The mini forecast that shows when you pause a movie is a great idea. You've done a great job with this add on. Thanks heaps for the quick fix btw.
Yeah I like it
- I enourage you to jsut copy the skin files to standard Confluence and/or mod your own Confluence rather than use the one in my repo though as I am slowly customising various things you may not like. I am putting in conditionals so that most of the major changes are off by default and I have my own settings panel now, so it's not a huge deal, but there may be updates to mainline Confluence I miss for a while as they update it - and I am using PVR Confluence as well, which is of course not suitable for everyone.
I couldnt do that as I couldnt find a confluence folder or a 720P folder in my xbmc on atv2.
Troyp42 Wrote:I couldnt do that as I couldnt find a confluence folder or a 720P folder in my xbmc on atv2.
Troyp42, not sure if this will help...
XBMC, like many programs, has two main file locations: one where the main program and associated files are installed and one where the per-user profile files are stored.
Add-ons like
bossanova808's
OzWeather and others that are not part of the default XBMC install are in the
addons folder in your user profile location. However, add-ons like the default
Confluence skin are in the
addons folder in the main XBMC install location.
For example, on my Windows 7 machine, XBMC is installed in...
C:\Program Files (x86)\XBMC
... whereas all of my per-user settings, including all extra add-ons and their settings and all user preferences are in...
C:\Users\[username]\AppData\Roaming\XBMC
So, for
ATV2 , the
OzWeather skin files are at...
/private/var/mobile/Library/Preferences/XBMC/addons/weather.ozweather/Skin files for extended features (copy to Confluence 720p)
... and you would copy those files to the
Confluence skin's
720p folder at...
/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/skin.confluence/720p
NB: I'm not 100% sure of the exact paths for ATV2 as I don't own one - the above locations are best that I could source from the interwebs
Mate..I found the Ozweather skin files at /private/var/mobile/Library/Preferences/XBMC/addons/weather.ozweather
And the location of my 720P folder finally at
/private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/skin.confluence/720p so thanks for that
but how do I change my skin back to the default skin before I copy these oz.weather files into my 720P folder.
I know it was only a few weeks back but I cant remember how I updated to the Bossanova808 skin in the first place. If I go into settings skin I just see a setting for the Bossanova skin only and no way to change to the default confluence skin which I assume I have to do first.
Settings -> appearance -> top group (can't remember name) -> skin
Mine was working for a day or so, but have recently started to get script failed message.
My log mentions:
10:01:17 T:8648 ERROR: Traceback (most recent call last):
File "C:\Users\Me\AppData\Roaming\XBMC\addons\weather.ozweather\default.py", line 39, in <module>
common = CommonFunctions.CommonFunctions()
AttributeError: 'module' object has no attribute 'CommonFunctions'
You Need To Update (try force refresh on the repo)- the current line in question is:
..whereas the line in your error is the what it used to be...so you are clearly using an older version. That's always the first thing to try if you're having trouble with an add on, as very often a fixed version will be available. For most people, leaving auto-updates on is the best way to go so this is automatic.
...as an add on the add on uses (parseDOM - comes with YouTube so update that too for good measure although it should be automatic) was updated recently.
It's been running smooth as here....
bossanova808 Wrote:You Need To Update (try force refresh on the repo)- the current line in question is:
I did uninstall and reinstall from you repository before I posted the log, do I need to install from the .zip file again? All my other addons have updated, I notice the YouTube addon auto updated this morning, as did my skin.
I will have another look..
Cheers.
You shouldn't need to uninstall/re-install, it should be automatic, and at most a force refresh on my repo should do it.
I'd say then that's an old log message from before the update. Restart your xbmc and let the weather refresh, see how you go (confirm the add on version is 0.3.4 - I think that's current).
If you see any new errors, let me know and post any errors in your log, plus let me know which settings (postcode, radar etc) you are using.
Cheers, I tried forcing refresh and restarted and it updated the script, tis working again.
I'm keep getting this error in my logs. Any ideas?
11:32:08 T:2879949680 M:2023313408 NOTICE: -->Python Interpreter Initialized<--
11:32:08 T:2879949680 M:2023313408 ERROR: Error Type: exceptions.SyntaxError
11:32:08 T:2879949680 M:2023313408 ERROR: Error Contents: ('invalid syntax', ('/home/bill/.xbmc/addons/weather.ozweather/default.py', 110, 23, ' except Exception as inst:\n'))
11:32:08 T:2879949680 M:2023313408 ERROR: File "/home/bill/.xbmc/addons/weather.ozweather/default.py", line 110
SyntaxError: invalid syntax
No errors here under Windows 7 or Openelec (linux, basically) - what platform are you on?
That's a pretty basic bit of the script and the syntaax is definitely correct - maybe there's a weird CR/LF thing going on, I am not sure about that '\n' bit as that's not in the source obviously, but might be coming from the xbmc log stuff.
