Hehe... i guess i deserve that answer
Here you go...
Addon version : 1.0.4
XBMC version : XBMCSetup-20121205-8ce3f48-master
... If you still need a debug log let me know.
Cheers
Nessus
i'll have to submit that one to wunderground.
it's a bug in their api.
i gave up on the three day weekend forecast.
it was too confusing and causing bugs.
as of now, wunderground will fetch a 2 day weekend only.
Hello,
Xbian 1.0 Alpha 3 & Weather Underground latest add-on 1.0.6
When trying to update it to 1.0.6 the following message is displayed:
Quote:add-on has been marked broken in repository
dependencies not met
So it can't be updated. Just for your info.
Regards!
We know and you should update to a newer build
There seems to be some issue with the text displayed in the Map and Alert part in the addon. It displays garbled text instead of normal text.
The weather location is in this case Hungary.
A screenshot that shows all the invalid characters or garbled text
Debug Log.
http://pastebin.com/3VUeTtEz
I thought originally that the garbled text should be in Hungarian but the first Three words being Snow and Ice being in English throws me off and further along on second line the   also throws me further off.
Logs shows nothing that I can see.
uNi
(2012-12-16, 20:38)uNiversal Wrote: [ -> ]There seems to be some issue with the text displayed in the Map and Alert part in the addon. It displays garbled text instead of normal text.
i've reported this issue to wunderground last week:
http://apicommunity.wunderground.com/wea..._messed_up
it's up to them to fix it.
(2012-12-16, 21:44)uNiversal Wrote: [ -> ]Ah thanks Ronie good to know.
FYI the https://github.com/xbmc/xbmc/pull/1941
Should be merged asap atm I'm overwriting the xml for time being.
Thanks again.
uNi
Only when we update wunderground like the PR says
The PR actually fixes something currently broken, anyway not that important that it cant wait.
uNi
(2012-12-17, 00:25)uNiversal Wrote: [ -> ]The PR actually fixes something currently broken, anyway not that important that it cant wait.
just trust us, we're professionals, we know what we're doing ;-)
(2012-12-16, 16:55)Martijn Wrote: [ -> ]We know and you should update to a newer build
Thanks for your support! So I did the updating to latest XBMC 12.0RC1 in XBian 1.0a3...
And the addon could be updated flawlessly! For your info.
Regards
Can you please change the wind scale to Beaufort for The Netherlands?
Many thanks for your great work!
