Full Version: Mixcloud plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
Thanks for this great addon
I accidentally activated the plugin with the activation code while logged in to my secondary Mixcloud account. Want to switch it to my main account, but cannot see how? Un- and re-installed but the activation code seems to be remembered (KODI on RPi). How can I change the activation code to link it to my main account?
(2017-12-29, 19:23)SlimPvC Wrote: [ -> ]Thanks for this great addon
You have to do it manually.
Go to the user folder C:\Users\<YOUR_USER>\AppData\Roaming\Kodi\userdata\addon_data\plugin.audio.mixcloud and open the file settings.xml.
Remove "access_token" and "oath_code" entries.
(2018-01-01, 22:15)jackyNIX Wrote: [ -> ]
Thanks for your answer. This seems to refer to a Windows-location? This particular addon is installed on a Raspberry Pi 3 (as part of Kodi/Max2play package), which is not Windows, so I don't know if this folder is available there (and I have approach it using SSH which I'm not very familiar with).
try: /home/pi/.kodi/userdata/addon_data/plugin.audio.mixcloud
fyi: current beta version (2.3.0) has a logoff function build in Smile
You can find the download link in the OP, it remains uncertain when it's going to be added to the official kodi repo.
Sounds like a good option, thanks!
this worked for me - thanks for your support!!
i am not receiving my authentication codeHuh
pls helpHuhHuhHuh
(2018-03-02, 08:09)zmaritz Wrote: [ -> ]i am not receiving my authentication codeHuh
pls helpHuhHuhHuh
 Just tested and it still works for me.
At which point is it going wrong for you? howto
The code is in the url...
hi, I have a Big problem from  2018/01/01 osmci update: every time I select a song from addon (every song) my raspi2 reply "one or more item failed ......".
I use your plugin for at least 2 year without problems. I wait new update, but no resolution. I made a frsh install with only mixcloud addon, and same error. I see my account, preferite etcetera, but only "one or more item failed ......".
logfile (the final part)
17:44:21.550 T:1458041600  NOTICE: MIXCLOUD Mode: 0
17:44:21.550 T:1458041600  NOTICE: MIXCLOUD Offset: 0
17:44:21.550 T:1458041600  NOTICE: MIXCLOUD Key:
17:44:21.550 T:1458041600  NOTICE: MIXCLOUD Query:
17:44:21.550 T:1458041600  NOTICE: MIXCLOUD ##########################################################
17:44:22.684 T:1709175552 WARNING: CSkinInfo: failed to load skin settings
17:44:32.827 T:1458041600  NOTICE: MIXCLOUD ##########################################################
17:44:32.827 T:1458041600  NOTICE: MIXCLOUD Mode: 15
17:44:32.827 T:1458041600  NOTICE: MIXCLOUD Offset: 0
17:44:32.827 T:1458041600  NOTICE: MIXCLOUD Key:
17:44:32.827 T:1458041600  NOTICE: MIXCLOUD Query:
17:44:32.828 T:1458041600  NOTICE: MIXCLOUD Get cloudcasts http://api.mixcloud.com/jackyNIX/cloudca...0&offset=0
17:44:38.327 T:1405084416  NOTICE: MIXCLOUD ##########################################################
17:44:38.328 T:1405084416  NOTICE: MIXCLOUD Mode: 40
17:44:38.328 T:1405084416  NOTICE: MIXCLOUD Offset: 0
17:44:38.328 T:1405084416  NOTICE: MIXCLOUD Key: /jackyNIX/jackynix-sosn08-one-pigmee-in-the-s%C3%A9par%C3%A9/
17:44:38.328 T:1405084416  NOTICE: MIXCLOUD Query:
17:44:38.328 T:1405084416  NOTICE: MIXCLOUD ##########################################################
17:44:38.328 T:1405084416  NOTICE: MIXCLOUD Resolverid _curr=0 _orig=0
17:44:38.328 T:1405084416  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...par%C3%A9/
17:44:38.328 T:1405084416  NOTICE: MIXCLOUD Link version 2
17:44:44.624 T:1405084416  NOTICE: MIXCLOUD Unable to resolve
17:44:44.624 T:1405084416  NOTICE: MIXCLOUD Cannot solve using current resolver
17:44:44.626 T:1405084416  NOTICE: MIXCLOUD Changing resolver to 1
17:44:44.627 T:1405084416  NOTICE: MIXCLOUD Locally resolving cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...par%C3%A9/
17:44:44.627 T:1405084416  NOTICE: MIXCLOUD Changing resolver to 2
17:44:44.627 T:1405084416  NOTICE: MIXCLOUD Resolving offliberty cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...par%C3%A9/
17:44:44.627 T:1405084416  NOTICE: MIXCLOUD Changing resolver to 3
17:44:44.627 T:1405084416  NOTICE: MIXCLOUD Resolving m4a cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...par%C3%A9/
17:44:44.627 T:1405084416  NOTICE: MIXCLOUD Changing resolver to 4
17:44:44.627 T:1405084416  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...par%C3%A9/
17:44:44.628 T:1405084416  NOTICE: MIXCLOUD Link version 1
17:44:51.037 T:1405084416  NOTICE: MIXCLOUD Unable to resolve
17:44:51.038 T:1405084416  NOTICE: MIXCLOUD Changing resolver to 5
17:44:51.039 T:1405084416  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...par%C3%A9/
17:44:51.039 T:1405084416  NOTICE: MIXCLOUD Link version 2
17:44:57.332 T:1405084416  NOTICE: MIXCLOUD Unable to resolve
17:44:57.333 T:1405084416  NOTICE: MIXCLOUD Stop player
17:44:57.334 T:1925925376   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2FjackyNIX%2Fjackynix-sosn08-one-pigmee-in-the-s%25C3%25A9par%25C3%25A9%2F&user=%2Fjacky
sorry for bad format. it's first time i use a forum
... ah they added CAPTCHA shizzle and things Sad
So for now, this addon is DEAD.
I might come up with something else (or not). We'll see...
Sad
Iam sad
Hope you can work on this project back again.
Thanks very much for one of the coolest addon
I fixed the resolver issue, the plugin is working again Big Grin
You can find download info in the opening post.
All good thanks very much
everything working fine
The official repo should be updated by now, the plugin will update automaticaly.
