2012-07-24, 10:14
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
2012-07-24, 11:43
(2012-07-24, 03:42)argh! Wrote: [ -> ]How on earth are you guys getting these wonferdul Weather Underground views?
you need to install a skin that supports the extended features of wu.
if you use T!, switch to the svn version of Transparency!
2012-07-24, 11:45
(2012-07-24, 10:14)nessus Wrote: [ -> ]ronie... are you planning to push this to the official repo ?
Cheers
Nessus
yeah, just don't know when.
2012-07-24, 11:50
2012-07-24, 12:03
(2012-07-24, 11:50)Martijn Wrote: [ -> ](2012-07-24, 11:45)ronie Wrote: [ -> ](2012-07-24, 10:14)nessus Wrote: [ -> ]ronie... are you planning to push this to the official repo ?
Cheers
Nessus
Could do it for you
i know and thanx for your help with the other addons :-)
there's a few things i need to double-check before i can push this one to the repo.
2012-07-24, 22:27
Ok... thanks
2012-07-24, 22:46
edit: nevermind, asked and answered above.
2012-07-26, 08:56
(2012-07-24, 11:43)ronie Wrote: [ -> ](2012-07-24, 03:42)argh! Wrote: [ -> ]How on earth are you guys getting these wonferdul Weather Underground views?
Ah. I do use T!, but I'll have to use a nightly to use the SVN build, right? I'm not quite brave enough to use a nightly as my regular player...
thanks.
2012-08-10, 13:08
(2011-12-11, 02:02)ronie Wrote: [ -> ]if you're interested in testing these new features:Hi ronie.
weather.wunderground-0.1.10.zip
question, requests, issues?
please let me know.
This addon is very useful for me.
I have installed the latest update (0.01.10).
I'm testing and I find no errors for now.
Why not a spanish version? This is my spanish translated strings.xml file.
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<strings>
<string id="32101">Ubicaciones</string>
<string id="32102">Opciones avanzadas</string>
<string id="32111">Ubicación 1</string>
<string id="32112">Ubicación 2</string>
<string id="32113">Ubicación 3</string>
<string id="32114">Nombre para la ubicación 1</string>
<string id="32115">Nombre para la ubicación 2</string>
<string id="32116">Nombre para la ubicación 3</string>
<string id="32117">Código de la ubicación 1</string>
<string id="32118">Código de la ubicación 2</string>
<string id="32119">Código de la ubicación 3</string>
<string id="32120">Habilitar el registro</string>
<string id="32121">Fin de semana</string>
<string id="32122">Sábado y domingo</string>
<string id="32123">Viernes y sábado</string>
<string id="32124">Jueves y viernes</string>
<string id="32125">Nivel de zoon de mapas</string>
<string id="32126">Mapas animados</string>
<string id="32501">Nueva</string>
<string id="32502">Creciente</string>
<string id="32503">Cuarto creciente</string>
<string id="32504">Gibosa creciente</string>
<string id="32505">Llena</string>
<string id="32506">Gibosa menguante</string>
<string id="32507">Cuarto menguante</string>
<string id="32508">Menguante</string>
<string id="32510">Alerta</string>
<string id="32511">Seguimiento</string>
<string id="32512">Aviso</string>
<string id="32513">Parte meteorológico</string>
<string id="32514">Previsión</string>
<string id="32515">Predicción meteorológica</string>
<string id="32516">Resumen</string>
</strings>
(And this is the translated sections in the addon.xml file)
<summary lang="es">Predicción meteorológica de wunderground.com</summary>
<description lang="es">Predicción meteorológica facilitada por Weather Underground (http://www.wunderground.com/)</description>
<disclaimer lang="es">El uso de este complemento implica la aceptación de los términos del servicio que se encuentran en http://www.wunderground.com/weather/api/d/terms.html</disclaimer>
Thank you for your work.
2012-08-15, 15:53
I'm running Aeon MQ4 and recently i'm getting many errors from wunderground
Example:
Anyone else noticed this?
Example:
01:00:04 T:140135748314880 ERROR: Error Type: <type 'exceptions.IOError'>
01:00:04 T:140135748314880 ERROR: Error Contents: (2, 'No such file or directory', '/storage/.xbmc/userdata/addon_data/weather.wunderground/map/7A6D773A30303030302E372E3036333530-20120815010004.png')
01:00:04 T:140135748314880 ERROR: Traceback (most recent call last):
File "/storage/.xbmc/addons/weather.wunderground/default.py", line 601, in <module>
forecast(location)
File "/storage/.xbmc/addons/weather.wunderground/default.py", line 144, in forecast
properties(data,loc)
File "/storage/.xbmc/addons/weather.wunderground/default.py", line 560, in properties
tmpmap = open(mapfile, 'wb')
IOError: (2, 'No such file or directory', '/storage/.xbmc/userdata/addon_data/weather.wunderground/map/7A6D773A30303030302E372E3036333530-20120815010004.png')
01:00:16 T:140135748314880 NOTICE: Thread Background Loader start, auto delete: false
01:00:25 T:140134791218944 NOTICE: Previous line repeats 1 times.
01:00:25 T:140134791218944 WARNING: GetIcon - Unknown nodetype requested videodb://2/2/9/-1/
2012-08-15, 18:11
(2012-08-15, 15:53)schumi2004 Wrote: [ -> ]Anyone else noticed this?
haven't seen it before...
did you, by any chance, enable folder redirection in advancedsettings.xml?
if you did, that could probably be the cause.
2012-08-15, 23:38
(2012-08-10, 13:08)Patrizia Wrote: [ -> ]Why not a spanish version? This is my spanish translated strings.xml file.
thanx mate!
will add them.
2012-08-16, 23:40
(2012-08-15, 18:11)ronie Wrote: [ -> ](2012-08-15, 15:53)schumi2004 Wrote: [ -> ]Anyone else noticed this?
Yes is did. Should i disable it or just copy add-on data back to box ? Disabling isn't actually an option.
2012-08-17, 01:09
(2012-08-16, 23:40)schumi2004 Wrote: [ -> ]Yes is did. Should i disable it or just copy add-on data back to box ? Disabling isn't actually an option.
as far as i know it's not possible to directly download something from the internet to a remote share,
it needs to be downloaded to a local drive.
addon_data is the designated place for addons to store it's data, so moving it to a remote share will cause issues.
2012-08-22, 16:32
Anyway to view the radar map instead of the satellite? Toggling between them would also be a great option.
