(2013-01-08, 20:19)Krautmaster Wrote: [ -> ]FireFox is included in my preconfigured setting u may coose in install (is ticked by default) - will be there in XBMC Main Menu to launch FireFox in Full HD.
Tutorial please !!!
I tried it last time on eden but did not get arround the half Screen Issue...
(2013-01-09, 01:10)Krautmaster Wrote: [ -> ]@ Wifi problems.
I got the same one day. I needed to choose cancle on wireless configuration, a error message will appear. After, i can select configure network again... and it works fine. When network is done it continues with the unattened install.
well, even if I cancel automatic installation process, so I can configure network manually (btw: this step really helps to change language and keyboard from German to other language), the installer still doesn't prompt for WPA credentials ... makes really difficult to use this script for me :-(
https://dl.dropbox.com/u/21136636/htpc/i...master.iso
should be engslish
Any how the us webserver is offline... problems... so i did a new iso file with english and mapped to my dropbox
if u know the content of the content of the htpc.seed file u may help me in correcting that wifi problem...
Quote:# Localization
d-i console-tools/archs select en
d-i console-keymaps-at/keymap select en
d-i keyboard-configuration/xkb-keymap select en
d-i console-setup/modelcode string pc105
d-i keyboard-configuration/layoutcode string en
d-i console-setup/variantcode string nodeadkeys
keyboard-configuration keyboard-configuration/modelcode string pc105
keyboard-configuration keyboard-configuration/layout select Germany
keyboard-configuration keyboard-configuration/variant select Germany - Eliminate dead keys
keyboard-configuration keyboard-configuration/variantcode string nodeadkeys
keyboard-configuration keyboard-configuration/layoutcode string de
locales locales/default_environment_locale select en_US.UTF-8
locales locales/locales_to_be_generated multiselect de_DE.UTF-8 UTF-8, en_US.UTF-8 UTF-8
# Network configuration
#d-i netcfg/choose_interface select auto
#d-i netcfg/get_hostname string htpc
#d-i netcfg/dhcp_failed note
#d-i netcfg/dhcp_options select Configure network manually
# Clock and time zone setup
d-i clock-setup/ntp boolean true
d-i time/zone string Europe/Berlin
# keine Nutzungsinfos senden
popularity-contest popularity-contest/participate boolean false
# partitionating
#d-i partman-auto/disk string /dev/sda
#d-i partman-auto/method string regular
#d-i partman-lvm/device_remove_lvm boolean true
#d-i partman-md/device_remove_md boolean true
#d-i partman-auto/choose_recipe select atomic
#d-i partman-partitioning/confirm_write_new_label boolean true
#d-i partman/choose_partition select finish
#d-i partman/confirm boolean true
#d-i partman/confirm_nooverwrite boolean true
#d-i partman-lvm/confirm boolean true
# Mirror settings
d-i mirror/country string manual
#d-i mirror/http/hostname string de.archive.ubuntu.com
d-i mirror/http/hostname string archive.ubuntu.com
d-i mirror/http/directory string /ubuntu
d-i mirror/http/proxy string
d-i debconf/priority select critical
d-i auto-install/enabled boolean true
# Account setup
d-i passwd/user-fullname string xbmc
d-i passwd/username string xbmc
d-i passwd/user-password password xbmc
d-i passwd/user-password-again password xbmc
d-i user-setup/allow-password-weak boolean true
# Apt setup
d-i apt-setup/restricted boolean true
d-i apt-setup/universe boolean true
d-i apt-setup/multiverse boolean true
d-i apt-setup/backports boolean true
d-i apt-setup/non-free boolean true
d-i apt-setup/contrib boolean true
d-i apt-setup/security-updates boolean true
d-i apt-setup/partner boolean true
# Package selection
tasksel tasksel/first multiselect ubuntu-standard
d-i pkgsel/include string openssh-server
d-i pkgsel/update-policy select none
##################################### geht #######################################
# This command is run just before the install finishes, but when there is
# still a usable /target directory. You can chroot to /target and use it
# directly, or use the apt-install and in-target commands to easily install
# packages and run commands in the target system.
d-i preseed/late_command string in-target mkdir /xbmcscripts; in-target wget -O /xbmcscripts/htpc.sh url=http://dl.dropbox.com/u/21136636/htpc/iso/htpc.sh; in-target chmod +x /xbmcscripts/htpc.sh; in-target sed -i 's/exec \/sbin\/getty -8 38400 tty1/exec \/bin\/login -f xbmc < \/dev\/tty1 > \/dev\/tty1 2>\&1/' /etc/init/tty1.conf; in-target chmod 755 /home/xbmc/.bashrc; echo "echo xbmc | sudo -S /xbmcscripts/htpc.sh" >> /target/home/xbmc/.bashrc
# Finishing up the installation
d-i finish-install/reboot_in_progress note
(2013-01-09, 18:55)john.cord Wrote: [ -> ] (2013-01-08, 20:19)Krautmaster Wrote: [ -> ]FireFox is included in my preconfigured setting u may coose in install (is ticked by default) - will be there in XBMC Main Menu to launch FireFox in Full HD.
Tutorial please !!!
https://github.com/Krautmaster/xbmc-ubun...firefox.sh
Wooow!
With the official catalyst 12.10 suspend/hibernate/resume works like a charm!!!
I´m using this new fglrx 9.02 since 5 days now on my ASUS E35M1-I Deluxe board with Ubuntu 12.04 and no more stuttering or other problems after resuming for now.
not sure what the issue is.
If I go for 'don't configure network now', the script goes to manual mode, so I can get back to network configuration again - and enter WPA key .... but still doesn't work for my WPA/WPA2 - Personal wireless settings. Will try on Friday again
I have a problem getting xbmc to run on my second monitor and not on the main. The setting are correct in xbmc, with output HDMI2 and fullscreen, but xbmc load on HDMI in fullscreen with my preferred HDMI2 resolution on HDMI1.
I've got it to run some few times correctly, but i'm unable to reproduce what I did different, it just works some very few times.
Here's my xbmc.log:
http://pastebin.com/xA5rJrUD
And the /usr/lib/xbmc/xbmc-xrandr:
http://pastebin.com/JgJgqYL8
I've noticed this in the log:
22:32:03 T:140254502549376 NOTICE: Using visual 0x21
The ID 0x21 isn't a ID in /usr/lib/xbmc/xbmc-xrandr so I have no idea why xbmc are using it.
If someone got a dualscreen working with the git version, how did you do it? And if anyone else has a clue, please reply!
(2013-01-09, 23:13)john.cord Wrote: [ -> ] (2013-01-09, 21:22)Krautmaster Wrote: [ -> ]https://github.com/Krautmaster/xbmc-ubun...firefox.sh
Ok and how do i start it? Do i need the advancedlauncher Plugin?
yep. Download von google code. Then create a launcher, Linux platform ... add a favourite for that launcher and then choose this favourite to add a main menu icon
(2013-01-09, 22:29)jannk Wrote: [ -> ]not sure what the issue is.
u can setup minimal ubuntu by ur own and simply start the script in putty then.
wget
https://raw.github.com/Krautmaster/xbmc-...install.sh
bash prepare_install.sh
(2013-01-04, 16:01)morktral Wrote: [ -> ]I hope I don´t capture this thread but I´m having severe prblems installing the AMD drivers on my machine, maybe some of you guys can give me a lead.
I bought a Zotac AD06 with AMD 7340 HD installed, The configuration is as follwing:
Xubuntu 12.10 64 bit, XBMC Frodo RC3, (Both of them are working fine with the machine, sound via HDMI finally enabled). Mainly installed with the guide from here (as already mentioned in the first posting) yoursuchageek
fritsch was so kind to help me with this problem of mine.
If somebody of you is haveing trouble installing the AMD drivers try, as a startingpoint, to change in BIOS from UEFi to LegacyOs which did the trick on my machine
Thanks again fritsch
(2013-01-10, 00:20)Krautmaster Wrote: [ -> ]yep. Download von google code. Then create a launcher, Linux platform ... add a favourite for that launcher and then choose this favourite to add a main menu icon
does not work for my, downloaded advanced launcher from the frodo plugin repo but gives me an error...
Hi fritsch,
Thanks again for the GLrenderer code pointers. I finally got Eclipse CDT/XBMC Frodo working on Intel VAAPI and then fixed/cropped the Interlace lines at the bottom for 1080i {1088i actually} vids. Hurray! Eclipse Juno is SO fast for running patches!
@Wsnipex/Fritsch
How can I git clone Eden latest stable XVBA so that I can run it on my AMD target. I cannot find Eden XVBA git source to test a XVBA crop. I can move to the Dev forum if you prefer.
@gfisher:
the special xvba git tree is not existent anymore. Also I would not work on Eden if I were you. Please use the master branch of fernetmenta's github. This way you can easily send code updates upstream again, as development continues and Eden is pretty old already (with frodo being released probably every day).
Thanks. That is the fork that I started with. I must figure out how to submit patches. I am new to git and opengl/texture stuff but it's coming . This project is large and takes absorption time. I will update my ATI Eden target then.. Got more reading to do.
The actual git 2:12.0~git20130112.2341-rc3-3precise from the tested git builds doesn´t work with tvheadend.
I have an error that no PVR add-ons could be found.
