2014-06-17, 17:54
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
2014-06-20, 12:09
ok I submitted this "fix" to addons mailing list http://sourceforge.net/p/xbmc/mailman/message/32484609/
Edit
That email turned out to be in wrong format. OS after speaking to kib a PR at github was made we wait for review of that by someone who can pull it or whatever.
If anyone want to test the fix https://github.com/uNiversaI/weather.wun...36hour.zip
The patch is here https://github.com/XBMC-Addons/weather.w...ll/2.patch
and the PR to github is https://github.com/XBMC-Addons/weather.w...und/pull/2
If some alternative or better fix for that is pushed pls share.
@ronie if you reading this by some crazy chance, hope everything is ok with you, given the circumstances of real life pulling you away. please know best wishes are heartfelt here.)
Edit
2014-06-27, 17:44
thx uNiversal !
i've pushed the update to the addon repo,
it should arrive at everyone's doorsteps in the next hours.
2014-06-28, 14:04
Hello,
I get no info in the weather
My system is in Hebrew, I found out that if I change it to any other language every thing works great.
But when I change it back to Hebrew I loos the weather info.
What can I do to make it work?
2014-06-28, 14:21
(2014-06-28, 14:04)Mr_Brownstone Wrote: [ -> ]Hello,
sadly i can't fix that.
it's a bug in the wunderground api:
http://apicommunity.wunderground.com/wea...ebrew_json
2014-06-28, 14:36
Ok,
Thank You
Thank You
2014-07-01, 06:50
thx ronie, nice new artwork, glad they changed it.
2014-07-28, 03:38
What versions are we on?
My XBMC in Windows says v3, on openELEC (RPi) its v2 (with no updates),
How do i get version 3 in openELEC for RPi?
Many Thanks
Many Thanks
2014-07-28, 10:05
(2014-07-28, 03:38)SFX Group Wrote: [ -> ]What versions are we on?
Many Thanks
if you're running xbmc 13.x, wunderground v3.08 is the latest version.
it should always be up-to-date if auto-update addons is enabled in xbmc.
2014-07-28, 14:04
(2014-07-28, 10:05)ronie Wrote: [ -> ]if you're running xbmc 13.x, wunderground v3.08 is the latest version.
Desktop is on v13, the RPI is on v12.2, looks like openELEC isnt on v13 yet (auto update is on).
2014-07-28, 14:08
(2014-07-28, 14:04)SFX Group Wrote: [ -> ](2014-07-28, 10:05)ronie Wrote: [ -> ]if you're running xbmc 13.x, wunderground v3.08 is the latest version.
I think they mentioned on their website that you needed to manually update from v12.2 to 13.1 (some changes in update system)
http://openelec.tv/news/22-releases/125-...0-released
2014-07-28, 14:23
(2014-07-28, 14:08)Martijn Wrote: [ -> ]I think they mentioned on their website that you needed to manually update from v12.2 to 13.1 (some changes in update system)
You have to be kidding me, i just asked this question 30 seconds ago, what's the point of "auto update" if they dont use it?
Means puling an SD card and manually updating then spending hours with a remote putting in all the settings in (again), as the backup doesnt work fully on the RPi as it locks the SD card.
2014-07-28, 14:31
(2014-07-28, 14:23)SFX Group Wrote: [ -> ](2014-07-28, 14:08)Martijn Wrote: [ -> ]I think they mentioned on their website that you needed to manually update from v12.2 to 13.1 (some changes in update system)
maybe i should have said it "could be" that you need to manually update.
This is something we have no control over. So don't complain about that here.
Besides ronie was talking about the add-on, not the OE version. Don't confuse sytem updates with add-on updates.
If you run an old OE version you will not receive any more updates for certain add-ons.
I have no idea how it works on a pi but if you have actually read http://wiki.openelec.tv/index.php?title=...te_Methods it should be easy as i have been doing the manual update since version 2.0 (because i use nightly builds)
2014-07-29, 03:11
Hi
Done, its was a semi manual update (read that to mean i didnt need to remove the SD card, but it does wipe out all settings).
2-3 hours work (only a TV remove for all typing)
Download update, copy files in to SD card share, restart system (updated)
Reset all config
Loads all add-ins and set them all up manually
The above assumes you dont store Movies or Photos on the SD card, if so theres a backup needing to be done, i didnt need to do this.
So i now have the latest weather App, the new version is alot faster, it loads the EPG like lighting unlike version 12, so thats nice.
Reset all config
2014-10-14, 09:48
This add-on stopped working for me yesterday. Using XBMC's debugging and Weather Underground's Add-on's logging option, here is what my xbmc.log said:
Did they update their service or something and the Add-on hasn't updated for it? As there is no way to create an account I am unsure how I exceeded any rate plan.
01:47:11 T:2744994624 DEBUG: weather.wunderground: forecast data:
"response": {
"version":"0.1",
"termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
"features": {
"error": {
"type": "invalidkey"
,"description": "this key is not valid due to exceeding rate plan"
