Full Version: Video Freezes after 8 seconds
Hello -
Thanks for all the time people put into this great product!
I am having issues -
This is a new install on a "new" machine. Things ran fine, it was running xp. I wiped it clean and installed windows 7 along with the daily from the 10th. I also installed the daily build from the 10th on another computer.
My videos play perfect on the other computer, and on the one I am having issues on play fine in vlc. I cannot get any video to play for more than 8 seconds in xbmc on this troubled computer (that used to work before upgrading the os/xbmc)
http://pastebin.com/mF9P1KED
stuff that might be relavent:
21:47:25 T:3548 DEBUG: CVideoDatabase::LoadVideoInfo, got episode info!
21:47:25 T:3548 DEBUG: Title = High Noon in the High Desert
21:47:25 T:3548 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
21:47:25 T:3548 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
21:47:25 T:3548 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
21:47:29 T:3548 DEBUG: ------ Window Deinit (Pointer.xml) ------
21:47:29 T:4008 DEBUG: CPullupCorrection: detected pattern of length 1: 33366.67, frameduration: 33366.666667
21:47:33 T:4008 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
21:47:33 T:4008 INFO: CDVDPlayerVideo - Stillframe detected, switching to forced 29.970030 fps
21:47:33 T:4008 DEBUG: CPullupCorrection: pattern lost on diff 166833.333333
21:47:37 T:4008 DEBUG: CPullupCorrection: detected pattern of length 1: 33366.67, frameduration: 33366.666667
any thoughts?
thanks!
The relevant errors are:
NOTICE: running thread: CDVDPlayerAudio::Process()
NOTICE: Creating audio device with codec id: 86017, channels: 2, sample rate: 48000, no pass-through
ERROR: DirectSoundCreate() Failed (0x88780078)
ERROR: CThread::staticThread : Access violation at 0x01347c9a: Reading location 0x00000000
You have a problem with the audio config. Note that Win7 helpfully disables audio devices if it decides that no speakers or headphones are connected. This can cause the problems you're seeing. Try plugging in a pair of headphones and see if that affects the playback.
JR
Interesting!
I didnt have speakers plugged in. Nice catch!
