Full Version: Weather Underground
Yep - I did that Smile - was for my OzWeather add on....link below.
Hitcher Wrote:Did I read on git that the default number of days is being increased to 7?
yup, xbmc can now handle 7 days weather forecast.
the addon needs to support it too of course.
... and skins as well.
So it's not been changed for this one then?
I might just add all seven days as standard but use visible conditions to hide any days that aren't scraped.
Hitcher Wrote:So it's not been changed for this one then?
nope not yet.
i'm working on extending the functionality of the addon.
the goal is to provide (at least):
  • 7 days forecast
  • hourly forecast
  • yesterdays weather
  • weather alerts
  • extra info for todays weather
  • ...and then some
no eta at the point.
WUNDERMAP!!! PLEASE!!!!
Diggs
Diggs Wrote:WUNDERMAP!!! PLEASE!!!!
Diggs
i'm afraid there's no api access to wundermap.
What happened to the FanartCode property?
Hitcher Wrote:What happened to the FanartCode property?
nothing?
it's there...you having problems with it?
My fault, sorry.
I was using an multiimage path string in a single image control and when it didn't work I checked the wiki and noticed FanartCode wasn't listed.
I have the XBMC 11 Eden: RC1: UPDATE and the weather underground script fails whenever I type in a location. Is this supposed to work in RC1? Using windows.
vskatusa Wrote:I have the XBMC 11 Eden: RC1: UPDATE and the weather underground script fails whenever I type in a location. Is this supposed to work in RC1? Using windows.
that's indeed supposed to work without any issues.
could you please post a logfile?
Sure.. here are the logs
check that you didn't enable a proxy server in xbmc (if you don't need it):
Settings > Network > Internet Access > Use http proxy...
That did it! Why did I not think about it Big Grin
