2011-12-14, 11:50
Hello Community
i'am running XBMC PVR successfully for more than a year on an AT3IONT-Board.
(ION v1 - VDPAU Profile B)
Since the amount of HD-movies grows in my library, i suffered some "strange" stuttering. The overall playback performance is great, but sometimes fragments appear or frames are dropped (stuttering). Cause of the fact, that this problems occur in same (movie) sequence and only in some movies, i suspect that the movie codec profile cause the problems.
To prove this i watched the problematic movies on my Workstation (3.2Ghz dual core/8800GTS - VDPAU Profile A). The 8800GTS fails completely to play the movies without stuttering. If vodpau is disabled by xbmc, the movie runs smoothly and without any fragments.
So i switched to an AMD Fusion E-350 - Platform (E35M1-M Pro). XBMC runs well, smooth overall playback but again in some movies there are this codec related problems. A fallback to un-accelerated Playback isn't possible. The CPU seemed to weak for playback.
So my question is: what options are left. Run XBMC on a 3.2GHz workstation isn't really an option cause of the fan-noise and power consumption. But a 1.6Ghz dualcore seems to weak for 1080p/720p-playback. Are there any VA-API/VDPAU cards who has a wide spectrum of supported codec variants?
Or if i re-encode the movies, are there any detailed information's which h264-encoding-parameters are to use for perfect playback?
