Hey guys What do I need to change in my old core factory and playiso.bat from eden to work with frodo? I have just rolled back to frodo 12.0 after reading the last few pages here. I had saved the player core and playiso from my old install. these 2 were all I needed because my entire library is iso. I have also made sure the correct drive letter for virtual clone drive is entered in the files. its not working yet though it acts like it is opening an external player but never does.
Edit: Almost forgot here is the playercore.xml and playiso.bat I am trying to use. If anyone has time to make me one that only does iso that would be amazing. I really dont need the other functions I just want to play all my iso files dvd and bluray with tmt5 or tmt6 which I have not tried yet.
playercore
<playercorefactory>
<players>
<player name="ISO_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Bleed\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
<hidexbmc>false</hidexbmc>
<hideconsole>true</hideconsole>
<warpcursor>none</warpcursor>
</player>
<player name="BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Bleed\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
<args>"{1}"</args>
</player>
<player name="Disc_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Bleed\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<args>"{1}"</args>
</player>
<player name="Universal_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe</filename>
<args>"{1}"</args>
</player>
</players>
<rules action="prepend">
<!-- Bluray ISO -->
<rule filenames="iso" filetypes="iso" player="ISO_Player"/>
<!-- Bluray BDMV -->
<rule filenames="bdmv" filetypes="bdmv" player="BDMV_Player"/>
<!-- Bluray M2TS -->
<rule filenames="m2ts" filetypes="m2ts" player="Universal_Player"/>
<!-- Bluray MKV -->
<rule filenames="mkv" filetypes="mkv" player="Universal_Player"/>
<!-- Bluray AVI -->
<rule filenames="avi" filetypes="avi" player="Universal_Player"/>
<!-- Bluray TS -->
<rule filenames="ts" filetypes="ts" player="Universal_Player"/>
<!-- Bluray Disc -->
<rule filenames="BD" name="E:\\.*" filetypes="bdmv" player="Disc_Player"/>
</rules>
</playercorefactory>
Playiso
echo off
rem you can place your PlayISO file in \Roaming\XBMC\userdata\
rem you need to put the correct VCDMount drive letter in the command below
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe" N:
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
