two rather silly questions: is there any xbmcbuntu iso with Frodo and Xvba available for download? And how much performance improvements brings Xvba comparing to 'standard' XBMC installation from
http://xbmc.org ?
nope and Xvba works, while mainline with vaapi is quite broken on AMD
yes, that's what I experienced with mainline on my AMD as well. thanks
an iso would be nice though ... :-) or is it ok to take any of your old iso with Xvba and just update xbmc from your ppa? (I'd like to avoid configuring auto login, auto start etc - takes me too long and I always get stuck at some point...)
Question - is fglrx 9.0.2 (ubuntu 12.10) - is that based on catalyst 12.9? Thanks
@tutu:
AMD does not talk about 12.xy anymore (though their downloads are still named like this), it talks about 9.x.y series. So the 12.9 Quantal is a whole lot newer than what you would expect. The userspace for example of 12.9Quantal supports xorg 1.13, where as fglrx 12.10 (9.0.1.something) does not.
You see - great confusion :-)
(2012-12-31, 18:35)fritsch Wrote: [ -> ]via ssh:
sudo service lightdm stop
sudo aticonfig --set-pcs-val=MCIL,DigitalHDTVDefaultUnderscan,0
sudo aticonfig --sync-vsync=on
sudo aticonfig --set-pcs-u32=MCIL,HWUVD_H264Level51Support,1
sudo service lightdm start
you will need all three to be happy, so I mentioned them here.
Set your TV to "just scan" mode (LG) or "Fit" (Samsung) this will make sure 1:1 Pixel Mapping.
fritsch
Sorry for the delay. I was able to get this to work with you instructions with one mod at least for my setup. Instead of Underscan 0 Underscan 6 worked. Anything worked, but not zero at least for my TV, 6 scaled well. For whatever reason by default, my TV clips the output rather than having black borders.
What I still dont understand is why afterwards, I can change this through Control Center and it will take on the next session. I would have guessed the '0' setting would force it not to default and then I could change it in the same way, but at least for me I dont think it behaves this way. I have to set it to something other than '0' and then I can change it through the GUI in control center.
I think one of the last things I need to figure is why the session seizes after some time. I am guessing screen saver or power saving mode.
Thank you again Fritsch.
U may test in VMware VM.
Summary: - Ubuntu 12.10 minimal x86 / x64
- AMD / Intel / Nvidia GPU Support / VMWare (automatisch)
- XBMC Frodo (from wsnipex)
- preconfigured XBMC setting of choice (3 Skins + my Settings optional)
- LiveTV / Oscam / Sedu-Ambilight Support (Plug and Play)
- XBMC Bootscreen
- SSH Zugriff (xbmc/xbmc) + Samba Freigaben
Ablaufgerman)
- Mini ISO hier laden: https://dl.dropbox.com/u/21136636/htpc/i...master.iso
- Unetbootin hier laden: http://www.computerbase.de/downloads/sys.../?download
- Mittels Unetbootin einen Bootfähigen USB Stick erstellen (>64 MB benötigt)
- HTPC braucht auf jedenfall Zugang zu Internet
- Mittels Einmalboot-Menü (meist F8-F12) vom Stick booten, oder im Bios (Entf) bei Festplatten Priorität auf den USB Stick als erstes Bootdevice wechseln.
- Ein blaues Fenster erscheint. Automatic HTPC Installation wählen, x32 oder x64
- Netzwerk einstellen und USB stick abziehen
- geführt oder manuell partitionieren
- nach dem ersten Neustart müsste ein blauer Dialog kommen (englisch)
- wenn nicht anders vorhergesehen default Werte nehmen - Auswahlen mit "Leertaste" treffen
- nach ca 30 Minuten sollte der PC rebooten und XBMC sollte laden.
- unter Umständen TV deaktivieren sofern nicht gebraucht
Tutorial: (english)
- Download the ISO file from here https://dl.dropbox.com/u/21136636/htpc/i...master.iso
- Download the Unetbootin tool from here: http://www.computerbase.de/downloads/sys.../?download
- create a bootable USB boot media, select the iso file and use a USB drive with more than 64MB
- Internet connection is required!
- boot from USB - you might need to change the boot settings in BIOS r press the "one time boot key"
- smal blue windows should appear, select "Automatic HTPC Installation"
- configure network- unplug the USD drive
- guided or manual partitioning
- after first boot, an english script should run
- use default values in that dialoges - if you want to customize press "space" to select or deselect
- after 30-60 minutes, the HTPC should reboot and XBMC should automatically start on boot
- you might customize your xbmc or turn LiveTV off
enjoy
Edit:
Sample Vids:
http://www.youtube.com/watch?v=faeyH7P9Rng
Does it make a difference if I reinstall my system to 12.10 as a base for my xbmc htpc or is the 12.04 ubuntu base just as good. Would I get any benefits from it?
I am currently running a 12.04 that I have been running since this summer but since we moved into the the betas and rcs I have noticed that I am getting sync issues between my sound and my display that i never had before.
Seems to me that the sound is early in the beginning of a show.. dead on in the middle and late in the end.
Michael.
should be almost no difference.
u may try out my ISO file
Krautmaster: just for the record - am I getting right that this an installation without any graphical interface behind, so there's no way to e.g. browse the web?
(2013-01-05, 12:36)jannk Wrote: [ -> ]And how much performance improvements brings Xvba comparing to 'standard' XBMC installation from http://xbmc.org ?
Quite a lot if you play HD content, especially on slower CPU/APUs. The best thing the 'standard' version has is VAAPI in this regard. But that doesnt work well.
For example i have a bdrip 1080p mkv that uses ~60-80% CPU with software decoding (AMD A8-5500 APU with 12.12 release driver). VAAPI uses ~40-50, but i get artefacts, its unwatchable.
Xvba gives ~28% (give or take 1%, very small variations), works perfectly. For that matter, i get ~28% for any 1080p clip i play and ~20 for standard ones. Idle is at ~10%.
EDIT:
As of 12 RC3, idle usage is at 2-3% CPU, 1080p playback with Xvba ~19-20%. Nice.
(2013-01-08, 15:24)jannk Wrote: [ -> ]Krautmaster: just for the record - am I getting right that this an installation without any graphical interface behind, so there's no way to e.g. browse the web?
FireFox is included in my preconfigured setting u may coose in install (is ticked by default) - will be there in XBMC Main Menu to launch FireFox in Full HD.
Normally there comes no desktop with. Its based on a minimal installation, u may use a 4 GB USB drive as OS drive too ... but running FireFox means i need to install fluxbox as minimal windows manager with xbmc. So u can run other applications as well but its designed to use XBMC as main GUI.
LiveTV via VDR and VNSI is included as well.
Krautmaster: I tried your installation script, despite some struggles with German language :-) I managed to install it, thanks.
It looks just fine, but I wasn't able to connect it through secured wifi (it never prompted for a password) + after the installation the main XBMC menu is partially still in German. I did switch to English, most of the menu is in English, but items like BEENDEN, FILME, SERIEN, BILDER, MUSIK seem still German to me (in Aeon Nox; Confluence is fine)
I'll have a more detailed look tomorrow, it could be just my mistakes.
no no i recognized the same... any how the AEON Nox skin doenst switch to english - dont ask me why... buggy.
The Diffuse Skin does.
@ Wifi problems.
I got the same one day. I needed to choose cancle on wireless configuration, a error message will appear. After, i can select configure network again... and it works fine. When network is done it continues with the unattened install.
Need to figure out why this happens...
User is xbmc / pass too... btw - it is still normal ubuntu + xbmc. If u delete the .xbmc folder u have completely standard.
