Full Version: DVR file not working
i have to following information from a dvr-file which XBMC doesn't play.
General
Complete name                    : D:\Videos\12-14_12-35-45_Das Erste HD (deu)_.ts
Format                           : MPEG-TS
File size                        : 16.9 MiB
Duration                         : 11s 735ms
Overall bit rate mode            : Variable
Overall bit rate                 : 12.1 Mbps
Video
Menu ID                          : 11100 (0x2B5C)
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : [email protected]
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Format settings, GOP             : M=16, N=32
Codec ID                         : 27
Duration                         : 11s 220ms
Bit rate mode                    : Variable
Bit rate                         : 11.2 Mbps
Maximum bit rate                 : 11.5 Mbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Display aspect ratio             : 16:9
Frame rate                       : 50.000 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.243
Stream size                      : 15.0 MiB (89%)
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 2
Codec ID                         : 3
Duration                         : 11s 712ms
Bit rate mode                    : Constant
Bit rate                         : 256 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 48.0 KHz
Compression mode                 : Lossy
Delay relative to video          : -1s 104ms
Stream size                      : 366 KiB (2%)
Language                         : German
is it possible to play this file, or is there no chance because of the slow cpu?
thanks a lot
poebler
50fps is a nogo atm...
that explains everything Smile thanks
