@JoeBlow-
Can you verify your files and TMT5 settings as mentioned in my
post #609.......
@Serzh,
It's a good idea.....can you create .xml and .cmd files to playback bluray .bdmv, .iso, .mkv and .m2ts using TMT5? You can upload the .xml and .cmd files to
SendSpace and post the link in here.....
If someone want to try your codes, they can download from SendSpace.....
The only difference I have under the "type" column is my Player Core Factory is XML File and not XML Document. Are the files suppose to go inside the userdata folder, or inside the xbmc folder?
(2012-07-27, 02:56)JoeBlow42069 Wrote: [ -> ]The only difference I have under the "type" column is my Player Core Factory is XML File and not XML Document. Are the files suppose to go inside the userdata folder, or inside the xbmc folder?
Yes, all the files should be in AppData\Roaming\XBMC\userdata folder. The playercorefactory should be playercorefactory.xml in the file properties....
I've done all these things and TMT5 still isn't launching. What else might be wrong?
(2012-07-27, 05:05)JoeBlow42069 Wrote: [ -> ]I've done all these things and TMT5 still isn't launching. What else might be wrong?
Do as below to verify the codes...
1. double click- playbdmv.bat (it'll launch TMT5)
2. double click- playercorefactory.xml (it'll launch the code with IE, and it will display the entire codes)
double clicking playbdmv.bat does not run TMT5, instead i get a prompt to "run" the program, i click run and nothing happens. Double clicking playercorefactory.xml does launch the code.
bluray
Quote: It's a good idea..
thank you, it is really easy to use.
Quote:@Serzh,
It's a good idea.....can you create .xml and .cmd files to playback bluray .bdmv, .iso, .mkv and .m2ts using TMT5? You can upload the .xml and .cmd files to SendSpace and post the link in here.....
If you someone want to try your codes, they can download from SendSpace.....
Why not just copy the text in batch? In Russia everyone is doing so
In any case there is a link "Архив.zip" in post number 801 in link my original theme.
You can download and post here himself.
Good Luck.
JoeBlow42069
maybe
error the text in batch Post: #810 "D:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe" %pth% exit
need to move to the next line the word "exit"
exit
@Serzh,
It would be very helpful to others if you can create .xml and .cmd files to playback bluray .bdmv, .iso, .mkv and .m2ts using TMT5. You can upload the working .xml and .cmd files to
If someone want to try your codes, they can download it from SendSpace.....
[align=right]
(2012-07-27, 05:26)JoeBlow42069 Wrote: [ -> ]double clicking playbdmv.bat does not run TMT5, instead i get a prompt to "run" the program, i click run and nothing happens. Double clicking playercorefactory.xml does launch the code.
That is your problem. When you double click playbdmv.bat it should launch TMT5 automatically.....
Here is the correct codes for PlayBDMV.bat-
echo off
set pth=%1
set pth=%pth:BDMV\index.bdmv=%
Quote:@Serzh,
It would be very helpful to others if you can create .xml and .cmd files to playback bluray .bdmv, .iso, .mkv and .m2ts using TMT5. You can upload the working .xml and .cmd files to SendSpace and post the link in here.....
I have already answered this question in
Post: #817
It's really very unclear what for download cmd files, if you can just paste in notepad
This is what my PlayBDMV.bat has:
echo off
rem you can place your PlayBDMV file in \Roaming\XBMC\userdata\
set pth=%1
I deleted line #2 and saved, but still nothing happens when I double click.
(2012-07-27, 18:37)JoeBlow42069 Wrote: [ -> ]This is what my PlayBDMV.bat has:
@echo off
set pth=%1
Is this "D:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe" the correct location of your TMT5 exe? Is PlayBDMV.bat properties show playbdmv.bat in it?
@echo off
set pth=%1
just run of such PlayBDMV.bat work?
@echo off
exit
are you sure that the path is correct?
