SUSE linux 12.1 XBMC from source x86_64 MKV problem
xbmc is compiled from git last unstable release . the problem is when i play MKV file it seems cant decode mkv its greenish scrambled screen
PC info amd zacate fusuin E350 gigabyte , linux is suse 12.1 x86_64 kernel 3.1
yeah you are right it happens to h264 ? what is wrong or what im doing wrong
maybe something in ./configure ....?
please try different h264 files. if it happens with all of them, you have a general problem.
if it is only one file that make problems, it could be L5.1, which is currently not supported by the ATI drivers.
it is not 5.1 its 4.1 look :
Quote:Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 41mn 48s
Bit rate : 5 807 Kbps
Nominal bit rate : 5 954 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
its maybe general problem h264
can you check my config am i missing something:
Quote:------------------------
XBMC Configuration:
Debugging: No
Profiling: No
Optimization: Yes
Crosscomp.: No
target ARCH: no
target CPU: no
OpenGL: Yes
ALSA: Yes
DBUS: Yes
VDPAU: No
VAAPI: Yes
CrystalHD: Yes
VDADecoder: No
VTBDecoder: No
OpenMax: No
Joystick: Yes
XRandR: Yes
GOOM: No
RSXS: Yes
ProjectM: Yes
Skin Touched: No
X11: Yes
Bluray: No
TexturePacker:Yes
MID Support: Yes
ccache: Yes
PulseAudio: No
HAL Support: No
DVDCSS: Yes
Avahi: Yes
Non-free: Yes
ASAP Codec: No
Webserver: Yes
libRTMP support: No
libsmbclient support: Yes
libnfs client support:No
libafpclient support: No
AirPLay support: No
AirTunes support: No
Optical drive: No
libudev support: Yes
libusb support: No
libcec support: No
External FFmpeg: No
prefix: /usr/local/xbmc
config seems fine.
which xvba-driver do you use? what does vainfo and fglrxinfo show?
im sorry about 3rd post but i wanted to tell i fixed it
and i dont know how this is funny
just i recompiled it and it runs flawlesly now
Quote:# vainfo
libva: libva version 0.32.0
libva: User requested driver 'fglrx'
libva: Trying to open /usr/lib64/dri/fglrx_drv_video.so
libva: va_openDriver() returns 0
vainfo: VA API version: 0.32
vainfo: Driver version: Splitted-Desktop Systems XvBA backend for VA-API - 0.8.0
vainfo: Supported profile and entrypoints
VAProfileH264High : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
Quote:# fglrxinfo
display: :0 screen: 0
OpenGL vendor string: Advanced Micro Devices, Inc.
OpenGL renderer string: AMD Radeon HD 6300 series Graphics
OpenGL version string: 4.1.11251 Compatibility Profile Context
and i saw a strange output when i exited xbmc:
Quote:./xbmc
Running DIL (3.23.0) Version
DtsDeviceOpen: Opening HW in mode 0
DtsDeviceOpen: Create File Failed
no talloc stackframe around, leaking memory
