
color red AmbiLight 202
color green AmbiLight 203
color blue AmbiLight 204
hscan 93 98
vscan 2 6.4
[light]
name left2
color red AmbiLight 205
color green AmbiLight 206
color blue AmbiLight 207
hscan 93 98
vscan 6.4 10.7
[light]
name left3
color red AmbiLight 208
color green AmbiLight 209
color blue AmbiLight 210
hscan 93 98
vscan 10.7 15.1
[light]
name left4
color red AmbiLight 211
color green AmbiLight 212
color blue AmbiLight 213
hscan 93 98
vscan 15.1 19.5
[light]
name left5
color red AmbiLight 214
color green AmbiLight 215
color blue AmbiLight 216
hscan 93 98
vscan 19.5 23.8
[light]
name left6
color red AmbiLight 217
color green AmbiLight 218
color blue AmbiLight 219
hscan 93 98
vscan 23.8 28.2
[light]
name left7
color red AmbiLight 220
color green AmbiLight 221
color blue AmbiLight 222
hscan 93 98
vscan 28.2 32.5
[light]
name left8
color red AmbiLight 223
color green AmbiLight 224
color blue AmbiLight 225
hscan 93 98
vscan 32.5 36.9
[light]
name left9
color red AmbiLight 226
color green AmbiLight 227
color blue AmbiLight 228
hscan 93 98
vscan 36.9 41.3
[light]
name left10
color red AmbiLight 229
color green AmbiLight 230
color blue AmbiLight 231
hscan 93 98
vscan 41.3 45.6
[light]
name left11
color red AmbiLight 232
color green AmbiLight 233
color blue AmbiLight 234
hscan 93 98
vscan 45.6 50
[light]
name left12
color red AmbiLight 235
color green AmbiLight 236
color blue AmbiLight 237
hscan 93 98
vscan 50 54.4
[light]
name left13
color red AmbiLight 238
color green AmbiLight 239
color blue AmbiLight 240
hscan 93 98
vscan 54.4 58.7
[light]
name left14
color red AmbiLight 241
color green AmbiLight 242
color blue AmbiLight 243
hscan 93 98
vscan 58.7 63.1
[light]
name left15
color red AmbiLight 244
color green AmbiLight 245
color blue AmbiLight 246
hscan 93 98
vscan 63.1 67.5
[light]
name left16
color red AmbiLight 247
color green AmbiLight 248
color blue AmbiLight 249
hscan 93 98
vscan 67.5 71.8
[light]
name left17
color red AmbiLight 250
color green AmbiLight 251
color blue AmbiLight 252
hscan 93 98
vscan 71.8 76.2
[light]
name left18
color red AmbiLight 253
color green AmbiLight 254
color blue AmbiLight 255
hscan 93 98
vscan 76.2 80.5
[light]
name left19
color red AmbiLight 256
color green AmbiLight 257
color blue AmbiLight 258
hscan 93 98
vscan 80.5 84.9
[light]
name left20
color red AmbiLight 259
color green AmbiLight 260
color blue AmbiLight 261
hscan 93 98
vscan 84.9 89.3
[light]
name left21
color red AmbiLight 262
color green AmbiLight 263
color blue AmbiLight 264
hscan 93 98
vscan 89.3 93.6
[light]
name left22
color red AmbiLight 265
color green AmbiLight 266
color blue AmbiLight 267
hscan 93 98
vscan 93.6 98
# Bottom End
[light]
name end1
color red AmbiLight 268
color green AmbiLight 269
color blue AmbiLight 270
hscan 94.2 98
vscan 93 98
[light]
name end2
color red AmbiLight 271
color green AmbiLight 272
color blue AmbiLight 273
hscan 90.3 94.2
vscan 93 98
[light]
name end3
color red AmbiLight 274
color green AmbiLight 275
color blue AmbiLight 276
hscan 86.5 90.3
vscan 93 98
[light]
name end4
color red AmbiLight 277
color green AmbiLight 278
color blue AmbiLight 279
hscan 82.6 86.5
vscan 93 98
[light]
name end5
color red AmbiLight 280
color green AmbiLight 281
color blue AmbiLight 282
hscan 78.8 82.6
vscan 93 98
[light]
name end6
color red AmbiLight 283
color green AmbiLight 284
color blue AmbiLight 285
hscan 75 78.8
vscan 93 98
[light]
name end7
color red AmbiLight 286
color green AmbiLight 287
color blue AmbiLight 288
hscan 71.1 75
vscan 93 98
[light]
name end8
color red AmbiLight 289
color green AmbiLight 290
color blue AmbiLight 291
hscan 67.3 71.1
vscan 93 98
[light]
name end9
color red AmbiLight 292
color green AmbiLight 293
color blue AmbiLight 294
hscan 63.4 67.3
vscan 93 98
[light]
name end10
color red AmbiLight 295
color green AmbiLight 296
color blue AmbiLight 297
hscan 59.6 63.4
vscan 93 98
[light]
name end11
color red AmbiLight 298
color green AmbiLight 299
color blue AmbiLight 300
hscan 55.8 59.6
vscan 93 98
