Ronie... i think (?) i found a couple bugs in v0.1.4
1. Icons are not showing and i think because of
this. When removed the "128x128" from scripts code they show up
before
WEATHER_ICON = xbmc.translatePath('special://temp/weather/128x128/%s.png')
after
WEATHER_ICON = xbmc.translatePath('special://temp/weather/%s.png')
2. Predefined temp unit for feels like label in hourly page is missing
set_property('Hourly.%i.Temperature' % (count+1), item['temp']['english'] + TEMPUNIT)
set_property('Hourly.%i.DewPoint' % (count+1), item['dewpoint']['english'] + TEMPUNIT)
set_property('Hourly.%i.FeelsLike' % (count+1), item['feelslike']['english'])
Of course i am not python coder i just saw those, i edit the script, and they work.
Cheers
Nessus
PS. I am not seeing any third day in weekend page yet...
. (This is not a bug. Just a request
(2012-04-30, 11:23)nessus Wrote: [ -> ]Ronie... i think (?) i found a couple bugs in v0.1.4
cheers mate
will fix those right away
(2012-04-30, 07:57)Nuka1195 Wrote: [ -> ]@ronie I have a module over at xbmc4xbox that handles conversions of various things. It has some moon phase icons also. Does this weather provider support that.
yup, wunderground provides the current moon phase:
"moon_phase": {
"percentIlluminated":"73",
"ageOfMoon":"10",
"current_time": {
"hour":"17",
"minute":"02"
edit:
see utilities.py, i have some code there that converts the percentIlluminated/ageOfMoon values
to a string (ie. 'full moon'). i guess the same code can be used for icon matching.
(2012-04-30, 00:37)tinybutstrong Wrote: [ -> ]Any skin already is supporting new features listed by you in page 7?
I have modified weather pages for Confluence (standard and vertical) that have many of the features (all based on the Weather+ support in Confluence).
https://github.com/downloads/pkscout/ski...eather.zip
pictures please.
ronie. i'll see about gathering the modules. i made changes and lost them when i lost my main computer. but one of the ideas i had was (if i understand correctly) don't force weather addons to pass to xbmc as celcius and then have xbmc convert to the proper local. the module takes care of that and then you don't get thos weird glitches. the moon icons are 0.png to 34.png or something like that. i made them in photoshop, based on the old weather icon's clear night. may not match the new icons. but if the skin takes advantage of the moon phases they're ther temporarily.
Perhaps tree_jammer is interested in doing moon phases that match the icons he did
I have a strange behavior with v0.1.4. Labels
36Hour.%i.TemperatureHeading and
36Hour.%i.Temperature they are not showing in some languages selected in XBMC International Settings. For example, "English (US)" and "French" are not working and "English" and "Italian" they are working fine. i didn't test more languages to have a complete list but if i remember correctly this was not happening in previous versions.
Here is a
debug log that includes addon's log enabled in settings which is rather big (700kb) and that's why pastebin doesn't accept it.
Cheers
Nessus
(2012-04-30, 11:23)nessus Wrote: [ -> ]2. Predefined temp unit for feels like label in hourly page is missing
This is the only instance where the temperature unit is dealt with by pkscout's modifications of the Confluence skin rather than the script.
If the tempunit is added to the script as above, the skin mods need to be changed to avoid
°C°C appearing
I've played arround with it...
i still get an "error", but the plugin works as it should. mayber a skin-problem (i haven't yet looked into my log)
Since animated maps are no longer free, I'm curious... How about shifting the animation responsibilities onto the script? That is: let script to construct its own animated maps by downloading the static map every 15-30 minutes and assembling the last 7-10 static images into an animated image?
weather.wunderground-0.1.6.zip
fixed:
- removed the 128x128 from the weather icon location
- added temp unit for the hourly feels-like value
- 36 hour heading and temp for certain languages
added:
- provide 3 day weekend forecast <- just to get everyone off my back ;-p
- keep 4 hours worth of satellite images to create an animation
@pkscuot: sorry, you'll have to adjust the weekend code in your mod again...
weather.wunderground-0.1.7.zip
fixed:
- delete cached images when user changes weather location
- clear alert properties when there are no more alerts
Ronie... i get an error with latest version. Do you need a full debug log ?
05:07:16 T:3192 NOTICE: -->Python Interpreter Initialized<--
05:07:19 T:3192 ERROR: JSONRPC: Failed to parse '{ "jsonrpc" : "2.0" , "method" : "Files.GetDirectory" , "params" : { "directory" : "C:\Users\User\AppData\Roaming\XBMC\userdata\addon_data\weather.wunderground\map" , "sort" : { "method" : "file" } } , "id" : 1 }'
05:07:19 T:3192 ERROR: Error Type: <type 'exceptions.KeyError'>
05:07:19 T:3192 ERROR: Error Contents: ('result',)
05:07:19 T:3192 ERROR: Traceback (most recent call last):
File "C:\Users\User\AppData\Roaming\XBMC\addons\weather.wunderground\default.py", line 544, in <module>
forecast(location)
File "C:\Users\User\AppData\Roaming\XBMC\addons\weather.wunderground\default.py", line 144, in forecast
properties(data,loc)
File "C:\Users\User\AppData\Roaming\XBMC\addons\weather.wunderground\default.py", line 490, in properties
if (json_response['result'] != None) and (json_response['result'].has_key('files')):
KeyError: ('result',)
P.S. cheers for the 3 day weekend.
