2011-12-14, 19:39
2011-12-15, 14:00
+1
2012-01-30, 23:06
+2.
I have some genre icons I downloaded and placed in C:\Program Files (x86)\XBMC\media\genre thumbs but they don't appear. Do I need to put them somewhere else, do something to activate them or give up as Aeon MQ3 doesn't support extra genre images?
2012-01-31, 12:20
Very simple, go to:
Settigns/Skin/Art/Use Icons for Music Genre/Use Alternative Icons
and indicate the path to the folder icons.
Maybe you need restart skin that changes take effect.
2012-01-31, 18:19
Hi MarcosQui,
Thanks for the reply and for all your hard work to produce such great skins.
I had already tried your suggestion without success. Any other suggestions for a novice user?
i'm using Eden beta 2 on win 7 with MQ3.
