Pages: 1 2 3 4 5 6 7 8 9 10
john6555 Wrote:What version is the fixed scraper? Don't think mine has updated yet...
It should now read 2.0.7 - if it doesn't then please try to update manually
Settings->Addons->Enabled Addons->Artist Information select AllMusic and update
Thanks DDD, looks like it works perfect now. I'll keep playing around with it and let you know if any thing is a problem.
Mman Wrote:Thanks DDD, looks like it works perfect now. I'll keep playing around with it and let you know if any thing is a problem.
Glad to hear it - enjoy
DDDamian Wrote:It should now read 2.0.7 - if it doesn't then please try to update manually
My Allmusic.com Album Information add-on is at v2.0.1 and Artists Information is v2.0.6 ... and update is grayed out. I tried refresh, update repo, etc. to no avail. Any other suggestions?
john6555 Wrote:My Allmusic.com Album Information add-on is at v2.0.1 and Artists Information is v2.0.6 ... and update is grayed out. I tried refresh, update repo, etc. to no avail. Any other suggestions?
Was just helping someone yesterday with the same
issue. Have you shut down XBMC and re-started? It should self-update.
DDDamian Wrote:Was just helping someone yesterday with the same issue. Have you shut down XBMC and re-started? It should self-update.
Thanks! I updated to Eden beta 2 and it seems to be working now.
I'm running Eden beta 2 on windows 7 with updated scrapers. I've restarted XBMC & even rebooted, but I'm still getting copyright message!!
Help please!
spinecho Wrote:I'm running Eden beta 2 on windows 7 with updated scrapers. I've restarted XBMC & even rebooted, but I'm still getting copyright message!!
Help please!
Did you see my post
here?
I had the same problem, but once I updated the allmusic.xml in the Program Files (x86) folder it started working.
john6555 Wrote:Did you see my post here?
Thanks, i'll give it a go!
quick question:
ive managed to get it to scrape album info but can't for the love of god get it to scrape artist. any pointers?
chrillep Wrote:quick question:
Welcome to the forums. Is your version correct (2.0.7)? Artist name? Are you refreshing Artist Information as opposed to Album Information? Are you in Library Mode?
DDDamian Wrote:Welcome to the forums. Is your version correct (2.0.8)?
Do you mean 2.0.7? Or has it been updated again?
john6555 Wrote:Do you mean 2.0.7? Or has it been updated again?
Apologies and thanks John - version 2.0.7 (under Settings->Addons->Enabled Addons->Artist Information) is correct & latest.
My Album Information add-on is also stuck at v2.0.1, while my Artist Information is at v2.0.7. Any reason why this would be the case?
graymoment Wrote:My Album Information add-on is also stuck at v2.0.1, while my Artist Information is at v2.0.7. Any reason why this would be the case?
That's perfectly normal - each is seperate code and revisions aren't always needed to both. Everything's up to date.
