2012-05-18, 17:25
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
2012-05-21, 12:41
(2012-05-14, 20:20)Nuka1195 Wrote: [ -> ]Ronie can i get you to comment on this trac ticket
http://trac.xbmc.org/ticket/13024
and while off topic. do you experience this one.
http://trac.xbmc.org/ticket/13030
one more friendly bump.
2012-05-21, 21:38
Wow, the new add-on works and looks great!
And finally the Dutch translation is also pretty good. E.g. the translation for 'clear' is actually the word we use for clear skies, not the one we use for 'clear the room'
My compliments on a job well done!!
2012-05-21, 22:38
(2012-05-14, 20:20)Nuka1195 Wrote: [ -> ]Ronie can i get you to comment on this trac ticketsure, will add my thoughts to the ticket. :-)
(2012-05-14, 20:20)Nuka1195 Wrote: [ -> ]and while off topic. do you experience this one.just tested it and can conform.
whether this is a bug or feature i'm unsure...
2012-05-22, 10:26
Thanks for a great job done.
Asking for assistance. I am experiencing a problem with parsing of the weather data when system language is different from English. Namely with Russian selected i see in log file all the weather data is fetched but this strings at the end of the log
09:39:42 T:4104 NOTICE: weather.wunderground - failed to parse weather data
09:39:42 T:4104 NOTICE: weather.wunderground - available locations: 2
09:39:42 T:4104 NOTICE: weather.wunderground - finished
With English selected, data is processed and shown but icons are missing for all the forecasts except default view and current condition Icon. Using AEON NOX git version 3.0.
Guide me please where to dig for the problem, i believe should be my local installation issue?
Thank you in advance
2012-05-22, 10:35
(2012-05-22, 10:26)savkin_k Wrote: [ -> ]Thanks for a great job done.
could you try the beta version (if you're not already doing so), available for download from the first post of this thread.
then go to Settings > Weather > Weather Underground > Advanced > Enable logging
and post the complete log to pastebin or xbmclogs.com
2012-05-22, 10:45
Thanks, Ronie for prompt reply.
I am already with 0.1.9 version of plugin.
here is fresh log
http://xbmclogs.com/show.php?id=2876
here is fresh log
2012-05-23, 00:46
(2012-05-22, 10:45)savkin_k Wrote: [ -> ]Thanks, Ronie for prompt reply.
here is fresh log
hmm.. that's a bug in their weather data.
will add a workaround for safety :-)
2012-05-31, 12:09
Seems my posts aren't going thru.
I entered weather. Then from there entered settings. I changed the zoom for map. Went back to weather. The map looked like you cache images for animation? If so you should delete cache when map zoom changes.
2012-05-31, 18:39
(2012-05-31, 12:09)Nuka1195 Wrote: [ -> ]I entered weather. Then from there entered settings. I changed the zoom for map. Went back to weather. The map looked like you cache images for animation?yup, the images of the last 4 hours are cached.
(2012-05-31, 12:09)Nuka1195 Wrote: [ -> ]If so you should delete cache when map zoom changes.would be very easy to do for Frodo, which supports onSettingsChanged events,
Eden would require a bit more work, will have to think about it...
2012-06-01, 01:25
Weather refreshes after saving settings. Just compare a zoom level property with the current setting. You also could look at my patch to addon settings. It adds an onclose="action" that runs after saving settings.
2012-06-09, 20:50
Just curious, but I updated the addon (1.9) through XBMC and restarted. The new files and folders did not update. So I manually updated the files and folders. Then, I noticed that the weather icons were not appearing except in the current (left) panel. Log indicated that the program was unable to find the weather icons in the cache/weather folder. When I checked, I had two subfolders in the weather folder: 128x128 and 64x64. By copying the icons from the 128x128 folder into the parent folder, the problem was resolved. However, I am wondering if this is a bug or did I do something wrong? Perhaps I skipped a previous update that modified these settings?
Any help appreciated.
2012-06-09, 21:42
What XBMC version are you using? Probably not Eden11.0
2012-06-09, 21:49
(2012-06-09, 21:42)Martijn Wrote: [ -> ]What XBMC version are you using? Probably not Eden11.0
Yep, Eden 11.0
2012-06-28, 15:22
I'm getting a script failed message after enabling v 1.9. I'm on Eden. Do I need to have a nightly installed for this addon to work? I've reset my location and using English Language and Region USA (12H). Thanks
I tried with New York City, NY and that works. It works for my old home town Spotyslvania, VA. But it is not working for Charlotte, NC (28203)
This was at the end of the log file if this is helpful.
09:39:33 T:3052 ERROR: Error Type: <type 'exceptions.KeyError'>
09:39:33 T:3052 ERROR: Error Contents: (u'L',)
09:39:33 T:3052 ERROR: Traceback (most recent call last):
File "C:\Users\Scott\AppData\Roaming\XBMC\addons\weather.wunderground\default.py", line 555, in <module>
forecast(location)
File "C:\Users\Scott\AppData\Roaming\XBMC\addons\weather.wunderground\default.py", line 144, in forecast
properties(data,loc)
File "C:\Users\Scott\AppData\Roaming\XBMC\addons\weather.wunderground\default.py", line 479, in properties
set_property('Alerts.%i.Significance' % (count+1), SEVERITY[item['significance']])
KeyError: (u'L',)
forecast(location)
KeyError: (u'L',)
