2015-01-02, 06:38
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
2015-01-02, 10:50
Fair enough. That would explain it. It must be skin specific. I'm using skin Ace and in the bottom right hand corner of the screen on the program home page when I hover over weather it says "Season: Winter". Thanks
2015-01-02, 13:07
Well happy to set the labels if you let me know what they are...
2015-01-03, 03:37
I'm not sure if anyone else is having this issue, I do fresh install and plugin works great. As soon as I reboot my box the script fails and I can't retrieve weather information. I currently don't have the weather showing on any of my Kodi installs due to it stopping after a reboot. Any help much appreciated as its my first plug in I install and use the most.
2015-01-03, 04:24
Not that I know of. Best thing is a debug log of it happening, I'm sure we can work it out
2015-01-03, 05:22
This seems like a nice plug in, but can someone enlighten me as to where the folder referenced in "COnfluence 720p" might be hidden or revealed on a debian (Kodi) system?
2015-01-03, 06:26
(2015-01-03, 04:24)bossanova808 Wrote: [ -> ]Not that I know of. Best thing is a debug log of it happening, I'm sure we can work it out
Thanks for you your reply I did a fresh install of Openelec on my Intel NUC just installed OZ weather and rebooted and issue has happened again. I have attached link of my log file: http://xbmclogs.com/show.php?id=392284
2015-01-04, 01:30
(2015-01-03, 05:22)guiguy Wrote: [ -> ]This seems like a nice plug in, but can someone enlighten me as to where the folder referenced in "COnfluence 720p" might be hidden or revealed on a debian (Kodi) system?
No I can't as I don't have a linux system. However I would suggest it is something like this:
~/.kodi/addons
under something like skin.confluence/720
2015-01-04, 02:24
2015-01-04, 04:06
@bossanova808 sorry about that I used the log uploader addon not sure how to do it otherwise. If you tell me what you require I will do that for you.
2015-01-04, 04:49
Guides here:
http://kodi.wiki/view/Log_file
2015-01-06, 07:54
2015-01-06, 08:18
@uksa007
I merged it, thanks
The skin will probably use an include file for setting the labels - basically if you grep for any weather related labels (like temp, or precipitation etc), you should find the spot quickly enough, then I just need a list of the used labels to set.
@Zifanite - this goes for you too and the seasons.
I merged it, thanks
2015-01-06, 09:31
(2015-01-06, 08:18)bossanova808 Wrote: [ -> ]@uksa007
I found there is a buch of stuff in the IncludesWeather.xml
This is just a small bit of it, would you like the whole file put somewhere?
<?xml version="1.0"?>
<!-- Aeon MQ 5 Helix 6.1.0-->
-<includes>
<!-- ######################################################################### Current #########################################################################-->
<!-- Widget Common Values -->
-<include name="TWC.ScrollbarCommon">
<include>ScrollBar_Vertical</include>
<posx>630</posx>
<posy>50</posy>
<width>65</width>
<height>465</height>
</include>
-<include name="TWC.LoadingLabelCommon">
<posx>5</posx>
<posy>265</posy>
<width>800</width>
<height>80</height>
<font>Font_15</font>
<align>center</align>
<aligny>center</aligny>
<label>$LOCALIZE[31863]</label>
<wrapmultiline>true</wrapmultiline>
</include>
-<include name="TWC.Current.DailyWeekdayBG">
<colordiffuse>30FFFFFF</colordiffuse>
<texture border="10">DailyWeekdayBG.png</texture>
<include>TWC.Current.DailyWeekendBG</include>
</include>
-<include name="TWC.Current.DailyWeekendBG">
<posy>0</posy>
<posx>0</posx>
<width>114</width>
<height>278</height>
<texture border="10">DailyWeekendBG.png</texture>
<aspectratio>stretch</aspectratio>
<include>TWC.Current.DailyDayLabelsCommon</include>
</include>
-<include name="TWC.Current.DailyPrecipitationCommon">
<posy>140</posy>
<height>30</height>
<textcolor>FFFFFAF0</textcolor>
<font>Font_23</font>
</include>
-<include name="TWC.Current.DailyHighLabelsCommon">
<posy>190</posy>
<height>30</height>
<textcolor>FFFF0000</textcolor>
</include>
-<include name="TWC.Current.DailyLowLabelsCommon">
<posy>240</posy>
<height>30</height>
<textcolor>FF00AFFF</textcolor>
<font>Font_20</font>
</include>
-<include name="TWC.Current.DailyIconCommon">
<posy>60</posy>
<height>72</height>
<aspectratio>keep</aspectratio>
</include>
-<include name="TWC.Current.DailyDayLabelsCommon">
<posx>-5</posx>
<posy>5</posy>
<height>20</height>
<width>120</width>
</include>
-<include name="TWC.Current.DailyDateLabelsCommon">
<posy>25</posy>
</include>
-<include name="TWC.Current.ConditionLabelsCommon">
<posx>0</posx>
<posy>-90</posy>
<height>30</height>
<width>300</width>
<align>right</align>
<textcolor>$VAR[value_headercolor]</textcolor>
<focusedcolor>white</focusedcolor>
<texturefocus>-</texturefocus>
<texturenofocus>-</texturenofocus>
</include>
-<include name="TWC.Current.ConditionValuesCommon">
<align>left</align>
<textcolor>FFf5f5f5</textcolor>
<include>TWC.Current.ConditionLabelsCommon</include>
</include>
-<include name="TWC.Current">
-<control type="group">
<posx>290</posx>
<posy>60</posy>
<visible>StringCompare(Window.Property(Weather.CurrentView),current)</visible>
<animation time="300" reversible="true" effect="fade">VisibleChange</animation>
<posx>-30</posx>
<posy>-20</posy>
<posx>10</posx>
-<control type="label">
<description>current temp value</description>
<posx>10</posx>
<posy>80</posy>
<width>180</width>
<height>40</height>
<font>Font_50</font>
<label>$INFO[Window.Property(Current.Temperature)]$INFO[System.TemperatureUnits]</label>
<animation time="0" effect="slide" condition="IntegerGreaterThan(Window.Property(Current.Temperature),-100) + !IntegerGreaterThan(Window.Property(Current.Temperature),9)" end="-17,0" start="0,0">Conditional</animation>
</control>
<!-- Local -->
<posx>50</posx>
<posy>45</posy>
<width>330</width>
<height>25</height>
<align>left</align>
<scroll>false</scroll>
<label>[UPPERCASE]$INFO[Window(Weather).Property(Location)][/UPPERCASE]</label>
<scrollout>false</scrollout>
<scroll>true</scroll>
</control>
<description>current feels like label</description>
<posx>30</posx>
<posy>135</posy>
<width>140</width>
<height>40</height>
<font>Font_18</font>
<label>[B]$LOCALIZE[402][/B]</label>
</control>
2015-01-06, 12:33
Looks like the labels are in another file (or two)
You'll figure it out - I need the labels. Don't want to spend time digging through files I don't use, but happy to do the work if the labels I need are given to me
