2014-08-14, 18:54
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154
2014-08-14, 22:44
After hours of messing around I have discovered the issue is with DVDFab which no longer appears to mount the image. I am now using the Elaborate Bytes virtual drive which mounts the image but sometimes results in XBMC minimising to the desktop and shows a command prompt for a few seconds before PowerDVD starts...
C:\Program Files (x86)\XBMC\GO TO unmounted
C:\Program Files (x86)\XMBC>IF EXIST E:\BDMV\. GOTO mounted
Is there any way to prevent this annoyance from occuring??
2014-08-15, 17:02
Ok, this is my last update in the hope that someone will offer some advice on this forum. The code still doesn't work correctly. The ISO gets mounted but the windows command prompt continuously loops in the background. When I close PowerDVD the windows command prompt has to be closed before it returns to XMBC. Still looking for some help please from this forum :-(
2014-08-16, 01:06
OK, keeping in mind I know next to nothing about writing this kind of code, looking at this line:
Is that a period after "BDMV\" and should it be there?
2014-08-16, 10:56
Hi Bruce, I've tried everything I can but still no good. I've just downloaded a trial version of TMT to see if that made any difference. Again the image gets mounted but excatly the same issue with the 'looping' windows command message.
Come on people, I thought this was a forum to help people like me. That's why I joined! Someone must have an idea what is wrong with the code? ;-(
2014-08-16, 11:57
i will try and find a moment today to test iso mounting as I've not used it for a while and then post my code up but i believe it does work from memory
2014-08-16, 12:32
Thanks Orby really appreciate some help. I've been trying for hours to fix this. I need to use the external player for my 3D Blu-rays so I thought that I may as well use for all my ISO's (Dvd's & Blurays).
2014-08-16, 14:10
had a quick play and i cannot get the iso to mount at the moment
2014-08-16, 14:37
for me at the moment and i'm not sure why it is ignoring my iso rule and is using my BDMV player/bat file
2014-08-16, 16:05
well i had mine all working as wanted, just about to post my files and now it's ignoring the playiso rule again and using BDMV.bat instead of playiso.bat for ISO's
2014-08-16, 17:27
okay starting from scratch as i couldn't get my old set up working so tested yours i changed the player core factory to
any my play iso is this
all working and much easier to manage than the old way i used to do it
<playercorefactory>
<players>
<player name="ISO_BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\************\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
<hidexbmc>false</hidexbmc>
</player>
</players>
<rules action="prepend">
<!-- Bluray ISO/BDMV -->
<rule filetypes="iso|bdmv|mpls" player="ISO_BDMV_Player"/>
</rules>
</playercorefactory>
@echo off
rem you can place your PlayISO file in \Roaming\XBMC\userdata\
rem you need to put the correct VCDMount drive letter in the command below
Set file=%1
Set dummy=%file:iso=%
IF NOT %dummy% == %file% (GOTO playiso) ELSE (goto next)
:next
Set file=%1
Set dummy=%file:mpls=%
IF NOT %dummy% == %file% (GOTO plaympls) ELSE (goto playbdmv)
:playiso
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 6\uTotalMediaTheatre6.exe" F:
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
GOTO end
:plaympls
set pth=%1
set pth=%pth:~1,-25%
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 6\uMCEPlayer6.exe" "%pth%" exit
GOTO end
:playbdmv
set pth=%1
set pth=%pth:BDMV\MovieObject.bdmv=%
set pth=%pth:BDMV\index.bdmv=%
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 6\uMCEPlayer6.exe" %pth% exit
GOTO end
:end
exit
2014-08-16, 20:55
Now i got a code thats working great with PDVD14.
PlayBD.bat
PlayDVD.bat
playercorefactory
What i'm missing now is a way to make PDVD exit when i press stop on my remote..
PlayBD.bat
@echo off
rem you can place your PlayDisc file in \Roaming\XBMC\userdata\
"C:\Program Files (x86)\CyberLink\PowerDVD14\PDVDLP.exe" AUTOPLAY BD G:\
PlayDVD.bat
@echo off
"C:\Program Files (x86)\CyberLink\PowerDVD14\PDVDLP.exe" AUTOPLAY DVD G:\
playercorefactory
<playercorefactory>
<players>
<player name="BD_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\XBMC\AppData\Roaming\XBMC\userdata\playBD.bat</filename>
<args>"{1}" /fullscreen</args>
<forceontop>false</forceontop>
<hidecursor>false</hidecursor>
</player>
<player name="DVD_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\XBMC\AppData\Roaming\XBMC\userdata\playDVD.bat</filename>
</player>
<player name="Universal_Player" type="ExternalPlayer" audio="false" video="false">
<filename>C:\Program Files (x86)\CyberLink\PowerDVD14\PowerDVD14.exe</filename>
</player>
</players>
<rule bd="true" player="BD_Player"/>
<rule dvd="true" player="DVD_Player"/>
</rules>
2014-08-16, 22:52
(2014-08-16, 17:27)orby Wrote: [ -> ]okay starting from scratch as i couldn't get my old set up working so tested yours i changed the player core factory to
Code:<playercorefactory>
<players>
<args>"{1}"</args>
</player>
</players>
</rules>
Code:@echo off
Set file=%1
:next
Set file=%1
:playiso
GOTO end
:plaympls
set pth=%1
GOTO end
:playbdmv
set pth=%1
GOTO end
:end
exit
Orby I modified the code slightly so that I use PowerDVD14 and now works like a gem. You're a star! ;-) I've just got to add a bit of extra code so that I can launch three videos using DVDFab Media Player. I guess I can add this in the Playercorefactory settings under Filenames?
This is the code which now works;
Playercorefactory
<playercorefactory>
<players>
<filename>C:\Users\Animal\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
</player>
</players>
</rules>
PlayISO.Bat
Set file=%1
:next
Set file=%1
:playiso
"C:\Program Files (x86)\CyberLink\PowerDVD14\Movie\PowerDVD Cinema\PowerDVDCinema.exe" E:
GOTO end
:plaympls
set pth=%1
"C:\Program Files (x86)\CyberLink\PowerDVD14\Movie\PowerDVD Cinema\PowerDVDCinema.exe" "%pth%" exit
GOTO end
:playbdmv
set pth=%1
"C:\Program Files (x86)\CyberLink\PowerDVD14\Movie\PowerDVD Cinema\PowerDVDCinema.exe" %pth% exit
GOTO end
:end
exit
I also found that completely uninstalling XMBC seems to help.
Thanks again Orby, much appreciated ;-)
2014-08-16, 23:25
No worries glad it's working
i'm not sure which would be the correct way to add different file types i let XBMC handle MKV's etc i may look into a different player to handle them though if i get a chance
but it's either expand what you already have and include the file types in the rule inside playercorefactory and add the info to playiso.bat or create a new player and rule in playercore and create a new .bat file to call upon
2014-08-16, 23:31
(2014-08-16, 23:25)orby Wrote: [ -> ]No worries glad it's working
Funnily enough I have just done the above and it kind of works. XBMC now gives me the option to select either PowerDVD or DVDFab as my external player. These both work however is it possible that I can configure the default player as DVDFab just for specific videos?
This is the code I've used for another external player (i've created a separate DVDFab.bat file). You will see I have one video at the moment (Men In Black 3) as a specific filename that I am trying to launch automatically using DVDFab but I have to select in XMBC.
<playercorefactory>
<players>
<player name="PowerDVD" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Animal\AppData\Roaming\XBMC\userdata\PowerDVD.bat</filename>
<args>"{1}"</args>
</player>
<player name="DVDFab" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Animal\AppData\Roaming\XBMC\userdata\DVDFab.bat</filename>
<args>"{1}"</args>
</player>
</players>
<rule filetypes="iso|bdmv|mpls" player="PowerDVD"/>
<rule filenames="Men In Black 3" player="DVDFab"/>
</rules>
It's not the end of the world but it would be useful.
