I have just purchase a Dell Zino PC which I plan to use as a HTPC running XMBC. I currently have about 2TB of music and movies on a Netgear Nas box and I am currently trying to clean up the file names to have ready when I install XBMC. What I need to know, do I need to remove all the files that I used to use when running a Tvix media box (i.e folder.jpg, fanart.tvix etc.) or can I leave them there.
Thanks for your help.
It shouldn't be a problem....just a bit messier. FYI..your Folder.jpg files may be used by XBMC.
for Movies, I use IMDB scrapper. filenames are extact hit to imdb, like "Harry Potter and the Deathly Hallows Part 2 (2011)".iso
Scrapers always automatically..
Thanks for the help guys.
Bolter
How do you change scrapers? There is only 1 shown to choose from and I can not find any way to manually add IMDB or pick it from a list.
HTElectrical Wrote:How do you change scrapers? There is only 1 shown to choose from and I can not find any way to manually add IMDB or pick it from a list.
When setting sources there should be a button 'get more'. That will bring you to the add-ons section to instal other scrapers. You can also go directly to the add-ons section and instaal a scraper
Didn't have my settings configured to email me, so I did not know that anyone had answered. Thanks, I will give that a try.
