Full Version: How to Install XBMC PVR Xvba for AMD/Nvidia/Intel GPUs
Hi
I have a problem when I upgraded from Ubuntu 11.10 to 12.04. When starting video playback on some HD videos the XBMC freezes. Playback does not start. Music and SD video playback is normal.
Get:1 http://si.archive.ubuntu.com/ubuntu/ precise/main libavfilter2 amd64 4:0.8.1-0ubuntu1 [80.7 kB]
Get:2 http://si.archive.ubuntu.com/ubuntu/ precise/universe libcec1 amd64 1.6.1-2 [121 kB]
Get:3 http://si.archive.ubuntu.com/ubuntu/ precise/main liblzo2-2 amd64 2.06-1 [52.1 kB]
Get:4 http://si.archive.ubuntu.com/ubuntu/ precise/universe libnfs1 amd64 1.2.0-3 [45.6 kB]
Get:5 http://si.archive.ubuntu.com/ubuntu/ precise/main libpcrecpp0 amd64 8.12-4 [16.2 kB]
Get:6 http://si.archive.ubuntu.com/ubuntu/ precise/universe libshairport1 amd64 1.2.1~git20120110.aeb4987-1 [25.8 kB]
Get:7 http://si.archive.ubuntu.com/ubuntu/ precise/main libvdpau1 amd64 0.4.1-3ubuntu1 [30.1 kB]
Get:8 http://si.archive.ubuntu.com/ubuntu/ precise/universe libhal1 amd64 0.5.14-8 [78.4 kB]
Get:9 http://si.archive.ubuntu.com/ubuntu/ precise/universe libhal-storage1 amd64 0.5.14-8 [23.8 kB]
Get:10 http://si.archive.ubuntu.com/ubuntu/ precise/universe libmicrohttpd5 amd64 0.4.6-1 [31.2 kB]
Get:11 http://si.archive.ubuntu.com/ubuntu/ precise/universe libtinyxml2.6.2 amd64 2.6.2-1build1 [35.3 kB]
Get:12 http://si.archive.ubuntu.com/ubuntu/ precise/universe xbmc-bin amd64 2:11.0~git20120423.cd20772-1 [7,369 kB]
Get:13 http://si.archive.ubuntu.com/ubuntu/ precise/universe xbmc all 2:11.0~git20120423.cd20772-1 [25.4 MB]
It seem the problem is that it is not taking the xbmc from ppa:wsnipex/xbmc-xvba. I installed it from deb files and it is working, but I get upgrade notifications. How can this be fixed?
This will be solved soon. Please also note, that ppa:wsnipex/xbmc-xvba will soon get post-eden(12.0 pre) packages.
If you want to stay with Eden stable code switch to: ppa:wsnipex/xbmc-xvba-eden
Last week i did a upgrade to AMD Fusion A6-3500. I mention some stutter problems with some older .mkv files.
Also PVR does give weird images when watching tv.
So i decided to go back to my ION system. But i got frame drops. Today i was thinking after finding this topic to give my fusion system another try. The overall picture is good on ION.
I am on XBMCbuntu Eden final. So my question is can i use this on XBMCbuntu or do i need to start from scratch? Will it make my system more stable if i compare it to Eden final?
you can just use the Eden ppa from this thread(see post above or the howto)
Owk thx wsnipex for the quick answer i am installing XBMCbuntu just switched from ion to fusion.
(2012-04-23, 21:09)FernetMenta Wrote: [ -> ]
17:10:31 T:140285433517824  NOTICE:  fps: 23.976024, pwidth: 1424, pheight: 1080, dwidth: 1424, dheight: 1080
17:10:31 T:140285433517824   DEBUG: OutputPicture - change configuration. 1424x1080. framerate: 23.98. format: XVBA
17:10:31 T:140285433517824   DEBUG: Resolution 1360x768 @ 60.02 - Full Screen (12) not a very good match for fps 23.976 (weight: 0.166), trying 2:3 cadence
17:10:31 T:140285433517824  NOTICE: Display resolution ADJUST : 1360x768 @ 60.02 - Full Screen (12) (weight: 0.001
Can you try with refresh rates which are closer to video fps?
Hi, tried with a lot of refresh rates. But the error does not disappear. Are there other options?
Could you give instructions to completely remove the amd video drivers so I can try to reinstall the whole thing (display gets to sleep every 5 min too. The suspend resume is present.
#!/bin/sh
case $1 in
     suspend|suspend_hybrid|hibernate)
        /usr/sbin/service lightdm stop
        /sbin/rmmod -f fglrx
     resume|thaw)
        /sbin/modprobe fglrx
        /usr/sbin/service lightdm start
esac
First i did spent time reading. But i am not sure where to start as i am already using XBMCbuntu with the latest 11.0-pvr build from pulse-eight packages.
I already added the repository:
sudo add-apt-repository ppa:wsnipex/xbmc-xvba-eden
sudo apt-get update
What about the app-get install cmd doesn't that break my xbmc?
sudo apt-get install xbmc xbmc-bin
My gpu: AMD Radeon HD6530D (A6-3500)
Catalyst version 11.11
Would there be any benefit by upgrading the Catalyst version?
I suggest you remove the pulse-eight ppa, uninstall xbmc, then install again(after adding my ppa)
about catalyst: depends, you need at least 11.11. just try with the one you have and see if it works.
hi guys,
I have another problem with XBMC. I have installed successfully following the guide and the .mkv video file and music are played without problems.
When I try to start a .mp4 video XBMC crashes and is restarted automaticcaly. What does it means? How can I fix this problem?
@CrazYoshi:
Please supply a xbmc.log with debugging turned on. Put it into a pastebin (paste.ubuntu.com) and supply the link, please.
Here is the log file: http://paste.ubuntu.com/954659/
Please, let me know why my XBMC crashes with .mp4 files...
@CrazYoshi:
Can you move: Campaign Crack/0718_sc2_rld_1.0.3crack.rar out of the way? :-)
I got a problem installing 64-bit 11.10 Ubuntu Oneric minimal.
When i am at the part partition disks my SSD is seen as SDB instead of SDA
The usb flash drive i use to install ubuntu from is SDA.
So i get an error with the grub bootloader.
Is there a way i can swap it?
(2012-04-29, 12:40)fritsch Wrote: [ -> ]@CrazYoshi:
you are totally right. XD Now it works... Thanks
