Full Version: Mixcloud plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
Pete, I did some more research on the subject.
Apparently Xbian has issues with m4a files, some play and others don't. Not a lot you can do about it, except make sure you're running the very latest Xbian release.
This is a Xbian problem.
Thanks, I'll look into it
Thanks for a great addon that just keeps getting better. My feature request is my account on the main page.Nod
(2015-03-04, 22:25)Oli_Oops Wrote: [ -> ]Thanks for a great addon that just keeps getting better. My feature request is my account on the main page.Nod
What do you mean by "my account"?
The "feed" you get when opening the webpage does not exist in the api. I've searched for it, but it is not there. There IS a "me/feed", but it only gives you what you did, your uploads, your listens, ...
One solution is to recreate that feed by querying the feeds of all your followings, filter and order it by date/time, but that 'll take a while to finish (especially as some people have hundreds of followings, that will take like forever Sleepy ).
If you want to shameless plug your cloudcasts... well, what do you have to offer Rofl
In case other people would stumble on the aforementioned problem:
this might indeed be related to a (temporary) issue with xbian, for almost all streams (eg mixcloud, youtube,...). See: Xbian issue 685 on github
Downgrading or waiting for fix seem to be the only solutions.
I am a newbie here and my knowledge of computer is low enough to make me not fully understanding the contain of all your posts.
I have installed Kobi on my computer and discovered the plug-in of my favorite music website "Mixcloud" .
The plug-in is now installed.
Unfortunately I cannot get the access token after having entered the authentication code picked up in the website address as per your directives in this thread.
Could you please tell me how I can get that token now?
Thanks in advance
Bruno
(2015-03-16, 17:53)braudoux Wrote: [ -> ]Hi,
Thanks in advance
Bruno
First, make sure you have version 2.0.1
Then try the procedure again (sometimes mixcloud does not respond).
HOWTO Getting an authentication code:
1: Login with your mixcloud account using following link, the access code is in the landing page URL
2.0.1: Login with your mixcloud account
2: You will return on the landing page. The access code is in the URL right next to code=, like this for 2.0.1: forum.kodi.tv/showthread.php?tid=116386&code=your_access_code
3: Enter this code in the mixcloud plugin settings window, right next to Authentication code
4: After entering the authentication code, the access token is fetched automatically in the background.
If this doesn't work, can you post the mixcloud log file?
I got an error first time, but then when I clicked OK it seemed to work.
Listening to things no problem now, thanks for the add-on!
Recentrly added the Mixcloud addon to my Kodi.
I can search and play streams without problems, but I am not able to use my authentication code.
Hope that somebody can help me.
This is what is displayed in the log:
16:38:50 T:1768252480 NOTICE: -->Python Interpreter Initialized<--
16:38:51 T:1768252480 NOTICE: MIXCLOUD ##########################################################
16:38:51 T:1768252480 NOTICE: MIXCLOUD Mode: 0
16:38:51 T:1768252480 NOTICE: MIXCLOUD Offset: 0
16:38:51 T:1768252480 NOTICE: MIXCLOUD Key:
16:38:51 T:1768252480 NOTICE: MIXCLOUD Query:
16:38:51 T:1579775040 NOTICE: Thread BackgroundLoader start, auto delete: false
16:38:54 T:1768252480 NOTICE: Thread LanguageInvoker start, auto delete: false
16:38:55 T:1768252480 NOTICE: -->Python Interpreter Initialized<--
16:38:56 T:1768252480 NOTICE: MIXCLOUD ##########################################################
16:38:56 T:1768252480 NOTICE: MIXCLOUD Mode: 11
16:38:56 T:1768252480 NOTICE: MIXCLOUD Offset: 0
16:38:56 T:1768252480 NOTICE: MIXCLOUD Key:
16:38:56 T:1768252480 NOTICE: MIXCLOUD Query:
16:38:56 T:1768252480 NOTICE: MIXCLOUD No access_token found
16:39:00 T:1793418304 NOTICE: service.libraryautoupdate-0.9.8 : Player is running, wait until finished
16:39:51 T:1768252480 NOTICE: MIXCLOUD getting access token https://www.mixcloud.com/oauth/access_to...PzKK3bQfSW
16:39:52 T:1768252480 NOTICE: MIXCLOUD oath_code failed error=HTTP Error 403: Forbidden
Best regards,
MacLeod
(2015-10-16, 16:46)MacLeod Wrote: [ -> ]Recentrly added the Mixcloud addon to my Kodi.
Best regards,
MacLeod
Apparently, Mixcloud modified something in their authentication procedure.
But I've figured it out already and got it working again. I'll try to upload a new version as soon as possible.
New version 2.0.3 is available from github
Also available from the official repository in a couple of days...
Going back to Sleepy
(2015-10-19, 11:17)jackyNIX Wrote: [ -> ]New version 2.0.3 is available from github
Thanks, will wait for the new version from the repository!
Enjoy your Sleepy!
Similar to other posters, I have Mixcloud 2.1.1 plugin installed on latest stable Kodi on OpenElec. I have my access code but it doesn't seem to auto fetch the authentication code. I have tried multiple times at different times of day and different days but it is still not accepted.
Any help gratefully received.
I will look into it.
(2016-01-07, 15:00)Sir Runcibal Spune Wrote: [ -> ]Hi,
I tried it, and it still works, but the procedure is a bit "wonky".
1: enable the "use mixcloud account" option
2: enter the authentication code you get when following the link in the OP.
3: exit the addon and reenter
4: enter one of the account functions (like followers, followings)
5: you'll be asked for the authentication code (already there now, or renter if not)
6: it is possible you have to retry 5 one or two times
Can you try this procedure and keep us posted here?
I'll try to iron things out a bit in the next version.
