2011-12-14, 20:18
I recently install XBMC on Linux Mint Debian Edition using the instructions found on the installation page...
sudo add-apt-repository ppa:team-xbmc
sudo apt-get update
sudo apt-get install xbmc
sudo apt-get update
sudo apt-get upgrade
From a usability perspective, XBMC appears to run w/o any issues, however, every time I launch the app an xbmc_crashlog is created (even when I don't watch any videos). When I do watch videos then the crashlog fills up with even more data.
Why does a crash log get created? Does it only happen when an "ERROR" is encountered?
Does anyone have any suggestions on how to suppress / fix the following errors...
Lots of these warnings when watching a video...
Thanks very much for any insight!
Eric
Here's the beginning of the crashlog...
sudo apt-get update
sudo apt-get update
23:43:33 T:140186617169952 M:8744058880 ERROR: GLX: Same window as before, refreshing context
23:43:34 T:140186038032128 M:8711921664 ERROR: WEATHER: Unable to get data: Invalid License Key.
23:43:49 T:140185769596672 M:8641888256 ERROR: AddPackets - failed to add leftover bytes to render
23:43:42 T:140185777989376 M:8644358144 WARNING: Decode - avcodec_decode_video didn't consume the full packet. size: 1056, consumed: 26
23:43:42 T:140185777989376 M:8644358144 WARNING: Decode - avcodec_decode_video didn't consume the full packet. size: 22, consumed: 26
23:43:42 T:140185777989376 M:8644358144 WARNING: Decode - avcodec_decode_video didn't consume the full packet. size: 226, consumed: 26
Eric
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Tue Dec 13 23:43:55 PST 2011
XBMC Options:
Arch: x86_64
Kernel: Linux 3.0.0-1-amd64 #1 SMP Sun Jul 24 02:24:44 UTC 2011
Release:
Distributor ID: LinuxMint
Description: Linux Mint Debian Edition
Release: 1
Codename: debian
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
23:43:33 T:140186617169952 M:8771571712 NOTICE: -----------------------------------------------------------------------
23:43:33 T:140186617169952 M:8771784704 NOTICE: Starting XBMC, Platform: Linux (Linux Mint Debian Edition, 3.0.0-1-amd64 x86_64). Built on Aug 17 2011 (Git:Unknown)
23:43:33 T:140186617169952 M:8771784704 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
23:43:33 T:140186617169952 M:8771784704 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
23:43:33 T:140186617169952 M:8771784704 NOTICE: special://masterprofile/ is mapped to: /home/weber/.xbmc/userdata
23:43:33 T:140186617169952 M:8771784704 NOTICE: special://home/ is mapped to: /home/weber/.xbmc
23:43:33 T:140186617169952 M:8771784704 NOTICE: special://temp/ is mapped to: /home/weber/.xbmc/temp
23:43:33 T:140186617169952 M:8771784704 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
23:43:33 T:140186617169952 M:8771784704 NOTICE: Log File is located: /home/weber/.xbmc/temp/xbmc.log
23:43:33 T:140186617169952 M:8771784704 NOTICE: -----------------------------------------------------------------------
23:43:33 T:140186617169952 M:8771756032 NOTICE: Setup SDL
23:43:33 T:140186617169952 M:8771768320 NOTICE: load settings...
23:43:33 T:140186617169952 M:8771768320 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:43:33 T:140186617169952 M:8771768320 NOTICE: loading special://masterprofile/guisettings.xml
23:43:33 T:140186617169952 M:8771477504 NOTICE: Getting hardware information now...
23:43:33 T:140186617169952 M:8771477504 NOTICE: Checking resolution 12
23:43:33 T:140186617169952 M:8771477504 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:43:33 T:140186617169952 M:8771477504 NOTICE: Loaded playercorefactory configuration
23:43:33 T:140186617169952 M:8771477504 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:43:33 T:140186617169952 M:8771477504 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:43:33 T:140186617169952 M:8771477504 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
23:43:33 T:140186617169952 M:8771477504 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.0.50</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_video</name>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_music</name>
</musicdatabase>
</advancedsettings>
23:43:33 T:140186617169952 M:8771477504 WARNING: VIDEO database configuration is experimental.
23:43:33 T:140186617169952 M:8771477504 NOTICE: Default DVD Player: dvdplayer
23:43:33 T:140186617169952 M:8771477504 NOTICE: Default Video Player: dvdplayer
23:43:33 T:140186617169952 M:8771477504 NOTICE: Default Audio Player: paplayer
23:43:33 T:140186617169952 M:8771477504 NOTICE: Loading media sources from special://masterprofile/sources.xml
23:43:33 T:140186617169952 M:8750669824 NOTICE: Using visual 0x51
23:43:33 T:140186617169952 M:8744058880 NOTICE: GL_VENDOR = ATI Technologies Inc.
23:43:33 T:140186617169952 M:8744058880 NOTICE: GL_RENDERER = ATI Radeon HD 5700 Series
23:43:33 T:140186617169952 M:8744058880 NOTICE: GL_VERSION = 4.1.11251 Compatibility Profile Context
23:43:33 T:140186617169952 M:8744058880 NOTICE: GL_SHADING_LANGUAGE_VERSION = 4.10
23:43:33 T:140186617169952 M:8744058880 NOTICE: GL_EXTENSIONS = GL_AMDX_debug_output etc, etc...
