Hey Blu, just when you thought you'd heard the last of me
I'm having problems using powerdvd12 as my external player for bluray isos. Using the codes in these posts i can get powerdvd to launch, but when i press play it tells me there is no disc in drive k:
I have a feeling its something to do with the image mounting.
Ideally i want xbmc to play everthing apart from bluray discs, dvds and blu ray .iso
here is my
<playercorefactory>
<players>
<player name="BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<!-- You can place your PlayBDMV file anywhere -->
<filename>C:\Users\Home\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
<args>"{1}"</args>
<hidexbmc>true</hidexbmc>
<hideconsole>true</hideconsole>
<warpcursor>none</warpcursor>
</player>
<player name="Universal_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\CyberLink\PowerDVD12\PDVDLaunchPolicy.exe</filename>
<args>"{1}"</args>
</player>
<player name="ISO_Player" type="ExternalPlayer" audio="false" video="true">
<!-- You can place your PlayISO file anywhere -->
<filename>C:\Users\Home\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
</player>
<player name="Disc_Player" type="ExternalPlayer" audio="false" video="true">
<!-- You can place your PlayDisc file anywhere -->
<filename>C:\Users\Home\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<args>"{1}"</args>
</player>
</players>
<rules action="prepend">
<rule filetypes=".*bdmv.*" player="BDMV_Player"/>
<rule filetypes=".*iso.*" player="ISO_Player"/>
<rule filetypes=".*m2ts.*" player="Universal_Player"/>
<rule filetypes=".*mkv.*" player="Universal_Player"/>
<rule filetypes=".*avi.*" player="Universal_Player"/>
<rule filetypes=".*ts.*" player="Universal_Player"/>
<rule name="Blu-Ray" filename="K:\\.*" filetypes="bdmv" player="Disc_Player"/>
</rules
</playercorefactory>
playiso.bat
echo off
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program Files (x86)\CyberLink\PowerDVD12\PDVDLaunchPolicy.exe" K:
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
Thanks in advance, and i will polish your shoes and iron your pants every morning
