tricky2lu Wrote:log is here
http://pastebin.com/hJntRzys
That's not much of a log you have there. If you're getting error trying to install newer zip over the old one on atv2, this might help:
1. Uninstall the old version.
2. From packages folder inside addons folder, delete plugin.video.snagfilms.zip.
3. Restart XBMC.
4. Install the new zip file.
Hi, I tried installing the latest plugin on my original XBox running a pretty recent nightly of XBMC and the script wouldn't load.
Here's the log with debugging:
http://pastebin.com/2x2wwekT
I'd love to get this working on the XBOX!
Roti2000 Wrote:Hi, I tried installing the latest plugin on my original XBox running a pretty recent nightly of XBMC and the script wouldn't load.
Unfortunately, I don't know anything about the XBOX filesystem and how it works.
Quote:ERROR: Unable to load: special://home/plugins/video/plugin.video.snagfilms/resources/settings.xml, Line 0
Failed to open file
Could it be a permissions problem?
Quote:ERROR: Python script "Q:\plugins\video\plugin.video.snagfilms\default.py" does not exist
Why is the filepath different from above? I have no idea. Maybe some code required for Xbox compatibility missing in the addon? Maybe some XBox expert can chime in.
I installed version 0.0.1 accidentally and now it will not upgrade to 0.0.5. I tried uninstalling it and to my surprise it is not even in the list after I select Get More... How is this possible and does anyone know how I can manually uninstall this add-on?
carnt get it to work on me ipad 2 script error any ideas ?
For script errors, xbmc.log is required. No way to guess what error you're getting.
can u plz tell me how i would get the log very new 2 all this but catch on very quick
