2012-11-15, 05:23
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154
2012-11-15, 05:46
I'm not sure you can help me, but first off, frodo alphas don't correctly send information about mpls files or bdmv files. This is what gets sent:
NOTICE: CExternalPlayer::ExecuteAppW32: "C:\Users\Home Theatre\AppData\Roaming\XBMC\userdata\PlayDisc.bat" "bluray://D%3a%5cMovies%5cIndiana%20Jones%20Trilogy%5cRaiders%20of%20the%20Lost%20Ark%20(1981)%5cIndiana_Jones_Lost_Ark%5c/BDMV/PLAYLIST/00800.mpls"
I don't have anything mapped, so it should be launching it as D:\Movies\Indiana Jones Trilogy\Raiders of the Lost Ark (1981)\BDMV\PLAYLIST\00800.mpls Once it gets to mpc-hc, it of course tells me there's no such file. I've asked for help in support and got none and I submitted a bug report, and it hasn't been picked up yet. If it's not a bug and my playercorefactory is wrong, then I'd greatly appreciate the help.
I decided to use yours and see where I could get since I really want the iso mounting capability. I use WinCDEmu though for mounting because it's more versatile. I also use mpc-hc to play everything.
Here's my playercore
<playercorefactory>
<players>
<player name="ISO_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Home Theatre\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
<hidexbmc>false</hidexbmc>
</player>
<player name="BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Home Theatre\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
<args>"{1}"</args>
</player>
<player name="Disc_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Home Theatre\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<args>"{1}"</args>
</player>
<player name="Universal_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\MPC-HC\mpc-hc.exe</filename>
<args>"{1}"</args>
</player>
</players>
<rules action="prepend">
<!-- Bluray ISO -->
<rule filenames="iso" filetypes="iso" player="ISO_Player"/>
<!-- Bluray BDMV -->
<rule filenames="bdmv" filetypes="bdmv" player="BDMV_Player"/>
<!-- Bluray M2TS -->
<rule filenames="m2ts" filetypes="m2ts" player="Universal_Player"/>
<!-- Bluray MKV -->
<rule filenames="mkv" filetypes="mkv" player="Universal_Player"/>
<!-- Bluray AVI -->
<rule filenames="avi" filetypes="avi" player="Universal_Player"/>
<!-- Bluray TS -->
<rule filenames="ts" filetypes="ts" player="Universal_Player"/>
<!-- Bluray Disc -->
<rule player="Disc_Player"/>
</rules>
</playercorefactory>
Here's iso.bat, which I can't get to work yet. Command line for wincdemu is vmnt.exe <image path> If I let xbmc handle the iso on its own, it sends the wrong stream to mpc-hc. Mpc-hc just reports File Not Found when I use iso.bat
Thanks for the help.
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
<args>"{1}"</args>
</player>
<args>"{1}"</args>
</player>
<args>"{1}"</args>
</player>
</players>
<!-- Bluray ISO -->
<!-- Bluray MKV -->
<!-- Bluray AVI -->
<!-- Bluray TS -->
</rules>
2012-11-15, 18:12
(2012-11-15, 05:46)corpgator Wrote: [ -> ]Here's iso.bat, which I can't get to work yet. Command line for wincdemu is vmnt.exe <image path> If I let xbmc handle the iso on its own, it sends the wrong stream to mpc-hc. Mpc-hc just reports File Not Found when I use iso.batWhere is PlayISO.bat? As far as I know, everyone is having issue with Frodo when they tried to use it with external player. Eden 11.0 is fine....
2012-11-15, 23:52
@bluray
I tried your suggestion to enable the setting the pop up is the same external player active click ok to finish
but stil TMT 5 dont start at all
2012-11-16, 00:45
(2012-11-15, 18:12)bluray Wrote: [ -> ](2012-11-15, 05:46)corpgator Wrote: [ -> ]Here's iso.bat, which I can't get to work yet. Command line for wincdemu is vmnt.exe <image path> If I let xbmc handle the iso on its own, it sends the wrong stream to mpc-hc. Mpc-hc just reports File Not Found when I use iso.batWhere is PlayISO.bat? As far as I know, everyone is having issue with Frodo when they tried to use it with external player. Eden 11.0 is fine....
It's in the same place as playercorefactory. If everyone is having the problem, then it's the same issue with Frodo sending bad strings to the external when trying to play it. That's what it looks like in the log anyway: all slashes, \ /, are replaced by random numbers and % signs. Hopefully they fix it soon because Frodo is pretty useless for Bluray movies with an external player right now.
2012-11-16, 01:41
Hi bluray,
I also have a problem with playing bluray through XBMC + TMT v.5.3.1.172 - TMT remains in the background and I must to exit XBMC. I tried several playercorefactory but without success.
Here si my playercorefactory.xml :
<playercorefactory>
<players>
<filename>C:\Users\HTADM\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
</player>
<filename>C:\Users\HTADM\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
<args>"{1}"</args>
</player>
<filename>C:\Users\HTADM\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<args>"{1}"</args>
</player>
<filename>C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uTotalMediaTheatre5.exe"</filename>
<args>"{1}"</args>
</player>
</players>
<!-- Bluray ISO -->
<!-- Bluray TS -->
<rule filenames="BD" name="E:\\.*" filetypes="bdmv" player="Disc_Player"/>
</rules>
Thanks for your help.
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
<args>"{1}"</args>
</player>
<args>"{1}"</args>
</player>
<args>"{1}"</args>
</player>
</players>
<!-- Bluray ISO -->
<!-- Bluray TS -->
</rules>
2012-11-16, 03:09
(2012-11-15, 23:52)unrealkiller Wrote: [ -> ]@blurayUsually when you Check "Use fullscreen window rather than true fullscreen" in XBMC system/settings/system/video output, the external player active error disappear. Can you make sure that TMT5 is not running in Windows Task Manager/Processes before you startup XBMC?
Since you only needs external player to playback BDMV, you can use the simple codes below-
<playercorefactory>
<players>
<filename>C:\Users\xxxx\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
<args>"{1}"</args>
</player>
</players>
<rule filetypes="bdmv" player="BDMV_Player"/>
</rules>
(2012-11-16, 01:41)memphisto007 Wrote: [ -> ]Hi bluray,What file are you trying to playback using TMT5? Make sure to Check "Use fullscreen window rather than true fullscreen" in XBMC system/settings/system/video output......
2012-11-16, 03:31
They got to my bug today, so blu-ray in folder structure should play correctly in external with next nightly. I think they might have fixed iso's as well. That is for Frodo of course.
2012-11-16, 04:37
(2012-11-16, 03:31)corpgator Wrote: [ -> ]They got to my bug today, so blu-ray in folder structure should play correctly in external with next nightly. I think they might have fixed iso's as well. That is for Frodo of course.Most files works fine with Frodo, but BDMV and disc folder still have problem....I'm still sticking to the most stable Eden...
2012-11-16, 09:43
[/quote]
I tried Bluray BDMV/ISO files everything playing fine but it backround and im using "Use fullscreen window rather than true fullscreen" . Any ideas?
2012-11-16, 17:10
(2012-11-16, 09:43)memphisto007 Wrote: [ -> ]I'm not quite sure what you mean by background. If you have not set TMT5 to launch "auto fullscreen" in TMT5 setting/playback, you need to set it to "auto fullscreen"...(2012-11-16, 01:41)memphisto007 Wrote: [ -> ]Hi bluray,What file are you trying to playback using TMT5? Make sure to Check "Use fullscreen window rather than true fullscreen" in XBMC system/settings/system/video output......
2012-11-16, 17:47
(2012-11-16, 04:37)bluray Wrote: [ -> ](2012-11-16, 03:31)corpgator Wrote: [ -> ]They got to my bug today, so blu-ray in folder structure should play correctly in external with next nightly. I think they might have fixed iso's as well. That is for Frodo of course.Most files works fine with Frodo, but BDMV and disc folder still have problem....I'm still sticking to the most stable Eden...
Blu-rays in folder structure are now working fine in the latest nightly. The only thing not working are blu-rays in iso's. They will be fixed later they said. So if you have to have blu-ray isos, stick with Eden. But playing dbmv and mpls from a blu-ray folder not on an iso works.
2012-11-16, 23:59
(2012-11-16, 17:10)bluray Wrote: [ -> ](2012-11-16, 09:43)memphisto007 Wrote: [ -> ]I'm not quite sure what you mean by background. If you have not set TMT5 to launch "auto fullscreen" in TMT5 setting/playback, you need to set it to "auto fullscreen"...(2012-11-16, 01:41)memphisto007 Wrote: [ -> ]Hi bluray,What file are you trying to playback using TMT5? Make sure to Check "Use fullscreen window rather than true fullscreen" in XBMC system/settings/system/video output......
I have this setting. TMT starts in fullscreen, but XBMC is not hiding. I hear sound but XBMC remains on the screen.
2012-11-17, 19:56
(2012-11-16, 23:59)memphisto007 Wrote: [ -> ]I have this setting. TMT starts in fullscreen, but XBMC is not hiding. I hear sound but XBMC remains on the screen.You need to replace this line "<hidexbmc>false</hidexbmc>" with this line "<hidexbmc>true</hidexbmc>"......
2012-11-19, 00:49
Thanks, it works as it should. Cool.
