Full Version: Mixcloud plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
... and it's broken again Sad
The fix worked for a couple of hours, but mixcloud also removed the m4a links just now. Sites like mixcloud-downloader.com and clouddownload.co.uk are also broken now.
We'll have to sit this one out, I'm sure somebody will find a way sooner or later Cool
Awwww I cant wait. I only use this plugin for music Sad
Well, this mixcloud update made me to install new firmware on my tv-box before I figured out what is happening ))
Nevertheless, I think they made some changes on how music is streaming. Before, files were kinda caching and playing was on even without internet connection. And now, sometimes when I have bad internet connection, I can see music stops immediately when connection breaks.
Hope, jackyNIX will find some solution to this.
Miss continuous playlist play badly Sad Mixcloud android app requires to push play for every new mix, so stupid
Thanks for your effort, man! Cheers!
not is working in kodi, true?
true working in kodi it is not
-yoda
There's light at the end of the tunnel...
An update will be ready soon. Nod
Great news Cool
The plugin will be updated automaticaly in Kodi,
but is also available through my repo on github.
Big thank you to zakedogg's dub sessions for some exquisite background noise Music
Legend, thanks for this!
(2017-08-29, 11:57)jackyNIX Wrote: [ -> ]The plugin will be updated automaticaly in Kodi,
The plugin is working again, thanks man!
Glad you like my dubs Smile
Check https://mixcloud.com/zakedogg/ if you like dub.
Hi jackyNIX,
I have a problem with the addon.
I can't listen to the music. I see everithing, but when i want to play a sound that's impossible.
Log is not very helpful :
15:21:22.465 T:1962160592   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2Ffalefebvre%2F111117-7008%2F&user=%2Ffalefebvre%2F]
15:21:25.437 T:1962160592   ERROR: Playlist Player: skipping unplayable item: 1, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2Ffalefebvre%2F5631-after-tiki-party%2F&user=%2Ffalefebvre%2F]
15:21:27.735 T:1962160592   ERROR: Playlist Player: skipping unplayable item: 2, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2Ffalefebvre%2F300717%2F&user=%2Ffalefebvre%2F]
15:21:30.702 T:1962160592   ERROR: Playlist Player: skipping unplayable item: 3, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2Ffalefebvre%2F070707%2F&user=%2Ffalefebvre%2F]
15:21:33.906 T:1962160592   ERROR: Playlist Player: skipping unplayable item: 4, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2Ffalefebvre%2F4538%2F&user=%2Ffalefebvre%2F]
15:21:37.238 T:1962160592   ERROR: Playlist Player: skipping unplayable item: 5, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2Ffalefebvre%2F5130%2F&user=%2Ffalefebvre%2F]
15:21:40.530 T:1962160592   ERROR: Playlist Player: skipping unplayable item: 6, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2Ffalefebvre%2Fmix_sunday_26_03_17%2F&user=%2Ffalefebvre%2F]
So just doing a lot :
desinstall et reinstall the addon with the repo and manually with your Github release
updated the Libreelec with the last version
Changed the resolver
Any idea where the problem is and any idea  to fix it ?
Thanks a lot ;-)
(2017-11-12, 19:03)Mucoma Wrote: [ -> ]Hi jackyNIX,
Thanks a lot ;-)
1: Can you enable Debug Mode in the addon settings and post the log (all the lines with NOTICE: MIXCLOUD in front)?
2: One thing I notice is all the %2F in the urls. Those are the "/" character. weird. It should print just as / in the log...
3: I tried the first stream in your log, it resolves as http://www.mixcloud.com/falefebvre/111117-7008/ and plays just fine on my system
4: Does it happen if you try my jackyNIX streams (the bottom folder in main menu) too?
The same issue for me (jackyNIX streams).
Kodi 17.4
Mixcloud 2.2.1
Here is the log in debug mode:
13:11:57.883 T:1745875888  NOTICE: MIXCLOUD ##########################################################
13:11:57.884 T:1745875888  NOTICE: MIXCLOUD Mode: 15
13:11:57.884 T:1745875888  NOTICE: MIXCLOUD Offset: 0
13:11:57.884 T:1745875888  NOTICE: MIXCLOUD Key:
13:11:57.884 T:1745875888  NOTICE: MIXCLOUD Query:
13:11:57.884 T:1745875888  NOTICE: MIXCLOUD ##########################################################
13:11:57.885 T:1745875888  NOTICE: MIXCLOUD Get cloudcasts http://api.mixcloud.com/jackyNIX/cloudca...0&offset=0
13:12:02.659 T:1556005808  NOTICE: MIXCLOUD ##########################################################
13:12:02.659 T:1556005808  NOTICE: MIXCLOUD Mode: 40
13:12:02.659 T:1556005808  NOTICE: MIXCLOUD Offset: 0
13:12:02.660 T:1556005808  NOTICE: MIXCLOUD Key: /jackyNIX/jackynix-sosn07-full-gaes-in-the-rue-blaes/
13:12:02.660 T:1556005808  NOTICE: MIXCLOUD Query:
13:12:02.660 T:1556005808  NOTICE: MIXCLOUD ##########################################################
13:12:02.660 T:1556005808  NOTICE: MIXCLOUD Resolverid _curr=0 _orig=0
13:12:02.660 T:1556005808  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...rue-blaes/
13:12:02.660 T:1556005808  NOTICE: MIXCLOUD Link version 2
13:12:06.021 T:1556005808  NOTICE: MIXCLOUD Unable to resolve
13:12:06.022 T:1556005808  NOTICE: MIXCLOUD Cannot solve using current resolver
13:12:06.023 T:1556005808  NOTICE: MIXCLOUD Changing resolver to 1
13:12:06.023 T:1556005808  NOTICE: MIXCLOUD Locally resolving cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...rue-blaes/
13:12:06.023 T:1556005808  NOTICE: MIXCLOUD Changing resolver to 2
13:12:06.023 T:1556005808  NOTICE: MIXCLOUD Resolving offliberty cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...rue-blaes/
13:12:06.023 T:1556005808  NOTICE: MIXCLOUD Changing resolver to 3
13:12:06.023 T:1556005808  NOTICE: MIXCLOUD Resolving m4a cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...rue-blaes/
13:12:06.024 T:1556005808  NOTICE: MIXCLOUD Changing resolver to 4
13:12:06.024 T:1556005808  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...rue-blaes/
13:12:06.024 T:1556005808  NOTICE: MIXCLOUD Link version 1
13:12:09.172 T:1556005808  NOTICE: MIXCLOUD Unable to resolve
13:12:09.173 T:1556005808  NOTICE: MIXCLOUD Changing resolver to 5
13:12:09.173 T:1556005808  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...rue-blaes/
13:12:09.173 T:1556005808  NOTICE: MIXCLOUD Link version 2
13:12:12.468 T:1556005808  NOTICE: MIXCLOUD Unable to resolve
13:12:12.469 T:1556005808  NOTICE: MIXCLOUD Stop player
13:12:12.473 T:1945883296   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2FjackyNIX%2Fjackynix-sosn07-full-gaes-in-the-rue-blaes%2F&user=%2FjackyNIX%2F]
13:12:14.277 T:1745875888  NOTICE: MIXCLOUD ##########################################################
13:12:14.277 T:1745875888  NOTICE: MIXCLOUD Mode: 40
13:12:14.279 T:1745875888  NOTICE: MIXCLOUD Offset: 0
13:12:14.279 T:1745875888  NOTICE: MIXCLOUD Key: /jackyNIX/jackynix-sosn-06-meanwhile-on-the-other-side-of-the-street/
13:12:14.279 T:1745875888  NOTICE: MIXCLOUD Query:
13:12:14.279 T:1745875888  NOTICE: MIXCLOUD ##########################################################
13:12:14.279 T:1745875888  NOTICE: MIXCLOUD Resolverid _curr=0 _orig=0
13:12:14.279 T:1745875888  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...he-street/
13:12:14.279 T:1745875888  NOTICE: MIXCLOUD Link version 2
13:12:17.437 T:1745875888  NOTICE: MIXCLOUD Unable to resolve
13:12:17.437 T:1745875888  NOTICE: MIXCLOUD Cannot solve using current resolver
13:12:17.438 T:1745875888  NOTICE: MIXCLOUD Changing resolver to 1
13:12:17.438 T:1745875888  NOTICE: MIXCLOUD Locally resolving cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...he-street/
13:12:17.438 T:1745875888  NOTICE: MIXCLOUD Changing resolver to 2
13:12:17.438 T:1745875888  NOTICE: MIXCLOUD Resolving offliberty cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...he-street/
13:12:17.438 T:1745875888  NOTICE: MIXCLOUD Changing resolver to 3
13:12:17.439 T:1745875888  NOTICE: MIXCLOUD Resolving m4a cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...he-street/
13:12:17.439 T:1745875888  NOTICE: MIXCLOUD Changing resolver to 4
13:12:17.439 T:1745875888  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...he-street/
13:12:17.439 T:1745875888  NOTICE: MIXCLOUD Link version 1
13:12:20.569 T:1745875888  NOTICE: MIXCLOUD Unable to resolve
13:12:20.570 T:1745875888  NOTICE: MIXCLOUD Changing resolver to 5
13:12:20.572 T:1745875888  NOTICE: MIXCLOUD Resolving mixcloud-downloader cloudcast stream for http://www.mixcloud.com/jackyNIX/jackyni...he-street/
13:12:20.572 T:1745875888  NOTICE: MIXCLOUD Link version 2
13:12:23.712 T:1745875888  NOTICE: MIXCLOUD Unable to resolve
13:12:23.713 T:1745875888  NOTICE: MIXCLOUD Stop player
13:12:23.714 T:1945883296   ERROR: Playlist Player: skipping unplayable item: 1, path [plugin://plugin.audio.mixcloud/?mode=40&key=%2FjackyNIX%2Fjackynix-sosn-06-meanwhile-on-the-other-side-of-the-street%2F&user=%2FjackyNIX%2F]
tnx, I'll look into it.
mmm, I simply cannot duplicate your problem, it always works (v2.2.1 on 17.3 - 17.6).
Try to browse to this url (on the same machine as kodi), and let me know what you get?
http://www.mixcloud-downloader.com/dl/mi...rue-blaes/
Maybe send me the source html file by PM
I suspect mixcloud-downloader shows something else on your setup, maybe you have their plugin installed?
