Full Version: [lion] nightly builds are not working
Hello here!
Just upgraded to 10.7.2... a lot of bugs with this OS :-( but I've to use it anyway.
I've a trouble with nightly builds: they crash! every time the main menu screen freezes and I've to kill the application, while the stable release works nice.
I don't know how to get a log file in such a condition... can I turn on the log in dharma hoping that this still valid in the unstable version? or can I post the apple log? can it be useful?
best regards
see my sig, use http://www.pastebin.com. xbmc.log and crashreporter logs.
for freezes, use the terminal app, 'top' to find the pid, then kill -6 <pid>. that will force a crashreporter log.
Latest nightly (Dec 10th) working fine for me on Mac OS X 10.7.2
davilla Wrote:for freezes, use the terminal app, 'top' to find the pid, then kill -6 <pid>. that will force a crashreporter log.
here you are
http://pastebin.com/QgENNkPw
thank you a lot!
sometimes it let me just move the arrow for a second, another time it opened already inside the movie menu... in any case it was always freezed
the stable version instead works (apart the trouble with the audio device that I wrote in another post)
I SOLVED THIS TROUBLE!!!
Quite silly... Lion has the resume function, so in my case a 1:1 substitution of Dharma with the nightly build generates a conflict. It was sufficient to remove the xbmc resume log and also this version loaded correctly.
gatto_mannaro Wrote:I SOLVED THIS TROUBLE!!!
Good to know! I'll have to note this for the revised Mac FAQ
My hint is to use the software RestoreMeNot
